Other Parts Discussed in Thread: TPS22918, TPS22976
Section 3 of the data sheet on sheet 1 says "a 220-Ohm on-chip load resistor is added for quick output discharge when switch is turned off"
The Functional Block Diagram in section 8.2 shows FETs pulling Vout to ground, or connecting to Vin based on the ON input state.
I'd like to verify whether the 220-Ohm load is a resistor in the part tied between Vout and ground that is not shown in section 8.2, or is implemented another way (e.g., a high on-resistance FET).
David
