Do you have ripple characteristics for this part? Other TI converters typically publish the graph, but not this one.
Does low power enable (PS) pin have to be pulled high for normal operation?
Is VINA supplied internally? The confusion is that the datasheet calls it an Input pin.
What are the output characteristics when EN pin is pulled low? There is some ambiguity in the description.
thank you!
