The datasheet says that the OC pin can be configured to be a DESAT detection and the threshold can be programmed. I don’t see any programmable threshold setting. When it says programmable does it mean adding Desat diodes + resistors between the OC pin and the Drain of the FET, or is there an actual internal programmable setting inside the IC?
Viktorija
