Hi Sir,
If the EN pin is connect to ground the resistor connected to Iset will control the input current.
If i set the input current to 177mA. VIN has connected to USB.
When the output current is around 550mA, the charger IC will change to supplement mode and external PMOS will be turn on? It will supply the output current from input current and battery on the same time, right?
