Part Number: TPS2373
Other Parts Discussed in Thread: TPS23880
I'm designing a .bt PoE 5-port switch with an ideal rectifier bridge.
I want to use the PG pin, with a 10k ohm pull-up to 3.3V (one of the power supply outputs). It will trigger the ideal rectifier to transition to "ideal" state, and it will trigger my PSE chip to begin operation (TPS23880).
This circuit does not use the transformer aux bias supply as shown in your typical circuits. Rather VDD and RTN directly feed the 24V and 3.3V supplies, both of which simply turn on as voltage is supplied to them.
What should I do with the VC_IN and VC_OUT pins?
Thanks! Jo
