can you please advise the efficiency level of the voltage regulator P/N: TPS72025QDRVRQ1 and if/how the output voltage can be regulated?
Or would there be another high efficiency voltage regulator available with an even higher efficiency level?
Required a high efficiency voltage regulator with an input voltage of 4.5VDC and an output voltage of 2.5VDC
Thank you.
Best regards
Adnan
