Other Parts Discussed in Thread: TIDA-00778,
Having configured UCC from TIDA-00778 it is clear Cboot 1000n was causing HO to produce PW >50us, open loop pulses. Likewise choice of VDD bias cap (10000n) UCC datasheet recommends 10x Cboot or 1000n. Could 10000n VDD bias cap cause LO overshooting? Does the UVLO circuit struggle <10000 VDD pin 7 bias? Competitions gate driver UVLO only require 100n VDD bias cap in our other 3 phase motor inverter.
Adding several external Schottky didoes (HO/LO) to stop overshoot is an internal requirement if UCC can not exceed competitions gate driver in similar configurations. At what frequency are Schottky diodes required to stop HO/LO overshoot and have they been tested to stop overshoot at industry typical PWM frequencies? TIDA-00778 design analysis fails to show zoomed out resulting HV phase drive from OGBT module relative to much higher Cboot/VDD bias cap values.
Might TIDA-00778 over compensate VDD/Cboot cap values also not clearly elaborate reasons for contradicting UCC datasheet application text? Might a post mortem follow up include UCC life expectancy under larger VDD/Cboot capacitance values benefit the community?
