U54 on the first page did not turn on. I believe it follows the recommended circuit exactly (Figure 20). The EN voltage is ~ ground.
Feedback would be appreciated.
Please make sure following things:
1. before VCC is above to 2.7V. the EN threshold is below its on threshold. ideally you do not want that EN reaches its on level before VCC reaches its working level.
2. if above is true, check the EN threholsd to make sure it is above its on threshold to turn on the FLAGS output after VCC is at its working level.
Yihe
Hi Yihe,
We found the issue.
Basically the Pins 2 and 3 were swapped on the schematic.
I tested on eval board and LM3880 works as expected.
Thank you,
Andrew
