LM5010A: Datasheet spec details
Part Number: LM5010A
Team,
My customer is looking for additional details on datasheet specs:
One of the parameters I’m looking at is the UVLO that occurs at 5.25V.  The 5.25V is a typical datasheet value and I’m interested in the range or distribution of this parameter.  There is no minimum boundary defined and I assume the maximum boundary is the 6V minimum input voltage or 6V minimum minus some hysteresis.  Is this something you can help me with?
Also, there is a startup sequence diagram shown in figure #1 of the LM5010A datasheet.  Is there a similar diagram shown for shutdown?  I’m interested in how the hysteresis works around the UVLO when the supply is increasing to power-on and decreasing to power-off.
Viktorija
