Part Number: DS3658
Team,
My customer needs the following clarification. Any light/background you can shed would be much appreciated.
We are awaiting delivery of some parts, the TI DS3658, I believe from a distributor. The delivery is being held up because the datasheet currently says that I-input-high is 1 uA max. Our spec says the max current is 10uA.
Digging through old datasheets, I found that when it was a National Semi datasheet, the Input High max current was 10 uA, but as soon as it changed to a TI datasheet, the max
value changed to 1uA. Another oddity is that the "typical" value on both datasheets is 1uA. It seems odd that the Max value would be the same as the Typical value, doesn't it?
Is there a way you can check this? I have a feeling that maybe the value was just transcribed to the new datasheet incorrectly.
Aaron
