Part Number: TPS22968
Page 16 of the datasheet states that the capacitors connected between CT and GND must be rated for 25V or higher. I understand there is a charge pump in this device, but this seems a bit excessive- please confirm.
Also, if this is truly the case, it would be very helpful if the data sheet were much more explicit about this requirement instead of burying it in a paragraph halfway through the data sheet.
Thanks, Best, Steve
