Hello E2E,
Please let me know about this topic. I could not to find calcration for soft start setting from datasheet.
I looked at the past post, but it was unresolved.
ACGUY
Hi ACGUY,
Please check the below ss circuit for the LM5000: it is determined by the internal 5k resistor and the external ss cap. but since it clamp the Vcomp voltage, so the ss time doesn't has a linear relationship with the Vout. The Vout also relate to the output load and output cap. So it is hard to calculate. You can test it on your board, which is more directly. Then adjust it to a value you wanted.
