Hi Ti Engineers,
When the UCC28251 was powered by 5V, the VREF pin has no output.I have checked the layout of PCB,No problems found. I don't know why.(Main circuit is not welded)
shaowei.
Hi Shaowei,
It is strange. You may want to check from below perspectives.
1) Check PCB to ensure high impendance to groud at VREF, OUTA/B and SRA/B respectively.
2) Swap chip to another to exlcude the possiblity of IC failure.
Happy debug!
BR
Frank
Hi Shaowei,
Since we are not as familiar with your design as yourself, reviewing your PCB file is not a straight forward way for us to support you on this issue.
Could you please get a TI EVM and test the part under 5V bias to see if you can reproduce the same issue as what you saw on your board? If you can, it help us on the same page quickly. If not, you can use EVM as a reference to debug your board.
Another suggestion on your board debug is to increase VDD voltage a little to see if the issue can be solved. Noticed that the minimum recommended supply voltage of UCC28251 is 4.7V and 5V bias in your application does not leave enough margins.
BR
Frank
