Part Number: LM5170-Q1
Hi
Try to use the circuit breaker of the LV port as shown below.
Can turn off the circuit breaker function if reverse voltage is applied to the lv-port?
Hi
Hi David,
The circuit breaker does not help in the reverse voltage protection, and there will be a path from the IC's esd structure and the body diode. In order to protect against reverse polarity, you may consider the following circuit.
Youhao Xi, Applications Engineering
