The library manager inside Fusion Digital Power Designer allows entry of the tolerance for the output capacitors.
How is this tolerance factored into the calculation of the compensation coefficients?
I've reviewed SLUU490 and the loop compensation chapter, but I'm not sure which value for "C" is being used: min,max, or typ?
In FDPD, if I first "Autotune" the compensation, then switch to "Manual" mode and change the output capacitance and see some change.
Is there a better way to hold the compensation constant and verify the stability of the regulator over output capacitor tolerance?
Thanks, Best, Steve
