Other Parts Discussed in Thread: TPS54110, TPS63070
I require two power rails in my circuit - 6V and 3.3V. I am using the TPS55160 for the previous and TPS54110(Buck converter) for the latter. My input ranges from 4V to 9V. Since the Buck converter does not have the required input voltage range, I tried connecting the output of the Buck-Boost to it. But this caused a drop in the output voltage of the Buck-Boost to about 4V and neither of the power requirements were fulfilled. Can someone help me with what went wrong, and if there is some modification that can solve the issue? I am thinking of using another buck converter with a larger input range if I don't find any solution to this.
Thanks!
