Dear all,
can you suggest a circuit to generate a delayed power on using the SD pin ? The LM2936 has a SD which works in the opposite way respect with most of similar devices.
regards,
Domenico
Hi Domenico,
Often people will use a GPIO of another device in their application to programmatically sequence their different voltage rails; however, there are other options if this is not available in your system. Another method is to use a SVS such as TPS3896P or TPS3898P. The other common method is to use a RC delay. You would still place the resistor between the source of Ven and the capacitor like you would for a delay on a EN pin; however, in this case you will be discharging the capacitor instead of charging the capacitor for the delay time.
Very Respectfully,
Ryan
Hi Ryan,
thanks, I was thinking to the RC approach. usually you connect the source of the EN pin (in this case SD) to the VIN with RC circuit. But in this case what do you suggest to discharge the capacitance ?
regards,
Domenico
