Hi.
My goal here is to implement the IC in a circuit using 12V as it's charging voltage.
To my understanding of the datasheet, the IC itself does not draw any significant amount of current from whatever source.
Then, is it safe to use a simple voltage divider around 100ks to cut the voltage to the recomended walue of the IC?(<10V)
Will it not cause any significant inefficiency, reagarding the fact the battery back is 2600mAh in it's capacity.
Thank You.
