Other Parts Discussed in Thread: LM5017
Using the LM34910C, presently my output voltage has nearly 100mv ripple which I would like to reduce. So i reviewed my notes and see that the original design was run through Web Bench. I went to Web bench and received a message that the part is found but is not supported.
Now this may be true but my memory, which is often suspect, and my few notes clearly show Web Bench values. I then checked the Web Bench history ( my history ) and found nothing. I know I ran several analysis' within the last couple of months.
So, what is going on?
[Now this oddity of not being able to access a previous web bench derived design has happened before ( about a year ago ) with the LM5017.]
Thank you.
Jaye
