Part Number: UCD9248
Hi, Team,
My customer didn't use the Ch1-B, and he let the DPWM-1B, SRE-1B floating, FLT-1B grounded. Connect the voltage signal to CS-1B, could he get the value of the voltage with the UCD9248?
Hi, Team,
The Current Sense (CS) pins on UCD9248 receive a small voltage that is proportional to the amount of current going through the power stage. They cannot be used for measuring output voltage.
If they are not using Ch1-B, they should ground CS-1B.
The output voltage of the power stage being controlled by CH-1A is measured by the EAp1 (V+) and EAn1 (V-) pins.
