BQ34110: Learn FCC Update Limit
Part Number: BQ34110
Other Parts Discussed in Thread: BQSTUDIO, GPCCEDV
Hello again,
After running multiple logging discharge cycles, I have noticed that FCC never updates itself by more than 256 mAh. In the BQ34110 TRM, it says "FCC cannot be reduced by more than FCC Learn Down or increased by more than FCC Learn Up during any single update cycle". "FCC Learn Down" and "FCC Learn Up" are bolded and italicized, which I assumed meant that they are data flash parameters that can be altered. However, there is no such parameter in BQStudio, and there is no other mention of these parameters elsewhere in the TRM.
Is it possible to increase the FCC Learn Down/Up limit to greater than 256 mAh? Or, if the parameter has only enough space for a 1-byte number, is there a way to turn off the limit entirely? I am asking this because it is clear that our batteries have a full charge capacity that is significantly lower than the Learned Full Charge Capacity reported by the chip (after fully charging, the RC value is approximately 5 Ah, while the learned FCC is approximately 7.8 Ah). I know that Learned Full Charge Capacity is a data flash parameter that can be changed, but I would rather let the chip measure it automatically, just in case our charger isn't working properly somehow. At the same time, I don't want to have to do 6 or 7 charging and discharging cycles because the Learned FCC can only update 256 mAh at a time.
Thanks again for any advice you can give.
Colin
  • Hi Colin
    How large are expected FCC updates to your device?
    FCC learn Up and FCC Learn down are private parameters.
    Sincerely,
    Bryan Kahler
  • Hello Bryan,
    Thanks for answering! While we are testing, the FCC updates seem to be quite large. Our battery only ever charges up to about 5 Ah RC while design capacity is 8 Ah (this is after only using the batteries for our GPC cycles). This isn't really our main concern, as we can change the learned FCC parameter if necessary. I'm more worried about when the batteries are used in their UPS application. The batteries are expected to rarely be discharged, if at all, and I doubt that the client would want to run periodic full discharge cycles. If the batteries have aged enough that FCC drops by 500 to 1000 mAh, then even after a recent full discharge, the learned FCC still won't show an accurate value, and consequently SoH and SoC will be skewed as well. In short, I don't know by how much FCC will change in between discharge cycles, but I would like to have an accurate FCC estimation if it drops by a large amount, say 500 mAh or more.
  • After more testing, I'd just like to add that there seems to be a difference between the chip's remaining capacity counter vs. the actual nominal design capacity of the battery. Even after using a fresh battery and running a discharge and charge cycle, the remaining capacity never charges back up over 5.5 Ah when the battery is rated 8 Ah, even when the voltage hits around 13.5 V (we are using 12V, 8Ah batteries). If we discharge them again from this 5.5 Ah point, Time to Empty (TTE) and State of Charge (SoC) estimations decrease linearly and continuously, and TTE seems to be very accurate. However if we disconnect and reconnect the chip to the battery in order to trick it into thinking it is at 8 Ah, 100% SoC, the TTE and SoC will decrease linearly to about 30% SoC until it gets close to EDV2, then drops abruptly to 7% SoC and 5 minutes TTE.
    This makes me think that the 5.5 Ah, ~60% SoC value is more trustworthy. But since the SoC is always at 60% max, FCC will never be able to update since SoC needs to be near full for it to qualify as a valid discharge. And even if we can trick the chip into thinking we're at FCC of 8 Ah, running an discharge cycle will only update the FCC by 256 mAh. Should we be just setting our design capacity to around 5.5 Ah?
    It might be easier to understand with the logs. In this log we did a full discharge from full charge capacity, 100% SoC. Then we charged it back up, but it only reached 65% SoC. I realize that the current doesn't taper off, but the voltage is already high enough that RC should be much closer to 8 Ah.
    TestDCLog-4-9-19-823.log
    This log is a continuation from the previous log, when it started discharging around the same voltage as the first log, but only around 65% SoC. The RC, SoC and TTE of this log is much more continuous and doesn't jump abruptly.TestDCLog-4-9-19-1338.log
  • Hi Colin,
    Thank you for the descriptive update. Due to current loading it will take some time to analyze these logs. Please expect another update by EOD Friday 4/19/2019.
    Sincerely,
    Bryan Kahler
    Just another update for whenever somebody gets the time to look into this problem: we charged the battery fully all the way to 100% capacity (close to 8 Ah) by using a power supply (instead of tricking the chip into thinking it's full SoC). The battery voltage peaked at about 13.5 OCV. We then started discharging from that point at full load (12A) and we had the same problem of the BQ34110 overestimating the time-to-empty and SoC values again (see attached log). At this point we are also wondering if our battery profile might be the problem. The CEDV calculator returned FCC OCV of 11.9V when it seems that our battery isn't full charge until it's closer to 13.5 V. I've also attached the battery profile and GPC logs to this post. FinalParams6s.zip
    Discharge7.log
  • Hi Colin,
    With respect to the GPCCEDV tool, if underestimation is seen, for example, with a low temp high rate application, replace the low temp high rate log file with one at a higher rate and try rerunning the tool over the data.
    Looking through the nested zip files, I wasn't able to find the gg.csv file. If issues persist, could you please attach that as well?
    Sincerely,
    Bryan Kahler
  • Thanks for the reply, I've attached the gg.csv file here: BQ34110GGCSV.xlsx We've seen underestimation at both lower and higher rates at room temp, so we're redoing both logs. I'll let you know if there's any improvement.
  • Hi Colin,
    Thank you for the update.
    Sincerely,
    Bryan Kahler
  • Hello Bryan,
    Finally got done with re-characterizing the battery. We actually redid all 6 logs- we thought we hadn't charged up the batteries the full way during the first set, so that might be the problem. With the new characterization, we are seeing a reduced error, but the TTE is still dropping from 11 minutes to 3 minutes. This is our characterization logs:
    NEWGPC3.zip
    This is the parameter zip file we received from TI:
    NEWGPC3-report.zip
    This is an example discharge with the new parameters:
    Discharge GPC3.log
    Fri Apr 26 11:30:46 ADT 2019
    Device Name = bq34110
    Firmware Version = 0_02
    Design Capacity = 8000
    Sample,DateTime,ElapsedTime,Control,Temperature,Voltage,Batt Stat,Current,RemCap,FullChgCap,AvgCurr,RunTimeEmty,AvgTimeFull,AccumulatedCharge,AccumulatedCharge Time,AvgPwr,IntTemp,CycleCnt,RSOC,SOH,ChgVolt,ChgCurr,OpStat,GaugeStat,CEDVRemCap,EDV Threshold,SmRemCap,SmCurrent,ManufacStat,EOSLearnStatus,EOSSafetyStatus,EOSStatus,AutoLearnTime,AvgDsgCurrent,AvgDsgTemp,LearnedResistance,LearnedResTimeHours,LearnedResTimeSeconds,LastLearnedResistance,LastLearnedResHours,LastLearnedResSeconds,InitialRRateAgeHours,InitialRRateAgeSeconds,RRate,RRateLong,InitialRcellRRateLearnRes,InitialRcellRRateLearnCount,LogRowTime(ms),LogStatus
    1,2019-04-26 11:30:51,4.001,0x0000,30.9,12576,0x0080,0,4685,7488,0,65535,65535,0,0,0,28.5,5,63,94,13200,4000,0x0282,0x40,1940,1782,4685,3077,0x08,0x0840,0x00,0x01,1885,0,-273.2,97,23,1971,198,23,1004,0,0,0,0,0,0,674,SUCCESS
    2,2019-04-26 11:30:55,8.002,0x0000,30.9,12576,0x0080,0,4685,7488,0,65535,65535,0,0,0,28.5,5,63,94,13200,4000,0x0282,0x40,1940,1782,4685,3077,0x08,0x0840,0x00,0x01,1881,0,-273.2,97,23,1975,198,23,1004,0,0,0,0,0,0,672,SUCCESS
    3,2019-04-26 11:30:59,12.002,0x0000,30.9,12576,0x0080,0,4685,7488,0,65535,65535,0,0,0,28.5,5,63,94,13200,4000,0x0282,0x40,1940,1782,4685,3077,0x08,0x0840,0x00,0x01,1877,0,-273.2,97,23,1979,198,23,1004,0,0,0,0,0,0,676,SUCCESS
    4,2019-04-26 11:31:03,16.003,0x0000,30.9,12576,0x0080,0,4685,7488,0,65535,65535,0,0,0,28.5,5,63,94,13200,4000,0x0282,0x40,1940,1782,4685,3077,0x08,0x0840,0x00,0x01,1873,0,-273.2,97,23,1983,198,23,1004,0,0,0,0,0,0,669,SUCCESS
    5,2019-04-26 11:31:07,20.004,0x0000,30.9,12576,0x0080,0,4685,7488,0,65535,65535,0,0,0,28.5,5,63,94,13200,4000,0x0282,0x40,1940,1782,4685,3077,0x08,0x0840,0x00,0x01,1869,0,-273.2,97,23,1987,198,23,1004,0,0,0,0,0,0,676,SUCCESS
    6,2019-04-26 11:31:11,24.005,0x0000,30.9,12576,0x0080,0,4685,7488,0,65535,65535,0,0,0,28.5,5,63,94,13200,4000,0x0282,0x40,1940,1782,4685,3077,0x08,0x0840,0x00,0x01,1865,0,-273.2,97,23,1991,198,23,1004,0,0,0,0,0,0,671,SUCCESS
    7,2019-04-26 11:31:15,28.005,0x0000,30.9,12576,0x0080,0,4685,7488,0,65535,65535,0,0,0,28.5,5,63,94,13200,4000,0x0282,0x40,1940,1782,4685,3077,0x08,0x0840,0x00,0x01,1861,0,-273.2,97,23,1995,198,23,1004,0,0,0,0,0,0,670,SUCCESS
    8,2019-04-26 11:31:19,32.006,0x0000,30.9,12576,0x0080,0,4685,7488,0,65535,65535,0,0,0,28.5,5,63,94,13200,4000,0x0282,0x40,1940,1782,4685,3077,0x08,0x0840,0x00,0x01,1857,0,-273.2,97,23,1999,198,23,1004,0,0,0,0,0,0,703,SUCCESS
    9,2019-04-26 11:31:23,36.006,0x0000,30.9,12576,0x0080,0,4685,7488,0,65535,65535,0,0,0,28.5,5,63,94,13200,4000,0x0282,0x40,1940,1782,4685,3077,0x08,0x0840,0x00,0x01,1853,0,-273.2,97,23,2003,198,23,1004,0,0,0,0,0,0,679,SUCCESS
    10,2019-04-26 11:31:27,40.007,0x0000,30.9,12576,0x0080,0,4685,7488,0,65535,65535,0,0,0,28.7,5,63,94,13200,4000,0x0282,0x40,1940,1782,4685,3077,0x08,0x0840,0x00,0x01,1849,0,-273.2,97,23,2007,198,23,1004,0,0,0,0,0,0,708,SUCCESS
    11,2019-04-26 11:31:31,44.007,0x0000,31.3,11448,0x0001,-9019,4675,7488,-2165,130,65535,0,0,-413,28.8,5,63,94,13200,4000,0x0282,0x40,1930,1746,4675,3077,0x08,0x0840,0x00,0x01,1845,0,-273.2,97,23,2011,198,23,1004,0,0,0,0,0,0,672,SUCCESS
    12,2019-04-26 11:31:35,48.008,0x0000,31.4,11442,0x0001,-9035,4665,7488,-3815,73,65535,0,0,-728,29.0,5,63,94,13200,4000,0x0282,0x40,1920,1746,4665,3077,0x08,0x0840,0x00,0x01,1842,0,-273.2,97,23,2015,198,23,1004,0,0,0,0,0,0,671,SUCCESS
    13,2019-04-26 11:31:39,52.008,0x0000,31.6,11436,0x0001,-9049,4655,7488,-5072,55,65535,0,0,-967,29.1,5,63,94,13200,4000,0x0282,0x40,1910,1746,4655,3077,0x08,0x0840,0x00,0x01,1838,0,-273.2,97,23,2019,198,23,1004,0,0,0,0,0,0,682,SUCCESS
    14,2019-04-26 11:31:43,56.009,0x0000,31.8,11430,0x0001,-9063,4645,7488,-6030,46,65535,0,0,-1150,29.3,5,63,94,13200,4000,0x0282,0x40,1900,1746,4645,3077,0x08,0x0840,0x00,0x01,1834,0,-273.2,97,23,2023,198,23,1004,0,0,0,0,0,0,695,SUCCESS
    15,2019-04-26 11:31:47,60.009,0x0000,32.0,11424,0x0001,-9074,4635,7488,-6760,41,65535,0,0,-1288,29.4,5,62,94,13200,4000,0x0282,0x40,1890,1746,4635,3077,0x08,0x0840,0x00,0x01,1830,0,-273.2,97,23,2026,198,23,1004,0,0,0,0,0,0,670,SUCCESS
    16,2019-04-26 11:31:51,64.010,0x0000,32.1,11418,0x0001,-9086,4625,7488,-7318,38,65535,0,0,-1394,29.5,5,62,94,13200,4000,0x0282,0x40,1880,1746,4625,3077,0x08,0x0840,0x00,0x01,1826,0,-273.2,97,23,2030,198,23,1004,0,0,0,0,0,0,669,SUCCESS
    17,2019-04-26 11:31:55,68.010,0x0000,32.3,11412,0x0001,-9095,4615,7488,-7744,36,65535,0,0,-1475,29.7,5,62,94,13200,4000,0x0282,0x40,1870,1746,4615,3077,0x08,0x0840,0x00,0x01,1822,0,-273.2,97,23,2034,198,23,1004,0,0,0,0,0,0,669,SUCCESS
    18,2019-04-26 11:31:59,72.011,0x0000,32.5,11406,0x0001,-9105,4605,7488,-8070,34,65535,0,0,-1536,29.8,5,62,94,13200,4000,0x0282,0x40,1859,1746,4605,3077,0x08,0x0840,0x00,0x01,1818,0,-273.2,97,23,2038,198,23,1004,0,0,0,0,0,0,668,SUCCESS
    19,2019-04-26 11:32:03,76.011,0x0000,32.7,11406,0x0001,-9113,4595,7488,-8320,33,65535,0,0,-1583,30.0,5,62,94,13200,4000,0x0282,0x40,1849,1746,4595,3077,0x08,0x0840,0x00,0x01,1814,0,-273.2,97,23,2042,198,23,1004,0,0,0,0,0,0,687,SUCCESS
    20,2019-04-26 11:32:07,80.012,0x0000,32.9,11400,0x0001,-9121,4585,7488,-8512,32,65535,0,0,-1619,30.1,5,62,94,13200,4000,0x0282,0x40,1839,1746,4585,3077,0x08,0x0840,0x00,0x01,1810,0,-273.2,97,23,2046,198,23,1004,0,0,0,0,0,0,685,SUCCESS
    21,2019-04-26 11:32:11,84.013,0x0000,33.0,11394,0x0001,-9129,4574,7488,-8660,32,65535,0,0,-1647,30.3,5,62,94,13200,4000,0x0282,0x40,1829,1745,4574,3077,0x08,0x0840,0x00,0x01,1806,0,-273.2,97,23,2050,198,23,1004,0,0,0,0,0,0,695,SUCCESS
    22,2019-04-26 11:32:15,88.013,0x0000,33.2,11388,0x0001,-9135,4564,7488,-8773,31,65535,0,0,-1668,30.4,5,61,94,13200,4000,0x0282,0x40,1819,1745,4564,3077,0x08,0x0840,0x00,0x01,1802,0,-273.2,97,23,2054,198,23,1004,0,0,0,0,0,0,687,SUCCESS
    23,2019-04-26 11:32:19,92.014,0x0000,33.4,11388,0x0001,-9142,4554,7488,-8861,31,65535,0,0,-1684,30.5,5,61,94,13200,4000,0x0282,0x40,1809,1745,4554,3077,0x08,0x0840,0x00,0x01,1798,0,-273.2,97,23,2058,198,23,1004,0,0,0,0,0,0,734,SUCCESS
    24,2019-04-26 11:32:23,96.015,0x0000,33.6,11382,0x0001,-9149,4544,7488,-8930,31,65535,0,0,-1696,30.7,5,61,94,13200,4000,0x0282,0x40,1799,1745,4544,3077,0x08,0x0840,0x00,0x01,1794,0,-273.2,97,23,2062,198,23,1004,0,0,0,0,0,0,731,SUCCESS
    25,2019-04-26 11:32:27,100.015,0x0000,33.7,11376,0x0001,-9154,4534,7488,-8983,30,65535,0,0,-1706,30.8,5,61,94,13200,4000,0x0282,0x40,1788,1745,4534,3077,0x08,0x0840,0x00,0x01,1790,0,-273.2,97,23,2066,198,23,1004,0,0,0,0,0,0,686,SUCCESS
    26,2019-04-26 11:32:31,104.016,0x0000,33.9,11376,0x0001,-9160,4524,7488,-9025,30,65535,0,0,-1713,30.9,5,61,94,13200,4000,0x0282,0x40,1778,1745,4524,3077,0x08,0x0840,0x00,0x01,1786,0,-273.2,97,23,2070,198,23,1004,0,0,0,0,0,0,686,SUCCESS
    27,2019-04-26 11:32:35,108.016,0x0000,34.1,11370,0x0001,-9165,4513,7488,-9058,30,65535,0,0,-1719,31.1,5,61,94,13200,4000,0x0282,0x40,1768,1745,4513,3077,0x08,0x0840,0x00,0x01,1782,0,-273.2,97,23,2074,198,23,1004,0,0,0,0,0,0,686,SUCCESS
    28,2019-04-26 11:32:39,112.016,0x0000,34.2,11364,0x0001,-9170,4503,7488,-9085,30,65535,0,0,-1723,31.2,5,61,94,13200,4000,0x0282,0x40,1758,1745,4503,3077,0x08,0x0840,0x00,0x01,1778,0,-273.2,97,23,2078,198,23,1004,0,0,0,0,0,0,684,SUCCESS
    29,2019-04-26 11:32:43,116.017,0x0000,34.3,11364,0x0001,-9174,4493,7488,-9106,30,65535,0,0,-1727,31.3,5,61,94,13200,4000,0x0282,0x40,1748,1745,4493,3077,0x08,0x0840,0x00,0x01,1774,0,-273.2,97,23,2082,198,23,1004,0,0,0,0,0,0,703,SUCCESS
    30,2019-04-26 11:32:47,120.017,0x0000,34.5,11358,0x0001,-9178,4483,7488,-9123,29,65535,0,0,-1729,31.5,5,60,94,13200,4000,0x0282,0x40,1737,1745,4483,3077,0x08,0x0840,0x00,0x01,1770,0,-273.2,97,23,2086,198,23,1004,0,0,0,0,0,0,687,SUCCESS
    31,2019-04-26 11:32:51,124.018,0x0000,34.6,11352,0x0001,-9183,4473,7488,-9137,29,65535,0,0,-1731,31.6,5,60,94,13200,4000,0x0282,0x40,1727,1745,4473,3077,0x08,0x0840,0x00,0x01,1766,0,-273.2,97,23,2090,198,23,1004,0,0,0,0,0,0,686,SUCCESS
    32,2019-04-26 11:32:55,128.019,0x0000,34.8,11352,0x0001,-9187,4462,7488,-9149,29,65535,0,0,-1733,31.7,5,60,94,13200,4000,0x0282,0x40,1717,1745,4462,3077,0x08,0x0840,0x00,0x01,1762,0,-273.2,97,23,2094,198,23,1004,0,0,0,0,0,0,685,SUCCESS
    33,2019-04-26 11:32:59,132.019,0x0000,34.9,11346,0x0001,-9190,4452,7488,-9158,29,65535,0,0,-1734,31.8,5,60,94,13200,4000,0x0282,0x40,1707,1745,4452,3077,0x08,0x0840,0x00,0x01,1758,0,-273.2,97,23,2098,198,23,1004,0,0,0,0,0,0,684,SUCCESS
    34,2019-04-26 11:33:03,136.020,0x0000,35.1,11346,0x0001,-9194,4442,7488,-9167,29,65535,0,0,-1735,31.9,5,60,94,13200,4000,0x0282,0x40,1697,1745,4442,3077,0x08,0x0840,0x00,0x01,1754,0,-273.2,97,23,2102,198,23,1004,0,0,0,0,0,0,683,SUCCESS
    35,2019-04-26 11:33:07,140.020,0x0000,35.2,11340,0x0001,-9197,4432,7488,-9174,29,65535,0,0,-1736,32.0,5,60,94,13200,4000,0x0282,0x40,1686,1745,4432,3077,0x08,0x0840,0x00,0x01,1750,0,-273.2,97,23,2106,198,23,1004,0,0,0,0,0,0,687,SUCCESS
    36,2019-04-26 11:33:11,144.021,0x0000,35.3,11334,0x0001,-9201,4422,7488,-9180,29,65535,0,0,-1737,32.1,5,60,94,13200,4000,0x0282,0x40,1676,1745,4422,3077,0x08,0x0840,0x00,0x01,1746,0,-273.2,97,23,2110,198,23,1004,0,0,0,0,0,0,680,SUCCESS
    37,2019-04-26 11:33:15,148.021,0x0000,35.5,11334,0x0001,-9204,4411,7488,-9186,29,65535,0,0,-1737,32.2,5,59,94,13200,4000,0x0282,0x40,1666,1745,4411,3077,0x08,0x0840,0x00,0x01,1742,0,-273.2,97,23,2114,198,23,1004,0,0,0,0,0,0,682,SUCCESS
    38,2019-04-26 11:33:19,152.022,0x0000,35.6,11328,0x0001,-9207,4401,7488,-9190,29,65535,0,0,-1737,32.3,5,59,94,13200,4000,0x0282,0x40,1656,1745,4401,3077,0x08,0x0840,0x00,0x01,1738,0,-273.2,97,23,2118,198,23,1004,0,0,0,0,0,0,682,SUCCESS
    39,2019-04-26 11:33:23,156.022,0x0000,35.7,11322,0x0001,-9209,4391,7488,-9195,29,65535,0,0,-1738,32.4,5,59,94,13200,4000,0x0282,0x40,1645,1745,4391,3077,0x08,0x0840,0x00,0x01,1734,0,-273.2,97,23,2122,198,23,1004,0,0,0,0,0,0,775,SUCCESS
    40,2019-04-26 11:33:27,160.023,0x0000,35.8,11322,0x0001,-9212,4381,7488,-9199,29,65535,0,0,-1738,32.5,5,59,94,13200,4000,0x0282,0x40,1635,1745,4381,3077,0x08,0x0840,0x00,0x01,1730,0,-273.2,97,23,2126,198,23,1004,0,0,0,0,0,0,686,SUCCESS
    41,2019-04-26 11:33:31,164.024,0x0000,35.9,11322,0x0001,-9215,4370,7488,-9202,28,65535,0,0,-1738,32.6,5,59,94,13200,4000,0x0282,0x40,1625,1745,4370,3077,0x08,0x0840,0x00,0x01,1726,0,-273.2,97,23,2130,198,23,1004,0,0,0,0,0,0,684,SUCCESS
    42,2019-04-26 11:33:35,168.024,0x0000,36.0,11316,0x0001,-9217,4360,7488,-9206,28,65535,0,0,-1738,32.7,5,59,94,13200,4000,0x0282,0x40,1615,1745,4360,3077,0x08,0x0840,0x00,0x01,1722,0,-273.2,97,23,2134,198,23,1004,0,0,0,0,0,0,714,SUCCESS
    43,2019-04-26 11:33:39,172.024,0x0000,36.1,11310,0x0001,-9220,4350,7488,-9209,28,65535,0,0,-1738,32.8,5,59,94,13200,4000,0x0282,0x40,1605,1745,4350,3077,0x08,0x0840,0x00,0x01,1718,0,-273.2,97,23,2138,198,23,1004,0,0,0,0,0,0,770,SUCCESS
    44,2019-04-26 11:33:43,176.025,0x0000,36.3,11310,0x0001,-9222,4342,7488,-9212,28,65535,0,0,-1738,32.9,5,58,94,13200,4000,0x0282,0x40,1594,1745,4340,3077,0x08,0x0840,0x00,0x01,1714,0,-273.2,97,23,2142,198,23,1004,0,0,0,0,0,0,719,SUCCESS
    45,2019-04-26 11:33:47,180.026,0x0000,36.4,11304,0x0001,-9223,4332,7488,-9215,28,65535,0,0,-1738,33.0,5,58,94,13200,4000,0x0282,0x40,1584,1745,4329,3077,0x08,0x0840,0x00,0x01,1710,0,-273.2,97,23,2146,198,23,1004,0,0,0,0,0,0,699,SUCCESS
    46,2019-04-26 11:33:51,184.027,0x0000,36.5,11298,0x0001,-9225,4322,7488,-9217,28,65535,0,0,-1738,33.1,5,58,94,13200,4000,0x0282,0x40,1574,1745,4319,3077,0x08,0x0840,0x00,0x01,1706,0,-273.2,97,23,2150,198,23,1004,0,0,0,0,0,0,714,SUCCESS
    47,2019-04-26 11:33:55,188.028,0x0000,36.6,11298,0x0001,-9227,4311,7488,-9220,28,65535,0,0,-1738,33.2,5,58,94,13200,4000,0x0282,0x40,1564,1745,4309,3077,0x08,0x0840,0x00,0x01,1702,0,-273.2,97,23,2154,198,23,1004,0,0,0,0,0,0,679,SUCCESS
    48,2019-04-26 11:33:59,192.028,0x0000,36.7,11292,0x0001,-9230,4301,7488,-9222,28,65535,0,0,-1737,33.2,5,58,94,13200,4000,0x0282,0x40,1553,1745,4299,3077,0x08,0x0840,0x00,0x01,1698,0,-273.2,97,23,2158,198,23,1004,0,0,0,0,0,0,760,SUCCESS
    49,2019-04-26 11:34:03,196.029,0x0000,36.8,11292,0x0001,-9232,4291,7488,-9224,28,65535,0,0,-1737,33.3,5,58,94,13200,4000,0x0282,0x40,1543,1745,4288,3077,0x08,0x0840,0x00,0x01,1694,0,-273.2,97,23,2162,198,23,1004,0,0,0,0,0,0,673,SUCCESS
    50,2019-04-26 11:34:07,200.030,0x0000,36.9,11286,0x0001,-9233,4281,7488,-9226,28,65535,0,0,-1737,33.4,5,58,94,13200,4000,0x0282,0x40,1533,1745,4278,3077,0x08,0x0840,0x00,0x01,1690,0,-273.2,97,23,2166,198,23,1004,0,0,0,0,0,0,706,SUCCESS
    51,2019-04-26 11:34:11,204.030,0x0000,37.0,11280,0x0001,-9235,4270,7488,-9228,28,65535,0,0,-1737,33.5,5,57,94,13200,4000,0x0282,0x40,1522,1745,4268,3077,0x08,0x0840,0x00,0x01,1686,0,-273.2,97,23,2170,198,23,1004,0,0,0,0,0,0,691,SUCCESS
    52,2019-04-26 11:34:15,208.031,0x0000,37.1,11280,0x0001,-9236,4260,7488,-9230,28,65535,0,0,-1737,33.6,5,57,94,13200,4000,0x0282,0x40,1512,1745,4258,3077,0x08,0x0840,0x00,0x01,1682,0,-273.2,97,23,2174,198,23,1004,0,0,0,0,0,0,695,SUCCESS
    53,2019-04-26 11:34:19,212.032,0x0000,37.2,11274,0x0001,-9238,4250,7488,-9232,28,65535,0,0,-1737,33.7,5,57,94,13200,4000,0x0282,0x40,1502,1745,4247,3077,0x08,0x0840,0x00,0x01,1678,0,-273.2,97,23,2178,198,23,1004,0,0,0,0,0,0,711,SUCCESS
    54,2019-04-26 11:34:23,216.032,0x0000,37.3,11268,0x0001,-9239,4240,7488,-9233,28,65535,0,0,-1736,33.7,5,57,94,13200,4000,0x0282,0x40,1492,1745,4237,3077,0x08,0x0840,0x00,0x01,1674,0,-273.2,97,23,2182,198,23,1004,0,0,0,0,0,0,693,SUCCESS
    55,2019-04-26 11:34:27,220.033,0x0000,37.3,11268,0x0001,-9241,4229,7488,-9235,27,65535,0,0,-1736,33.8,5,57,94,13200,4000,0x0282,0x40,1481,1745,4227,3077,0x08,0x0840,0x00,0x01,1670,0,-273.2,97,23,2186,198,23,1004,0,0,0,0,0,0,695,SUCCESS
    56,2019-04-26 11:34:31,224.033,0x0000,37.4,11262,0x0001,-9243,4219,7488,-9237,27,65535,0,0,-1736,33.9,5,57,94,13200,4000,0x0282,0x40,1471,1745,4217,3077,0x08,0x0840,0x00,0x01,1666,0,-273.2,97,23,2190,198,23,1004,0,0,0,0,0,0,690,SUCCESS
    57,2019-04-26 11:34:35,228.034,0x0000,37.5,11256,0x0001,-9244,4209,7488,-9238,27,65535,0,0,-1736,34.0,5,57,94,13200,4000,0x0282,0x40,1461,1745,4206,3077,0x08,0x0840,0x00,0x01,1662,0,-273.2,97,23,2194,198,23,1004,0,0,0,0,0,0,717,SUCCESS
    58,2019-04-26 11:34:39,232.035,0x0000,37.6,11256,0x0001,-9246,4199,7488,-9240,27,65535,0,0,-1735,34.1,5,57,94,13200,4000,0x0282,0x40,1451,1745,4196,3077,0x08,0x0840,0x00,0x01,1658,0,-273.2,97,23,2198,198,23,1004,0,0,0,0,0,0,723,SUCCESS
    59,2019-04-26 11:34:43,236.035,0x0000,37.7,11256,0x0001,-9247,4188,7488,-9242,27,65535,0,0,-1735,34.1,5,56,94,13200,4000,0x0282,0x40,1440,1745,4186,3077,0x08,0x0840,0x00,0x01,1654,0,-273.2,97,23,2202,198,23,1004,0,0,0,0,0,0,690,SUCCESS
    60,2019-04-26 11:34:47,240.036,0x0000,37.8,11250,0x0001,-9248,4178,7488,-9243,27,65535,0,0,-1735,34.2,5,56,94,13200,4000,0x0282,0x40,1430,1745,4175,3077,0x08,0x0840,0x00,0x01,1650,0,-273.2,97,23,2206,198,23,1004,0,0,0,0,0,0,693,SUCCESS
    61,2019-04-26 11:34:51,244.036,0x0000,37.9,11250,0x0001,-9249,4168,7488,-9245,27,65535,0,0,-1735,34.3,5,56,94,13200,4000,0x0282,0x40,1420,1745,4165,3077,0x08,0x0840,0x00,0x01,1646,0,-273.2,97,23,2210,198,23,1004,0,0,0,0,0,0,739,SUCCESS
    62,2019-04-26 11:34:55,248.037,0x0000,38.0,11244,0x0001,-9251,4157,7488,-9246,27,65535,0,0,-1734,34.3,5,56,94,13200,4000,0x0282,0x40,1409,1745,4155,3077,0x08,0x0840,0x00,0x01,1642,0,-273.2,97,23,2214,198,23,1004,0,0,0,0,0,0,682,SUCCESS
    63,2019-04-26 11:34:59,252.037,0x0000,38.0,11238,0x0001,-9251,4147,7488,-9247,27,65535,0,0,-1734,34.4,5,56,94,13200,4000,0x0282,0x40,1399,1745,4145,3077,0x08,0x0840,0x00,0x01,1638,0,-273.2,97,23,2218,198,23,1004,0,0,0,0,0,0,682,SUCCESS
    64,2019-04-26 11:35:03,256.038,0x0000,38.1,11238,0x0001,-9253,4137,7488,-9248,27,65535,0,0,-1734,34.5,5,56,94,13200,4000,0x0282,0x40,1389,1745,4134,3077,0x08,0x0840,0x00,0x01,1634,0,-273.2,97,23,2222,198,23,1004,0,0,0,0,0,0,682,SUCCESS
    65,2019-04-26 11:35:07,260.038,0x0000,38.2,11232,0x0001,-9253,4127,7488,-9250,27,65535,0,0,-1734,34.5,5,56,94,13200,4000,0x0282,0x40,1379,1745,4124,3077,0x08,0x0840,0x00,0x01,1630,0,-273.2,97,23,2226,198,23,1004,0,0,0,0,0,0,684,SUCCESS
    66,2019-04-26 11:35:11,264.039,0x0000,38.2,11226,0x0001,-9254,4116,7488,-9251,27,65535,0,0,-1733,34.6,5,55,94,13200,4000,0x0282,0x40,1368,1745,4114,3077,0x08,0x0840,0x00,0x01,1626,0,-273.2,97,23,2230,198,23,1004,0,0,0,0,0,0,684,SUCCESS
    67,2019-04-26 11:35:15,268.039,0x0000,38.3,11226,0x0001,-9256,4106,7488,-9252,27,65535,0,0,-1733,34.7,5,55,94,13200,4000,0x0282,0x40,1358,1745,4103,3077,0x08,0x0840,0x00,0x01,1622,0,-273.2,97,23,2234,198,23,1004,0,0,0,0,0,0,683,SUCCESS
    68,2019-04-26 11:35:19,272.040,0x0000,38.3,11220,0x0001,-9257,4096,7488,-9253,27,65535,0,0,-1733,34.7,5,55,94,13200,4000,0x0282,0x40,1348,1745,4093,3077,0x08,0x0840,0x00,0x01,1618,0,-273.2,97,23,2238,198,23,1004,0,0,0,0,0,0,684,SUCCESS
    69,2019-04-26 11:35:23,276.040,0x0000,38.4,11214,0x0001,-9257,4085,7488,-9254,26,65535,0,0,-1732,34.8,5,55,94,13200,4000,0x0282,0x40,1338,1745,4083,3077,0x08,0x0840,0x00,0x01,1614,0,-273.2,97,23,2242,198,23,1004,0,0,0,0,0,0,688,SUCCESS
    70,2019-04-26 11:35:27,280.041,0x0000,38.5,11214,0x0001,-9258,4075,7488,-9255,26,65535,0,0,-1732,34.9,5,55,94,13200,4000,0x0282,0x40,1330,1745,4073,3077,0x08,0x0840,0x00,0x01,1610,0,-273.2,97,23,2246,198,23,1004,0,0,0,0,0,0,683,SUCCESS
    71,2019-04-26 11:35:31,284.041,0x0000,38.5,11208,0x0001,-9259,4065,7488,-9256,26,65535,0,0,-1731,34.9,5,55,94,13200,4000,0x0282,0x40,1320,1745,4062,3077,0x08,0x0840,0x00,0x01,1606,0,-273.2,97,23,2250,198,23,1004,0,0,0,0,0,0,686,SUCCESS
    72,2019-04-26 11:35:35,288.042,0x0000,38.6,11208,0x0001,-9260,4055,7488,-9257,26,65535,0,0,-1731,35.0,5,55,94,13200,4000,0x0282,0x40,1309,1745,4052,3077,0x08,0x0840,0x00,0x01,1602,0,-273.2,97,23,2254,198,23,1004,0,0,0,0,0,0,682,SUCCESS
    73,2019-04-26 11:35:39,292.042,0x0000,38.7,11202,0x0001,-9261,4044,7488,-9258,26,65535,0,0,-1731,35.0,5,55,94,13200,4000,0x0282,0x40,1299,1745,4044,3077,0x08,0x0840,0x00,0x01,1598,0,-273.2,97,23,2258,198,23,1004,0,0,0,0,0,0,684,SUCCESS
    74,2019-04-26 11:35:43,296.043,0x0000,38.8,11202,0x0001,-9262,4034,7488,-9259,26,65535,0,0,-1730,35.1,5,54,94,13200,4000,0x0282,0x40,1289,1745,4034,3077,0x08,0x0840,0x00,0x01,1594,0,-273.2,97,23,2262,198,23,1004,0,0,0,0,0,0,683,SUCCESS
    75,2019-04-26 11:35:47,300.044,0x0000,38.8,11196,0x0001,-9262,4024,7488,-9259,26,65535,0,0,-1730,35.1,5,54,94,13200,4000,0x0282,0x40,1278,1745,4024,3077,0x08,0x0840,0x00,0x01,1590,0,-273.2,97,23,2266,198,23,1004,0,0,0,0,0,0,682,SUCCESS
    76,2019-04-26 11:35:51,304.045,0x0000,38.9,11196,0x0001,-9264,4013,7488,-9260,26,65535,0,0,-1729,35.2,5,54,94,13200,4000,0x0282,0x40,1268,1745,4013,3077,0x08,0x0840,0x00,0x01,1586,0,-273.2,97,23,2270,198,23,1004,0,0,0,0,0,0,681,SUCCESS
    77,2019-04-26 11:35:55,308.045,0x0000,38.9,11190,0x0001,-9264,4003,7488,-9261,26,65535,0,0,-1729,35.2,5,54,94,13200,4000,0x0282,0x40,1255,1745,4001,3077,0x08,0x0840,0x00,0x01,1582,0,-273.2,97,23,2274,198,23,1004,0,0,0,0,0,0,1380,SUCCESS
    78,2019-04-26 11:35:59,312.046,0x0000,39.0,11184,0x0001,-9264,3993,7488,-9262,26,65535,0,0,-1729,35.3,5,54,94,13200,4000,0x0282,0x40,1245,1745,3990,3077,0x08,0x0840,0x00,0x01,1578,0,-273.2,97,23,2278,198,23,1004,0,0,0,0,0,0,1214,SUCCESS
    79,2019-04-26 11:36:03,316.046,0x0000,39.0,11184,0x0001,-9265,3983,7488,-9263,26,65535,0,0,-1728,35.3,5,54,94,13200,4000,0x0282,0x40,1235,1745,3980,3077,0x08,0x0840,0x00,0x01,1574,0,-273.2,97,23,2282,198,23,1004,0,0,0,0,0,0,864,SUCCESS
    80,2019-04-26 11:36:07,320.047,0x0000,39.1,11178,0x0001,-9266,3972,7488,-9263,26,65535,0,0,-1728,35.4,5,54,94,13200,4000,0x0282,0x40,1227,1745,3972,3077,0x08,0x0840,0x00,0x01,1570,0,-273.2,97,23,2286,198,23,1004,0,0,0,0,0,0,678,SUCCESS
    81,2019-04-26 11:36:11,324.048,0x0000,39.1,11172,0x0001,-9267,3962,7488,-9264,26,65535,0,0,-1727,35.5,5,53,94,13200,4000,0x0282,0x40,1217,1745,3962,3077,0x08,0x0840,0x00,0x01,1567,0,-273.2,97,23,2290,198,23,1004,0,0,0,0,0,0,676,SUCCESS
    82,2019-04-26 11:36:15,328.048,0x0000,39.2,11172,0x0001,-9268,3952,7488,-9265,26,65535,0,0,-1727,35.5,5,53,94,13200,4000,0x0282,0x40,1206,1745,3952,3077,0x08,0x0840,0x00,0x01,1563,0,-273.2,97,23,2294,198,23,1004,0,0,0,0,0,0,677,SUCCESS
    83,2019-04-26 11:36:19,332.049,0x0000,39.2,11166,0x0001,-9268,3941,7488,-9266,26,65535,0,0,-1727,35.6,5,53,94,13200,4000,0x0282,0x40,1196,1745,3941,3077,0x08,0x0840,0x00,0x01,1559,0,-273.2,97,23,2298,198,23,1004,0,0,0,0,0,0,693,SUCCESS
    84,2019-04-26 11:36:23,336.050,0x0000,39.3,11160,0x0001,-9269,3931,7488,-9266,25,65535,0,0,-1726,35.6,5,53,94,13200,4000,0x0282,0x40,1186,1745,3931,3077,0x08,0x0840,0x00,0x01,1555,0,-273.2,97,23,2301,198,23,1004,0,0,0,0,0,0,689,SUCCESS
    85,2019-04-26 11:36:27,340.050,0x0000,39.3,11160,0x0001,-9269,3921,7488,-9267,25,65535,0,0,-1726,35.6,5,53,94,13200,4000,0x0282,0x40,1175,1745,3921,3077,0x08,0x0840,0x00,0x01,1551,0,-273.2,97,23,2305,198,23,1004,0,0,0,0,0,0,689,SUCCESS
    86,2019-04-26 11:36:31,344.051,0x0000,39.4,11154,0x0001,-9270,3910,7488,-9268,25,65535,0,0,-1725,35.7,5,53,94,13200,4000,0x0282,0x40,1165,1745,3910,3077,0x08,0x0840,0x00,0x01,1547,0,-273.2,97,23,2309,198,23,1004,0,0,0,0,0,0,689,SUCCESS
    87,2019-04-26 11:36:35,348.051,0x0000,39.5,11154,0x0001,-9271,3900,7488,-9268,25,65535,0,0,-1725,35.7,5,53,94,13200,4000,0x0282,0x40,1155,1745,3900,3077,0x08,0x0840,0x00,0x01,1543,0,-273.2,97,23,2313,198,23,1004,0,0,0,0,0,0,690,SUCCESS
    88,2019-04-26 11:36:39,352.052,0x0000,39.5,11154,0x0001,-9271,3890,7488,-9269,25,65535,0,0,-1724,35.8,5,52,94,13200,4000,0x0282,0x40,1144,1745,3890,3077,0x08,0x0840,0x00,0x01,1539,0,-273.2,97,23,2317,198,23,1004,0,0,0,0,0,0,692,SUCCESS
    89,2019-04-26 11:36:43,356.052,0x0000,39.5,11148,0x0001,-9272,3880,7488,-9270,25,65535,0,0,-1724,35.8,5,52,94,13200,4000,0x0282,0x40,1134,1745,3880,3077,0x08,0x0840,0x00,0x01,1535,0,-273.2,97,23,2321,198,23,1004,0,0,0,0,0,0,707,SUCCESS
    90,2019-04-26 11:36:47,360.052,0x0000,39.6,11142,0x0001,-9272,3869,7488,-9270,25,65535,0,0,-1724,35.9,5,52,94,13200,4000,0x0282,0x40,1124,1745,3869,3077,0x08,0x0840,0x00,0x01,1531,0,-273.2,97,23,2325,198,23,1004,0,0,0,0,0,0,694,SUCCESS
    91,2019-04-26 11:36:51,364.053,0x0000,39.6,11142,0x0001,-9273,3859,7488,-9271,25,65535,0,0,-1723,35.9,5,52,94,13200,4000,0x0282,0x40,1114,1745,3859,3077,0x08,0x0840,0x00,0x01,1527,0,-273.2,97,23,2329,198,23,1004,0,0,0,0,0,0,707,SUCCESS
    92,2019-04-26 11:36:55,368.054,0x0000,39.7,11136,0x0001,-9273,3849,7488,-9271,25,65535,0,0,-1723,36.0,5,52,94,13200,4000,0x0282,0x40,1103,1745,3849,3077,0x08,0x0840,0x00,0x01,1523,0,-273.2,97,23,2333,198,23,1004,0,0,0,0,0,0,721,SUCCESS
    93,2019-04-26 11:36:59,372.054,0x0000,39.7,11130,0x0001,-9274,3838,7488,-9272,25,65535,0,0,-1722,36.0,5,52,94,13200,4000,0x0282,0x40,1093,1745,3838,3077,0x08,0x0840,0x00,0x01,1519,0,-273.2,97,23,2337,198,23,1004,0,0,0,0,0,0,725,SUCCESS
    94,2019-04-26 11:37:03,376.055,0x0000,39.8,11130,0x0001,-9274,3828,7488,-9272,25,65535,0,0,-1722,36.0,5,52,94,13200,4000,0x0282,0x40,1083,1745,3828,3077,0x08,0x0840,0x00,0x01,1515,0,-273.2,97,23,2341,198,23,1004,0,0,0,0,0,0,690,SUCCESS
    95,2019-04-26 11:37:07,380.056,0x0000,39.8,11118,0x0001,-9275,3818,7488,-9273,25,65535,0,0,-1721,36.1,5,51,94,13200,4000,0x0282,0x40,1070,1745,3815,3077,0x08,0x0840,0x00,0x01,1510,0,-273.2,97,23,2346,198,23,1004,0,0,0,0,0,0,2031,SUCCESS
    96,2019-04-26 11:37:11,384.057,0x0000,39.9,11118,0x0001,-9275,3807,7488,-9273,25,65535,0,0,-1721,36.1,5,51,94,13200,4000,0x0282,0x40,1062,1745,3807,3077,0x08,0x0840,0x00,0x01,1507,0,-273.2,97,23,2349,198,23,1004,0,0,0,0,0,0,881,SUCCESS
    97,2019-04-26 11:37:15,388.058,0x0000,39.9,11118,0x0001,-9275,3797,7488,-9274,25,65535,0,0,-1720,36.2,5,51,94,13200,4000,0x0282,0x40,1052,1745,3797,3077,0x08,0x0840,0x00,0x01,1503,0,-273.2,97,23,2353,198,23,1004,0,0,0,0,0,0,765,SUCCESS
    98,2019-04-26 11:37:19,392.059,0x0000,39.9,11112,0x0001,-9276,3787,7488,-9274,25,65535,0,0,-1720,36.2,5,51,94,13200,4000,0x0282,0x40,1041,1745,3787,3077,0x08,0x0840,0x00,0x01,1499,0,-273.2,97,23,2357,198,23,1004,0,0,0,0,0,0,715,SUCCESS
    99,2019-04-26 11:37:23,396.059,0x0000,40.0,11112,0x0001,-9276,3776,7488,-9275,24,65535,0,0,-1719,36.2,5,51,94,13200,4000,0x0282,0x40,1031,1745,3776,3077,0x08,0x0840,0x00,0x01,1495,0,-273.2,97,23,2361,198,23,1004,0,0,0,0,0,0,734,SUCCESS
    100,2019-04-26 11:37:27,400.060,0x0000,40.0,11106,0x0001,-9277,3766,7488,-9275,24,65535,0,0,-1719,36.3,5,51,94,13200,4000,0x0282,0x40,1021,1745,3766,3077,0x08,0x0840,0x00,0x01,1491,0,-273.2,97,23,2365,198,23,1004,0,0,0,0,0,0,687,SUCCESS
    101,2019-04-26 11:37:31,404.060,0x0000,40.1,11100,0x0001,-9277,3756,7488,-9276,24,65535,0,0,-1718,36.3,5,51,94,13200,4000,0x0282,0x40,1011,1745,3756,3077,0x08,0x0840,0x00,0x01,1487,0,-273.2,97,23,2369,198,23,1004,0,0,0,0,0,0,703,SUCCESS
    102,2019-04-26 11:37:35,408.060,0x0000,40.1,11100,0x0001,-9277,3746,7488,-9276,24,65535,0,0,-1718,36.4,5,51,94,13200,4000,0x0282,0x40,1000,1745,3746,3077,0x08,0x0840,0x00,0x01,1483,0,-273.2,97,23,2373,198,23,1004,0,0,0,0,0,0,700,SUCCESS
    103,2019-04-26 11:37:39,412.061,0x0000,40.1,11094,0x0001,-9278,3735,7488,-9276,24,65535,0,0,-1717,36.4,5,50,94,13200,4000,0x0282,0x40,990,1745,3735,3077,0x08,0x0840,0x00,0x01,1479,0,-273.2,97,23,2377,198,23,1004,0,0,0,0,0,0,708,SUCCESS
    104,2019-04-26 11:37:43,416.061,0x0000,40.1,11088,0x0001,-9278,3728,7488,-9277,24,65535,0,0,-1717,36.4,5,50,94,13200,4000,0x0282,0x40,980,1745,3725,3077,0x08,0x0840,0x00,0x01,1475,0,-273.2,97,23,2381,198,23,1004,0,0,0,0,0,0,710,SUCCESS
    105,2019-04-26 11:37:47,420.062,0x0000,40.2,11088,0x0001,-9278,3717,7488,-9277,24,65535,0,0,-1716,36.4,5,50,94,13200,4000,0x0282,0x40,969,1745,3715,3077,0x08,0x0840,0x00,0x01,1471,0,-273.2,97,23,2385,198,23,1004,0,0,0,0,0,0,705,SUCCESS
    106,2019-04-26 11:37:51,424.062,0x0000,40.2,11082,0x0001,-9279,3707,7488,-9277,24,65535,0,0,-1716,36.5,5,50,94,13200,4000,0x0282,0x40,959,1745,3704,3077,0x08,0x0840,0x00,0x01,1467,0,-273.2,97,23,2389,198,23,1004,0,0,0,0,0,0,686,SUCCESS
    107,2019-04-26 11:37:55,428.062,0x0000,40.3,11076,0x0001,-9279,3697,7488,-9278,24,65535,0,0,-1715,36.5,5,50,94,13200,4000,0x0282,0x40,949,1745,3694,3077,0x08,0x0840,0x00,0x01,1463,0,-273.2,97,23,2393,198,23,1004,0,0,0,0,0,0,685,SUCCESS
    108,2019-04-26 11:37:59,432.063,0x0000,40.3,11076,0x0001,-9279,3686,7488,-9278,24,65535,0,0,-1715,36.5,5,50,94,13200,4000,0x0282,0x40,938,1745,3684,3077,0x08,0x0840,0x00,0x01,1459,0,-273.2,97,23,2397,198,23,1004,0,0,0,0,0,0,683,SUCCESS
    109,2019-04-26 11:38:03,436.064,0x0000,40.3,11070,0x0001,-9280,3676,7488,-9278,24,65535,0,0,-1714,36.6,5,50,94,13200,4000,0x0282,0x40,928,1745,3673,3077,0x08,0x0840,0x00,0x01,1455,0,-273.2,97,23,2401,198,23,1004,0,0,0,0,0,0,686,SUCCESS
    110,2019-04-26 11:38:07,440.065,0x0000,40.3,11064,0x0001,-9280,3666,7488,-9279,24,65535,0,0,-1713,36.6,5,49,94,13200,4000,0x0282,0x40,918,1745,3663,3077,0x08,0x0840,0x00,0x01,1451,0,-273.2,97,23,2405,198,23,1004,0,0,0,0,0,0,687,SUCCESS
    111,2019-04-26 11:38:11,444.065,0x0000,40.4,11064,0x0001,-9280,3655,7488,-9279,24,65535,0,0,-1713,36.7,5,49,94,13200,4000,0x0282,0x40,907,1745,3653,3077,0x08,0x0840,0x00,0x01,1447,0,-273.2,97,23,2409,198,23,1004,0,0,0,0,0,0,687,SUCCESS
    112,2019-04-26 11:38:15,448.066,0x0000,40.4,11058,0x0001,-9280,3645,7488,-9279,24,65535,0,0,-1712,36.7,5,49,94,13200,4000,0x0282,0x40,897,1745,3642,3077,0x08,0x0840,0x00,0x01,1443,0,-273.2,97,23,2413,198,23,1004,0,0,0,0,0,0,745,SUCCESS
    113,2019-04-26 11:38:19,452.066,0x0000,40.4,11058,0x0001,-9281,3635,7488,-9280,24,65535,0,0,-1712,36.7,5,49,94,13200,4000,0x0282,0x40,887,1745,3632,3077,0x08,0x0840,0x00,0x01,1439,0,-273.2,97,23,2417,198,23,1004,0,0,0,0,0,0,775,SUCCESS
    114,2019-04-26 11:38:23,456.067,0x0000,40.5,11052,0x0001,-9281,3624,7488,-9280,23,65535,0,0,-1711,36.7,5,49,94,13200,4000,0x0282,0x40,876,1745,3622,3077,0x08,0x0840,0x00,0x01,1435,0,-273.2,97,23,2421,198,23,1004,0,0,0,0,0,0,751,SUCCESS
    115,2019-04-26 11:38:27,460.067,0x0000,40.5,11046,0x0001,-9282,3614,7488,-9280,23,65535,0,0,-1711,36.8,5,49,94,13200,4000,0x0282,0x40,866,1745,3612,3077,0x08,0x0840,0x00,0x01,1431,0,-273.2,97,23,2425,198,23,1004,0,0,0,0,0,0,701,SUCCESS
    116,2019-04-26 11:38:31,464.068,0x0000,40.6,11046,0x0001,-9282,3604,7488,-9281,23,65535,0,0,-1710,36.8,5,49,94,13200,4000,0x0282,0x40,856,1745,3601,3077,0x08,0x0840,0x00,0x01,1427,0,-273.2,97,23,2429,198,23,1004,0,0,0,0,0,0,721,SUCCESS
    117,2019-04-26 11:38:35,468.069,0x0000,40.6,11040,0x0001,-9282,3593,7488,-9281,23,65535,0,0,-1710,36.8,5,48,94,13200,4000,0x0282,0x40,846,1745,3591,3077,0x08,0x0840,0x00,0x01,1423,0,-273.2,97,23,2433,198,23,1004,0,0,0,0,0,0,822,SUCCESS
    118,2019-04-26 11:38:39,472.070,0x0000,40.7,11034,0x0001,-9282,3583,7488,-9281,23,65535,0,0,-1709,36.9,5,48,94,13200,4000,0x0282,0x40,835,1745,3581,3077,0x08,0x0840,0x00,0x01,1419,0,-273.2,97,23,2437,198,23,1004,0,0,0,0,0,0,797,SUCCESS
    119,2019-04-26 11:38:43,476.071,0x0000,40.7,11034,0x0001,-9283,3573,7488,-9282,23,65535,0,0,-1709,36.9,5,48,94,13200,4000,0x0282,0x40,827,1745,3573,3077,0x08,0x0840,0x00,0x01,1415,0,-273.2,97,23,2441,198,23,1004,0,0,0,0,0,0,692,SUCCESS
    120,2019-04-26 11:38:47,480.072,0x0000,40.7,11028,0x0001,-9283,3563,7488,-9282,23,65535,0,0,-1708,36.9,5,48,94,13200,4000,0x0282,0x40,817,1745,3560,3077,0x08,0x0840,0x00,0x01,1411,0,-273.2,97,23,2445,198,23,1004,0,0,0,0,0,0,769,SUCCESS
    121,2019-04-26 11:38:51,484.072,0x0000,40.7,11022,0x0001,-9283,3552,7488,-9282,23,65535,0,0,-1707,37.0,5,48,94,13200,4000,0x0282,0x40,807,1745,3552,3077,0x08,0x0840,0x00,0x01,1407,0,-273.2,97,23,2449,198,23,1004,0,0,0,0,0,0,711,SUCCESS
    122,2019-04-26 11:38:55,488.073,0x0000,40.7,11022,0x0001,-9283,3542,7488,-9282,23,65535,0,0,-1707,37.0,5,48,94,13200,4000,0x0282,0x40,797,1745,3542,3077,0x08,0x0840,0x00,0x01,1403,0,-273.2,97,23,2453,198,23,1004,0,0,0,0,0,0,693,SUCCESS
    123,2019-04-26 11:38:59,492.073,0x0000,40.8,11016,0x0001,-9283,3532,7488,-9283,23,65535,0,0,-1706,37.0,5,48,94,13200,4000,0x0282,0x40,786,1745,3532,3077,0x08,0x0840,0x00,0x01,1399,0,-273.2,97,23,2457,198,23,1004,0,0,0,0,0,0,711,SUCCESS
    124,2019-04-26 11:39:03,496.074,0x0000,40.8,11016,0x0001,-9284,3521,7488,-9283,23,65535,0,0,-1706,37.0,5,48,94,13200,4000,0x0282,0x40,776,1745,3521,3077,0x08,0x0840,0x00,0x01,1395,0,-273.2,97,23,2461,198,23,1004,0,0,0,0,0,0,695,SUCCESS
    125,2019-04-26 11:39:07,500.074,0x0000,40.8,11004,0x0001,-9284,3511,7488,-9283,23,65535,0,0,-1705,37.1,5,47,94,13200,4000,0x0282,0x40,766,1745,3511,3077,0x08,0x0840,0x00,0x01,1392,0,-273.2,97,23,2465,198,23,1004,0,0,0,0,0,0,695,SUCCESS
    126,2019-04-26 11:39:11,504.075,0x0000,40.8,11004,0x0001,-9285,3501,7488,-9283,23,65535,0,0,-1705,37.1,5,47,94,13200,4000,0x0282,0x40,755,1745,3501,3077,0x08,0x0840,0x00,0x01,1388,0,-273.2,97,23,2469,198,23,1004,0,0,0,0,0,0,707,SUCCESS
    127,2019-04-26 11:39:15,508.076,0x0000,40.8,10998,0x0001,-9285,3490,7488,-9284,23,65535,0,0,-1704,37.1,5,47,94,13200,4000,0x0282,0x40,745,1745,3490,3077,0x08,0x0840,0x00,0x01,1384,0,-273.2,97,23,2472,198,23,1004,0,0,0,0,0,0,693,SUCCESS
    128,2019-04-26 11:39:19,512.077,0x0000,40.9,10992,0x0001,-9285,3480,7488,-9284,22,65535,0,0,-1704,37.1,5,47,94,13200,4000,0x0282,0x40,735,1745,3480,3077,0x08,0x0840,0x00,0x01,1380,0,-273.2,97,23,2476,198,23,1004,0,0,0,0,0,0,705,SUCCESS
    129,2019-04-26 11:39:23,516.078,0x0000,40.9,10992,0x0001,-9285,3470,7488,-9284,22,65535,0,0,-1703,37.2,5,47,94,13200,4000,0x0282,0x40,724,1745,3470,3077,0x08,0x0840,0x00,0x01,1376,0,-273.2,97,23,2480,198,23,1004,0,0,0,0,0,0,719,SUCCESS
    130,2019-04-26 11:39:27,520.078,0x0000,40.9,10986,0x0001,-9285,3459,7488,-9284,22,65535,0,0,-1702,37.2,5,47,94,13200,4000,0x0282,0x40,714,1745,3459,3077,0x08,0x0840,0x00,0x01,1372,0,-273.2,97,23,2484,198,23,1004,0,0,0,0,0,0,691,SUCCESS
    131,2019-04-26 11:39:31,524.079,0x0000,41.0,10980,0x0001,-9286,3450,7488,-9285,22,65535,0,0,-1702,37.2,5,47,94,13200,4000,0x02C2,0x40,704,1745,3450,8000,0x08,0x0840,0x00,0x01,1368,0,-273.2,97,23,2488,198,23,1004,0,0,0,0,0,0,704,SUCCESS
    132,2019-04-26 11:39:35,528.079,0x0000,41.0,10980,0x0001,-9286,3441,7488,-9285,22,65535,0,0,-1701,37.2,5,46,94,13200,4000,0x02C2,0x40,693,1745,3441,8000,0x08,0x0840,0x00,0x01,1364,0,-273.2,97,23,2492,198,23,1004,0,0,0,0,0,0,679,SUCCESS
    133,2019-04-26 11:39:39,532.080,0x0000,41.0,10974,0x0001,-9286,3432,7488,-9285,22,65535,0,0,-1700,37.3,5,46,94,13200,4000,0x02C2,0x40,683,1745,3432,8000,0x08,0x0840,0x00,0x01,1360,0,-273.2,97,23,2496,198,23,1004,0,0,0,0,0,0,684,SUCCESS
    134,2019-04-26 11:39:43,536.080,0x0000,41.0,10968,0x0001,-9286,3423,7488,-9285,22,65535,0,0,-1700,37.3,5,46,94,13200,4000,0x02C2,0x40,673,1745,3423,8000,0x08,0x0840,0x00,0x01,1356,0,-273.2,97,23,2500,198,23,1004,0,0,0,0,0,0,679,SUCCESS
    135,2019-04-26 11:39:47,540.081,0x0000,41.1,10968,0x0001,-9286,3414,7488,-9286,22,65535,0,0,-1699,37.3,5,46,94,13200,4000,0x02C2,0x40,662,1745,3414,8000,0x08,0x0840,0x00,0x01,1352,0,-273.2,97,23,2504,198,23,1004,0,0,0,0,0,0,689,SUCCESS
    136,2019-04-26 11:39:51,544.081,0x0000,41.1,10962,0x0001,-9286,3405,7488,-9286,22,65535,0,0,-1699,37.3,5,46,94,13200,4000,0x02C2,0x40,652,1745,3405,8000,0x08,0x0840,0x00,0x01,1348,0,-273.2,97,23,2508,198,23,1004,0,0,0,0,0,0,735,SUCCESS
    137,2019-04-26 11:39:55,548.082,0x0000,41.1,10956,0x0001,-9287,3396,7488,-9286,22,65535,0,0,-1698,37.4,5,46,94,13200,4000,0x02C2,0x40,642,1745,3396,8000,0x08,0x0840,0x00,0x01,1344,0,-273.2,97,23,2512,198,23,1004,0,0,0,0,0,0,751,SUCCESS
    138,2019-04-26 11:39:59,552.082,0x0000,41.1,10950,0x0001,-9287,3388,7488,-9286,22,65535,0,0,-1698,37.4,5,46,94,13200,4000,0x02C2,0x40,631,1745,3388,8000,0x08,0x0840,0x00,0x01,1340,0,-273.2,97,23,2516,198,23,1004,0,0,0,0,0,0,737,SUCCESS
    139,2019-04-26 11:40:03,556.083,0x0000,41.1,10950,0x0001,-9287,3379,7488,-9287,22,65535,0,0,-1697,37.4,5,46,94,13200,4000,0x02C2,0x40,621,1745,3379,8000,0x08,0x0840,0x00,0x01,1336,0,-273.2,97,23,2520,198,23,1004,0,0,0,0,0,0,733,SUCCESS
    140,2019-04-26 11:40:07,560.084,0x0000,41.1,10944,0x0001,-9287,3370,7488,-9287,22,65535,0,0,-1696,37.4,5,46,94,13200,4000,0x02C2,0x40,611,1745,3370,8000,0x08,0x0840,0x00,0x01,1332,0,-273.2,97,23,2524,198,23,1004,0,0,0,0,0,0,715,SUCCESS
    141,2019-04-26 11:40:11,564.084,0x0000,41.2,10938,0x0001,-9287,3361,7488,-9287,22,65535,0,0,-1696,37.4,5,45,94,13200,4000,0x02C2,0x40,600,1745,3361,8000,0x08,0x0840,0x00,0x01,1328,0,-273.2,97,23,2528,198,23,1004,0,0,0,0,0,0,716,SUCCESS
    142,2019-04-26 11:40:15,568.085,0x0000,41.2,10938,0x0001,-9288,3352,7488,-9287,22,65535,0,0,-1695,37.4,5,45,94,13200,4000,0x02C2,0x40,590,1745,3352,8000,0x08,0x0840,0x00,0x01,1324,0,-273.2,97,23,2532,198,23,1004,0,0,0,0,0,0,716,SUCCESS
    143,2019-04-26 11:40:19,572.085,0x0000,41.2,10932,0x0001,-9288,3343,7488,-9287,22,65535,0,0,-1694,37.5,5,45,94,13200,4000,0x02C2,0x40,580,1745,3343,8000,0x08,0x0840,0x00,0x01,1320,0,-273.2,97,23,2536,198,23,1004,0,0,0,0,0,0,729,SUCCESS
    144,2019-04-26 11:40:23,576.086,0x0000,41.3,10926,0x0001,-9288,3334,7488,-9287,22,65535,0,0,-1694,37.5,5,45,94,13200,4000,0x02C2,0x40,570,1745,3334,8000,0x08,0x0840,0x00,0x01,1316,0,-273.2,97,23,2540,198,23,1004,0,0,0,0,0,0,693,SUCCESS
    145,2019-04-26 11:40:27,580.087,0x0000,41.3,10926,0x0001,-9288,3325,7488,-9288,21,65535,0,0,-1693,37.5,5,45,94,13200,4000,0x02C2,0x40,559,1745,3325,8000,0x08,0x0840,0x00,0x01,1312,0,-273.2,97,23,2544,198,23,1004,0,0,0,0,0,0,725,SUCCESS
    146,2019-04-26 11:40:31,584.087,0x0000,41.3,10920,0x0001,-9288,3316,7488,-9288,21,65535,0,0,-1693,37.5,5,45,94,13200,4000,0x02C2,0x40,549,1745,3316,8000,0x08,0x0840,0x00,0x01,1308,0,-273.2,97,23,2548,198,23,1004,0,0,0,0,0,0,721,SUCCESS
    147,2019-04-26 11:40:35,588.087,0x0000,41.3,10920,0x0001,-9288,3310,7488,-9288,21,65535,0,0,-1692,37.6,5,45,94,13200,4000,0x02C2,0x40,539,1745,3308,8000,0x08,0x0840,0x00,0x01,1304,0,-273.2,97,23,2552,198,23,1004,0,0,0,0,0,0,713,SUCCESS
    148,2019-04-26 11:40:39,592.088,0x0000,41.3,10914,0x0001,-9288,3301,7488,-9288,21,65535,0,0,-1691,37.6,5,45,94,13200,4000,0x02C2,0x40,528,1745,3299,8000,0x08,0x0840,0x00,0x01,1300,0,-273.2,97,23,2556,198,23,1004,0,0,0,0,0,0,694,SUCCESS
    149,2019-04-26 11:40:43,596.088,0x0000,41.3,10908,0x0001,-9289,3292,7488,-9288,21,65535,0,0,-1691,37.6,5,44,94,13200,4000,0x02C2,0x40,518,1745,3290,8000,0x08,0x0840,0x00,0x01,1296,0,-273.2,97,23,2560,198,23,1004,0,0,0,0,0,0,688,SUCCESS
    150,2019-04-26 11:40:47,600.088,0x0000,41.3,10902,0x0001,-9289,3283,7488,-9289,21,65535,0,0,-1690,37.6,5,44,94,13200,4000,0x02C2,0x40,508,1745,3281,8000,0x08,0x0840,0x00,0x01,1292,0,-273.2,97,23,2564,198,23,1004,0,0,0,0,0,0,736,SUCCESS
    151,2019-04-26 11:40:51,604.089,0x0000,41.3,10902,0x0001,-9289,3274,7488,-9289,21,65535,0,0,-1690,37.6,5,44,94,13200,4000,0x02C2,0x40,497,1745,3272,8000,0x08,0x0840,0x00,0x01,1288,0,-273.2,97,23,2568,198,23,1004,0,0,0,0,0,0,696,SUCCESS
    152,2019-04-26 11:40:55,608.090,0x0000,41.4,10896,0x0001,-9289,3265,7488,-9289,21,65535,0,0,-1689,37.6,5,44,94,13200,4000,0x02C2,0x40,487,1745,3263,8000,0x08,0x0840,0x00,0x01,1284,0,-273.2,97,23,2572,198,23,1004,0,0,0,0,0,0,720,SUCCESS
    153,2019-04-26 11:40:59,612.091,0x0000,41.4,10890,0x0001,-9289,3256,7488,-9289,21,65535,0,0,-1689,37.7,5,44,94,13200,4000,0x02C2,0x40,477,1745,3254,8000,0x08,0x0840,0x00,0x01,1280,0,-273.2,97,23,2576,198,23,1004,0,0,0,0,0,0,749,SUCCESS
    154,2019-04-26 11:41:03,616.091,0x0000,41.4,10884,0x0001,-9289,3248,7488,-9289,21,65535,0,0,-1688,37.7,5,44,94,13200,4000,0x02C2,0x40,466,1745,3245,8000,0x08,0x0840,0x00,0x01,1276,0,-273.2,97,23,2580,198,23,1004,0,0,0,0,0,0,1028,SUCCESS
    155,2019-04-26 11:41:07,620.091,0x0000,41.4,10884,0x0001,-9289,3239,7488,-9289,21,65535,0,0,-1687,37.7,5,44,94,13200,4000,0x02C2,0x40,456,1745,3236,8000,0x08,0x0840,0x00,0x01,1272,0,-273.2,97,23,2584,198,23,1004,0,0,0,0,0,0,991,SUCCESS
    156,2019-04-26 11:41:11,624.092,0x0000,41.4,10878,0x0001,-9290,3230,7488,-9289,21,65535,0,0,-1686,37.7,5,44,94,13200,4000,0x02C2,0x40,446,1745,3228,8000,0x08,0x0840,0x00,0x01,1268,0,-273.2,97,23,2588,198,23,1004,0,0,0,0,0,0,1138,SUCCESS
    157,2019-04-26 11:41:15,628.093,0x0000,41.4,10878,0x0001,-9290,3221,7488,-9289,21,65535,0,0,-1686,37.7,5,44,94,13200,4000,0x02C2,0x40,435,1745,3219,8000,0x08,0x0840,0x00,0x01,1264,0,-273.2,97,23,2592,198,23,1004,0,0,0,0,0,0,755,SUCCESS
    158,2019-04-26 11:41:19,632.093,0x0000,41.5,10872,0x0001,-9290,3212,7488,-9289,21,65535,0,0,-1685,37.7,5,43,94,13200,4000,0x02C2,0x40,425,1745,3210,8000,0x08,0x0840,0x00,0x01,1260,0,-273.2,97,23,2596,198,23,1004,0,0,0,0,0,0,751,SUCCESS
    159,2019-04-26 11:41:23,636.094,0x0000,41.5,10866,0x0001,-9290,3203,7488,-9290,21,65535,0,0,-1684,37.8,5,43,94,13200,4000,0x02C2,0x40,415,1745,3201,8000,0x08,0x0840,0x00,0x01,1256,0,-273.2,97,23,2600,198,23,1004,0,0,0,0,0,0,735,SUCCESS
    160,2019-04-26 11:41:27,640.095,0x0000,41.5,10860,0x0001,-9290,3194,7488,-9290,21,65535,0,0,-1684,37.8,5,43,94,13200,4000,0x02C2,0x40,404,1745,3192,8000,0x08,0x0840,0x00,0x01,1252,0,-273.2,97,23,2604,198,23,1004,0,0,0,0,0,0,840,SUCCESS
    161,2019-04-26 11:41:31,644.095,0x0000,41.5,10854,0x0001,-9290,3185,7488,-9290,21,65535,0,0,-1683,37.8,5,43,94,13200,4000,0x02C2,0x40,397,1745,3183,8000,0x08,0x0840,0x00,0x01,1248,0,-273.2,97,23,2608,198,23,1004,0,0,0,0,0,0,750,SUCCESS
    162,2019-04-26 11:41:35,648.095,0x0000,41.5,10854,0x0001,-9290,3176,7488,-9290,21,65535,0,0,-1683,37.8,5,43,94,13200,4000,0x02C2,0x40,386,1745,3176,8000,0x08,0x0840,0x00,0x01,1244,0,-273.2,97,23,2612,198,23,1004,0,0,0,0,0,0,716,SUCCESS
    163,2019-04-26 11:41:39,652.096,0x0000,41.5,10848,0x0001,-9290,3168,7488,-9290,20,65535,0,0,-1682,37.8,5,43,94,13200,4000,0x02C2,0x40,376,1745,3168,8000,0x08,0x0840,0x00,0x01,1240,0,-273.2,97,23,2616,198,23,1004,0,0,0,0,0,0,729,SUCCESS
    164,2019-04-26 11:41:43,656.097,0x0000,41.5,10842,0x0001,-9291,3159,7488,-9290,20,65535,0,0,-1681,37.9,5,43,94,13200,4000,0x02C2,0x40,366,1745,3159,8000,0x08,0x0840,0x00,0x01,1236,0,-273.2,97,23,2620,198,23,1004,0,0,0,0,0,0,713,SUCCESS
    165,2019-04-26 11:41:47,660.098,0x0000,41.5,10836,0x0001,-9291,3150,7488,-9290,20,65535,0,0,-1681,37.9,5,43,94,13200,4000,0x02C2,0x40,355,1745,3150,8000,0x08,0x0840,0x00,0x01,1232,0,-273.2,97,23,2624,198,23,1004,0,0,0,0,0,0,717,SUCCESS
    166,2019-04-26 11:41:51,664.098,0x0000,41.6,10830,0x0001,-9291,3141,7488,-9290,20,65535,0,0,-1680,37.9,5,42,94,13200,4000,0x02C2,0x40,345,1745,3141,8000,0x08,0x0840,0x00,0x01,1228,0,-273.2,97,23,2628,198,23,1004,0,0,0,0,0,0,715,SUCCESS
    167,2019-04-26 11:41:55,668.099,0x0000,41.6,10830,0x0001,-9291,3132,7488,-9291,20,65535,0,0,-1679,37.9,5,42,94,13200,4000,0x02C2,0x40,335,1745,3132,8000,0x08,0x0840,0x00,0x01,1224,0,-273.2,97,23,2632,198,23,1004,0,0,0,0,0,0,730,SUCCESS
    168,2019-04-26 11:41:59,672.100,0x0000,41.7,10824,0x0001,-9291,3123,7488,-9291,20,65535,0,0,-1678,37.9,5,42,94,13200,4000,0x02C2,0x40,324,1745,3123,8000,0x08,0x0840,0x00,0x01,1221,0,-273.2,97,23,2636,198,23,1004,0,0,0,0,0,0,706,SUCCESS
    169,2019-04-26 11:42:03,676.100,0x0000,41.7,10824,0x0001,-9292,3114,7488,-9291,20,65535,0,0,-1678,37.9,5,42,94,13200,4000,0x02C2,0x40,314,1745,3114,8000,0x08,0x0840,0x00,0x01,1217,0,-273.2,97,23,2639,198,23,1004,0,0,0,0,0,0,692,SUCCESS
    170,2019-04-26 11:42:07,680.101,0x0000,41.7,10812,0x0001,-9292,3105,7488,-9291,20,65535,0,0,-1677,37.9,5,42,94,13200,4000,0x02C2,0x40,304,1745,3105,8000,0x08,0x0840,0x00,0x01,1213,0,-273.2,97,23,2644,198,23,1004,0,0,0,0,0,0,722,SUCCESS
    171,2019-04-26 11:42:11,684.101,0x0000,41.7,10812,0x0001,-9292,3096,7488,-9291,20,65535,0,0,-1676,37.9,5,42,94,13200,4000,0x02C2,0x40,293,1745,3096,8000,0x08,0x0840,0x00,0x01,1209,0,-273.2,97,23,2647,198,23,1004,0,0,0,0,0,0,677,SUCCESS
    172,2019-04-26 11:42:15,688.102,0x0000,41.7,10806,0x0001,-9292,3088,7488,-9292,20,65535,0,0,-1676,38.0,5,42,94,13200,4000,0x02C2,0x40,283,1745,3088,8000,0x08,0x0840,0x00,0x01,1205,0,-273.2,97,23,2651,198,23,1004,0,0,0,0,0,0,691,SUCCESS
    173,2019-04-26 11:42:19,692.102,0x0000,41.7,10800,0x0001,-9292,3079,7488,-9292,20,65535,0,0,-1675,38.0,5,42,94,13200,4000,0x02C2,0x40,273,1745,3079,8000,0x08,0x0840,0x00,0x01,1201,0,-273.2,97,23,2655,198,23,1004,0,0,0,0,0,0,702,SUCCESS
    174,2019-04-26 11:42:23,696.103,0x0000,41.7,10800,0x0001,-9292,3070,7488,-9292,20,65535,0,0,-1675,38.0,5,41,94,13200,4000,0x02C2,0x40,262,1745,3070,8000,0x08,0x0840,0x00,0x01,1197,0,-273.2,97,23,2659,198,23,1004,0,0,0,0,0,0,706,SUCCESS
    175,2019-04-26 11:42:27,700.103,0x0000,41.7,10788,0x0001,-9292,3061,7488,-9292,20,65535,0,0,-1674,38.0,5,41,94,13200,4000,0x02C2,0x40,252,1745,3061,8000,0x08,0x0840,0x00,0x01,1193,0,-273.2,97,23,2664,198,23,1004,0,0,0,0,0,0,870,SUCCESS
    176,2019-04-26 11:42:31,704.103,0x0000,41.7,10788,0x0001,-9292,3052,7488,-9292,20,65535,0,0,-1673,38.0,5,41,94,13200,4000,0x02C2,0x40,242,1745,3052,8000,0x08,0x0840,0x00,0x01,1189,0,-273.2,97,23,2667,198,23,1004,0,0,0,0,0,0,694,SUCCESS
    177,2019-04-26 11:42:35,708.104,0x0000,41.7,10782,0x0001,-9292,3043,7488,-9292,20,65535,0,0,-1673,38.0,5,41,94,13200,4000,0x02C2,0x40,231,1745,3043,8000,0x08,0x0840,0x00,0x01,1185,0,-273.2,97,23,2671,198,23,1004,0,0,0,0,0,0,706,SUCCESS
    178,2019-04-26 11:42:39,712.105,0x0000,41.8,10782,0x0001,-9292,3034,7488,-9292,20,65535,0,0,-1672,38.0,5,41,94,13200,4000,0x02C2,0x40,221,1745,3034,8000,0x08,0x0840,0x00,0x01,1181,0,-273.2,97,23,2675,198,23,1004,0,0,0,0,0,0,705,SUCCESS
    179,2019-04-26 11:42:43,716.105,0x0000,41.8,10770,0x0001,-9292,3025,7488,-9292,20,65535,0,0,-1671,38.1,5,41,94,13200,4000,0x02C2,0x40,211,1745,3025,8000,0x08,0x0840,0x00,0x01,1177,0,-273.2,97,23,2679,198,23,1004,0,0,0,0,0,0,685,SUCCESS
    180,2019-04-26 11:42:47,720.106,0x0000,41.8,10770,0x0001,-9292,3016,7488,-9292,19,65535,0,0,-1670,38.1,5,41,94,13200,4000,0x02C2,0x40,200,1745,3016,8000,0x08,0x0840,0x00,0x01,1173,0,-273.2,97,23,2683,198,23,1004,0,0,0,0,0,0,704,SUCCESS
    181,2019-04-26 11:42:51,724.106,0x0000,41.9,10764,0x0001,-9292,3008,7488,-9292,19,65535,0,0,-1670,38.1,5,41,94,13200,4000,0x02C2,0x40,190,1746,3008,8000,0x08,0x0840,0x00,0x01,1169,0,-273.2,97,23,2687,198,23,1004,0,0,0,0,0,0,740,SUCCESS
    182,2019-04-26 11:42:55,728.107,0x0000,41.8,10758,0x0001,-9292,2999,7488,-9292,19,65535,0,0,-1669,38.1,5,41,94,13200,4000,0x02C2,0x40,180,1745,2999,8000,0x08,0x0840,0x00,0x01,1165,0,-273.2,97,23,2691,198,23,1004,0,0,0,0,0,0,736,SUCCESS
    183,2019-04-26 11:42:59,732.107,0x0000,41.8,10758,0x0001,-9292,2990,7488,-9292,19,65535,0,0,-1668,38.1,5,40,94,13200,4000,0x02C2,0x40,169,1745,2990,8000,0x08,0x0840,0x00,0x01,1161,0,-273.2,97,23,2695,198,23,1004,0,0,0,0,0,0,736,SUCCESS
    184,2019-04-26 11:43:03,736.107,0x0000,41.8,10746,0x0001,-9293,2981,7488,-9292,19,65535,0,0,-1667,38.1,5,40,94,13200,4000,0x02C2,0x40,159,1745,2981,8000,0x08,0x0840,0x00,0x01,1157,0,-273.2,97,23,2699,198,23,1004,0,0,0,0,0,0,748,SUCCESS
    185,2019-04-26 11:43:07,740.108,0x0000,41.8,10746,0x0001,-9293,2972,7488,-9292,19,65535,0,0,-1667,38.2,5,40,94,13200,4000,0x02C2,0x40,149,1745,2972,8000,0x08,0x0840,0x00,0x01,1153,0,-273.2,97,23,2703,198,23,1004,0,0,0,0,0,0,745,SUCCESS
    186,2019-04-26 11:43:11,744.108,0x0000,41.8,10740,0x0001,-9293,2963,7488,-9293,19,65535,0,0,-1666,38.2,5,40,94,13200,4000,0x02C2,0x40,139,1745,2963,8000,0x08,0x0840,0x00,0x01,1149,0,-273.2,97,23,2707,198,23,1004,0,0,0,0,0,0,762,SUCCESS
    187,2019-04-26 11:43:15,748.109,0x0000,41.9,10734,0x0001,-9293,2954,7488,-9293,19,65535,0,0,-1665,38.1,5,40,94,13200,4000,0x02C2,0x40,128,1746,2954,8000,0x08,0x0840,0x00,0x01,1145,0,-273.2,97,23,2711,198,23,1004,0,0,0,0,0,0,727,SUCCESS
    188,2019-04-26 11:43:19,752.110,0x0000,41.9,10728,0x0001,-9293,2945,7488,-9293,19,65535,0,0,-1665,38.1,5,40,94,13200,4000,0x02C2,0x40,118,1746,2945,8000,0x08,0x0840,0x00,0x01,1141,0,-273.2,97,23,2715,198,23,1004,0,0,0,0,0,0,729,SUCCESS
    189,2019-04-26 11:43:23,756.110,0x0000,41.9,10728,0x0001,-9293,2936,7488,-9293,19,65535,0,0,-1664,38.1,5,40,94,13200,4000,0x02C2,0x40,108,1746,2936,8000,0x08,0x0840,0x00,0x01,1137,0,-273.2,97,23,2719,198,23,1004,0,0,0,0,0,0,743,SUCCESS
    190,2019-04-26 11:43:27,760.111,0x0000,42.0,10722,0x0001,-9293,2928,7488,-9293,19,65535,0,0,-1663,38.1,5,40,94,13200,4000,0x02C2,0x40,97,1745,2928,8000,0x08,0x0840,0x00,0x01,1133,0,-273.2,97,23,2723,198,23,1004,0,0,0,0,0,0,818,SUCCESS
    191,2019-04-26 11:43:31,764.112,0x0000,42.0,10716,0x0001,-9293,2919,7488,-9293,19,65535,0,0,-1663,38.2,5,39,94,13200,4000,0x02C2,0x40,87,1745,2919,8000,0x08,0x0840,0x00,0x01,1129,0,-273.2,97,23,2727,198,23,1004,0,0,0,0,0,0,742,SUCCESS
    192,2019-04-26 11:43:35,768.112,0x0000,42.0,10716,0x0001,-9294,2912,7488,-9293,19,65535,0,0,-1662,38.2,5,39,94,13200,4000,0x02C2,0x40,77,1745,2910,8000,0x08,0x0840,0x00,0x01,1125,0,-273.2,97,23,2731,198,23,1004,0,0,0,0,0,0,727,SUCCESS
    193,2019-04-26 11:43:39,772.113,0x0000,42.0,10704,0x0001,-9294,2903,7488,-9293,19,65535,0,0,-1661,38.2,5,39,94,13200,4000,0x02C2,0x40,66,1745,2901,8000,0x08,0x0840,0x00,0x01,1121,0,-273.2,97,23,2735,198,23,1004,0,0,0,0,0,0,706,SUCCESS
    194,2019-04-26 11:43:43,776.114,0x0000,41.9,10704,0x0001,-9294,2894,7488,-9294,19,65535,0,0,-1660,38.2,5,39,94,13200,4000,0x02C2,0x40,56,1745,2892,8000,0x08,0x0840,0x00,0x01,1117,0,-273.2,97,23,2739,198,23,1004,0,0,0,0,0,0,723,SUCCESS
    195,2019-04-26 11:43:47,780.115,0x0000,41.9,10698,0x0001,-9293,2885,7488,-9294,19,65535,0,0,-1660,38.2,5,39,94,13200,4000,0x02C2,0x40,46,1745,2883,8000,0x08,0x0840,0x00,0x01,1113,0,-273.2,97,23,2743,198,23,1004,0,0,0,0,0,0,690,SUCCESS
    196,2019-04-26 11:43:51,784.116,0x0000,41.9,10692,0x0001,-9294,2876,7488,-9294,19,65535,0,0,-1659,38.3,5,39,94,13200,4000,0x02C2,0x40,35,1746,2874,8000,0x08,0x0840,0x00,0x01,1109,0,-273.2,97,23,2747,198,23,1004,0,0,0,0,0,0,705,SUCCESS
    197,2019-04-26 11:43:55,788.117,0x0000,41.9,10686,0x0001,-9293,2868,7488,-9294,19,65535,0,0,-1658,38.3,5,39,94,13200,4000,0x02C2,0x40,25,1745,2865,8000,0x08,0x0840,0x00,0x01,1105,0,-273.2,97,23,2751,198,23,1004,0,0,0,0,0,0,687,SUCCESS
    198,2019-04-26 11:43:59,792.118,0x0000,42.0,10686,0x0001,-9294,2859,7488,-9294,18,65535,0,0,-1657,38.3,5,39,94,13200,4000,0x02C2,0x40,15,1745,2856,8000,0x08,0x0840,0x00,0x01,1101,0,-273.2,97,23,2755,198,23,1004,0,0,0,0,0,0,701,SUCCESS
    199,2019-04-26 11:44:03,796.119,0x0000,42.0,10680,0x0001,-9294,2850,7488,-9294,18,65535,0,0,-1657,38.3,5,39,94,13200,4000,0x02C2,0x40,4,1745,2848,8000,0x08,0x0840,0x00,0x01,1097,0,-273.2,97,23,2759,198,23,1004,0,0,0,0,0,0,688,SUCCESS
    200,2019-04-26 11:44:07,800.119,0x0000,42.0,10674,0x0001,-9294,2841,7488,-9294,18,65535,0,0,-1656,38.3,5,38,94,13200,4000,0x02C2,0x40,0,1745,2839,8000,0x08,0x0840,0x00,0x01,1093,0,-273.2,97,23,2763,198,23,1004,0,0,0,0,0,0,687,SUCCESS
    201,2019-04-26 11:44:11,804.120,0x0000,42.0,10668,0x0001,-9294,2832,7488,-9294,18,65535,0,0,-1655,38.3,5,38,94,13200,4000,0x02C2,0x40,0,1745,2830,8000,0x08,0x0840,0x00,0x01,1089,0,-273.2,97,23,2767,198,23,1004,0,0,0,0,0,0,684,SUCCESS
    202,2019-04-26 11:44:15,808.121,0x0000,42.0,10662,0x0001,-9294,2823,7488,-9294,18,65535,0,0,-1654,38.3,5,38,94,13200,4000,0x02C2,0x40,0,1745,2821,8000,0x08,0x0840,0x00,0x01,1085,0,-273.2,97,23,2771,198,23,1004,0,0,0,0,0,0,700,SUCCESS
    203,2019-04-26 11:44:19,812.122,0x0000,42.0,10656,0x0001,-9294,2814,7488,-9294,18,65535,0,0,-1654,38.3,5,38,94,13200,4000,0x02C2,0x40,0,1745,2812,8000,0x08,0x0840,0x00,0x01,1081,0,-273.2,97,23,2775,198,23,1004,0,0,0,0,0,0,685,SUCCESS
    204,2019-04-26 11:44:23,816.122,0x0000,42.0,10650,0x0001,-9294,2805,7488,-9294,18,65535,0,0,-1653,38.3,5,38,94,13200,4000,0x02C2,0x40,0,1745,2803,8000,0x08,0x0840,0x00,0x01,1077,0,-273.2,97,23,2779,198,23,1004,0,0,0,0,0,0,699,SUCCESS
    205,2019-04-26 11:44:27,820.123,0x0000,42.0,10644,0x0001,-9294,2796,7488,-9294,18,65535,0,0,-1652,38.3,5,38,94,13200,4000,0x02C2,0x40,0,1745,2794,8000,0x08,0x0840,0x00,0x01,1073,0,-273.2,97,23,2783,198,23,1004,0,0,0,0,0,0,695,SUCCESS
    206,2019-04-26 11:44:31,824.124,0x0000,42.0,10638,0x0001,-9294,2788,7488,-9294,18,65535,0,0,-1651,38.3,5,38,94,13200,4000,0x02C2,0x40,0,1745,2785,8000,0x08,0x0840,0x00,0x01,1069,0,-273.2,97,23,2787,198,23,1004,0,0,0,0,0,0,700,SUCCESS
    207,2019-04-26 11:44:35,828.124,0x0000,42.0,10638,0x0001,-9294,2779,7488,-9294,18,65535,0,0,-1650,38.3,5,38,94,13200,4000,0x02C2,0x40,0,1745,2776,8000,0x08,0x0840,0x00,0x01,1065,0,-273.2,97,23,2791,198,23,1004,0,0,0,0,0,0,681,SUCCESS
    208,2019-04-26 11:44:39,832.125,0x0000,42.0,10632,0x0001,-9294,2770,7488,-9294,18,65535,0,0,-1650,38.4,5,37,94,13200,4000,0x02C2,0x40,0,1745,2768,8000,0x08,0x0840,0x00,0x01,1061,0,-273.2,97,23,2795,198,23,1004,0,0,0,0,0,0,714,SUCCESS
    209,2019-04-26 11:44:43,836.126,0x0000,42.0,10626,0x0001,-9294,2761,7488,-9294,18,65535,0,0,-1649,38.3,5,37,94,13200,4000,0x02C2,0x40,0,1745,2761,8000,0x08,0x0840,0x00,0x01,1057,0,-273.2,97,23,2799,198,23,1004,0,0,0,0,0,0,697,SUCCESS
    210,2019-04-26 11:44:47,840.126,0x0000,42.0,10620,0x0001,-9294,2752,7488,-9294,18,65535,0,0,-1648,38.4,5,37,94,13200,4000,0x02C2,0x40,0,1745,2752,8000,0x08,0x0840,0x00,0x01,1053,0,-273.2,97,23,2803,198,23,1004,0,0,0,0,0,0,696,SUCCESS
    211,2019-04-26 11:44:51,844.127,0x0000,42.1,10614,0x0001,-9294,2743,7488,-9294,18,65535,0,0,-1647,38.3,5,37,94,13200,4000,0x02C2,0x40,0,1745,2743,8000,0x08,0x0840,0x00,0x01,1049,0,-273.2,97,23,2807,198,23,1004,0,0,0,0,0,0,763,SUCCESS
    212,2019-04-26 11:44:55,848.127,0x0000,42.1,10608,0x0001,-9294,2734,7488,-9294,18,65535,0,0,-1646,38.4,5,37,94,13200,4000,0x02C2,0x40,0,1745,2734,8000,0x08,0x0840,0x00,0x01,1045,0,-273.2,97,23,2811,198,23,1004,0,0,0,0,0,0,695,SUCCESS
    213,2019-04-26 11:44:59,852.128,0x0000,42.1,10602,0x0001,-9294,2725,7488,-9294,18,65535,0,0,-1645,38.4,5,37,94,13200,4000,0x02C2,0x40,0,1745,2725,8000,0x08,0x0840,0x00,0x01,1041,0,-273.2,97,23,2815,198,23,1004,0,0,0,0,0,0,696,SUCCESS
    214,2019-04-26 11:45:03,856.129,0x0000,42.1,10596,0x0001,-9294,2716,7488,-9294,18,65535,0,0,-1644,38.4,5,37,94,13200,4000,0x02C2,0x40,0,1745,2716,8000,0x08,0x0840,0x00,0x01,1037,0,-273.2,97,23,2819,198,23,1004,0,0,0,0,0,0,690,SUCCESS
    215,2019-04-26 11:45:07,860.129,0x0000,42.1,10596,0x0001,-9294,2708,7488,-9294,17,65535,0,0,-1644,38.4,5,37,94,13200,4000,0x02C2,0x40,0,1745,2708,8000,0x08,0x0840,0x00,0x01,1033,0,-273.2,97,23,2823,198,23,1004,0,0,0,0,0,0,696,SUCCESS
    216,2019-04-26 11:45:11,864.129,0x0000,42.1,10590,0x0001,-9294,2699,7488,-9294,17,65535,0,0,-1643,38.4,5,37,94,13200,4000,0x02C2,0x40,0,1745,2699,8000,0x08,0x0840,0x00,0x01,1029,0,-273.2,97,23,2827,198,23,1004,0,0,0,0,0,0,713,SUCCESS
    217,2019-04-26 11:45:15,868.130,0x0000,42.1,10584,0x0001,-9294,2690,7488,-9294,17,65535,0,0,-1642,38.4,5,36,94,13200,4000,0x02C2,0x40,0,1745,2690,8000,0x08,0x0840,0x00,0x01,1026,0,-273.2,97,23,2831,198,23,1004,0,0,0,0,0,0,731,SUCCESS
    218,2019-04-26 11:45:19,872.130,0x0000,42.1,10578,0x0001,-9294,2681,7488,-9294,17,65535,0,0,-1641,38.4,5,36,94,13200,4000,0x02C2,0x40,0,1745,2681,8000,0x08,0x0840,0x00,0x01,1022,0,-273.2,97,23,2835,198,23,1004,0,0,0,0,0,0,741,SUCCESS
    219,2019-04-26 11:45:23,876.131,0x0000,42.1,10572,0x0001,-9294,2672,7488,-9294,17,65535,0,0,-1640,38.4,5,36,94,13200,4000,0x02C2,0x40,0,1745,2672,8000,0x08,0x0840,0x00,0x01,1018,0,-273.2,97,23,2839,198,23,1004,0,0,0,0,0,0,754,SUCCESS
    220,2019-04-26 11:45:27,880.131,0x0000,42.1,10566,0x0001,-9295,2663,7488,-9294,17,65535,0,0,-1640,38.5,5,36,94,13200,4000,0x02C2,0x40,0,1745,2663,8000,0x08,0x0840,0x00,0x01,1014,0,-273.2,97,23,2842,198,23,1004,0,0,0,0,0,0,721,SUCCESS
    221,2019-04-26 11:45:31,884.132,0x0000,42.1,10560,0x0001,-9295,2654,7488,-9295,17,65535,0,0,-1639,38.5,5,36,94,13200,4000,0x02C2,0x40,0,1745,2654,8000,0x08,0x0840,0x00,0x01,1010,0,-273.2,97,23,2846,198,23,1004,0,0,0,0,0,0,724,SUCCESS
    222,2019-04-26 11:45:35,888.133,0x0000,42.1,10554,0x0001,-9295,2645,7488,-9295,17,65535,0,0,-1638,38.5,5,36,94,13200,4000,0x02C2,0x40,0,1745,2645,8000,0x08,0x0840,0x00,0x01,1006,0,-273.2,97,23,2850,198,23,1004,0,0,0,0,0,0,722,SUCCESS
    223,2019-04-26 11:45:39,892.134,0x0000,42.2,10548,0x0001,-9295,2636,7488,-9295,17,65535,0,0,-1637,38.5,5,36,94,13200,4000,0x02C2,0x40,0,1745,2636,8000,0x08,0x0840,0x00,0x01,1002,0,-273.2,97,23,2854,198,23,1004,0,0,0,0,0,0,692,SUCCESS
    224,2019-04-26 11:45:43,896.134,0x0000,42.2,10542,0x0001,-9295,2628,7488,-9295,17,65535,0,0,-1636,38.4,5,36,94,13200,4000,0x02C2,0x40,0,1745,2628,8000,0x08,0x0840,0x00,0x01,998,0,-273.2,97,23,2858,198,23,1004,0,0,0,0,0,0,694,SUCCESS
    225,2019-04-26 11:45:47,900.135,0x0000,42.2,10536,0x0001,-9295,2619,7488,-9295,17,65535,0,0,-1635,38.5,5,35,94,13200,4000,0x02C2,0x40,0,1745,2619,8000,0x08,0x0840,0x00,0x01,994,0,-273.2,97,23,2862,198,23,1004,0,0,0,0,0,0,710,SUCCESS
    226,2019-04-26 11:45:51,904.136,0x0000,42.2,10530,0x0001,-9295,2610,7488,-9295,17,65535,0,0,-1634,38.5,5,35,94,13200,4000,0x02C2,0x40,0,1745,2610,8000,0x08,0x0840,0x00,0x01,990,0,-273.2,97,23,2866,198,23,1004,0,0,0,0,0,0,704,SUCCESS
    227,2019-04-26 11:45:55,908.136,0x0000,42.2,10524,0x0001,-9295,2601,7488,-9295,17,65535,0,0,-1633,38.5,5,35,94,13200,4000,0x02C2,0x40,0,1745,2601,8000,0x08,0x0840,0x00,0x01,986,0,-273.2,97,23,2870,198,23,1004,0,0,0,0,0,0,689,SUCCESS
    228,2019-04-26 11:45:59,912.136,0x0000,42.2,10518,0x0001,-9295,2592,7488,-9295,17,65535,0,0,-1632,38.5,5,35,94,13200,4000,0x02C2,0x40,0,1745,2592,8000,0x08,0x0840,0x00,0x01,982,0,-273.2,97,23,2874,198,23,1004,0,0,0,0,0,0,724,SUCCESS
    229,2019-04-26 11:46:03,916.137,0x0000,42.2,10512,0x0001,-9295,2583,7488,-9295,17,65535,0,0,-1631,38.5,5,35,94,13200,4000,0x02C2,0x40,0,1745,2583,8000,0x08,0x0840,0x00,0x01,978,0,-273.2,97,23,2878,198,23,1004,0,0,0,0,0,0,722,SUCCESS
    230,2019-04-26 11:46:07,920.138,0x0000,42.2,10506,0x0001,-9295,2574,7488,-9295,17,65535,0,0,-1631,38.5,5,35,94,13200,4000,0x02C2,0x40,0,1745,2574,8000,0x08,0x0840,0x00,0x01,974,0,-273.2,97,23,2882,198,23,1004,0,0,0,0,0,0,705,SUCCESS
    231,2019-04-26 11:46:11,924.138,0x0000,42.2,10500,0x0101,-9295,2565,7488,-9295,17,65535,0,0,-1630,38.5,5,35,94,13200,4000,0x02C2,0x40,0,1745,2565,8000,0x08,0x0840,0x00,0x01,970,0,-273.2,97,23,2886,198,23,1004,0,0,0,0,0,0,703,SUCCESS
    232,2019-04-26 11:46:15,928.139,0x0000,42.2,10494,0x0101,-9295,2556,7488,-9295,16,65535,0,0,-1629,38.5,5,35,94,13200,4000,0x02C2,0x40,0,1745,2556,8000,0x08,0x0840,0x00,0x01,966,0,-273.2,97,23,2890,198,23,1004,0,0,0,0,0,0,690,SUCCESS
    233,2019-04-26 11:46:19,932.139,0x0000,42.2,10482,0x0101,-9296,2548,7488,-9295,16,65535,0,0,-1628,38.5,5,35,94,13200,4000,0x02C2,0x40,0,1745,2548,8000,0x08,0x0840,0x00,0x01,962,0,-273.2,97,23,2894,198,23,1004,0,0,0,0,0,0,703,SUCCESS
    234,2019-04-26 11:46:23,936.140,0x0000,42.2,10482,0x0101,-9295,2539,7488,-9295,16,65535,0,0,-1627,38.5,5,34,94,13200,4000,0x02C2,0x40,0,1745,2539,8000,0x08,0x0840,0x00,0x01,958,0,-273.2,97,23,2898,198,23,1004,0,0,0,0,0,0,705,SUCCESS
    235,2019-04-26 11:46:27,940.140,0x0000,42.2,10470,0x0101,-9295,524,7488,-9295,3,65535,0,0,-1626,38.5,5,7,94,13200,4000,0x028A,0x4040,0,1745,524,8000,0x08,0x0840,0x00,0x01,954,0,-273.2,97,23,2902,198,23,1004,0,0,0,0,0,0,702,SUCCESS
    236,2019-04-26 11:46:31,944.141,0x0000,42.2,10470,0x4101,-9296,513,7488,-9295,3,65535,0,0,-1625,38.5,5,7,94,13200,4000,0x028A,0x4040,0,1720,513,8000,0x08,0x0840,0x00,0x01,950,0,-273.2,97,23,2906,198,23,1004,0,0,0,0,0,0,685,SUCCESS
    237,2019-04-26 11:46:35,948.141,0x0000,42.3,10458,0x4101,-9296,507,7488,-9295,3,65535,0,0,-1624,38.6,5,7,94,13200,4000,0x02CA,0x4040,0,1720,507,5604,0x08,0x0840,0x00,0x01,946,0,-273.2,97,23,2910,198,23,1004,0,0,0,0,0,0,702,SUCCESS
    238,2019-04-26 11:46:39,952.142,0x0000,42.2,10452,0x4101,-9295,501,7488,-9295,3,65535,0,0,-1623,38.6,5,7,94,13200,4000,0x02CA,0x4040,0,1720,501,5604,0x08,0x0840,0x00,0x01,942,0,-273.2,97,23,2914,198,23,1004,0,0,0,0,0,0,685,SUCCESS
    239,2019-04-26 11:46:43,956.142,0x0000,42.3,10446,0x4101,-9296,495,7488,-9295,3,65535,0,0,-1622,38.6,5,7,94,13200,4000,0x02CA,0x4040,0,1720,495,5604,0x08,0x0840,0x00,0x01,938,0,-273.2,97,23,2918,198,23,1004,0,0,0,0,0,0,704,SUCCESS
    240,2019-04-26 11:46:47,960.143,0x0000,42.3,10440,0x4101,-9295,489,7488,-9295,3,65535,0,0,-1621,38.6,5,7,94,13200,4000,0x02CA,0x4040,0,1720,489,5604,0x08,0x0840,0x00,0x01,934,0,-273.2,97,23,2922,198,23,1004,0,0,0,0,0,0,686,SUCCESS
    241,2019-04-26 11:46:51,964.144,0x0000,42.2,10434,0x4001,0,485,7488,-8268,4,65535,0,0,-1441,38.6,5,7,94,13200,4000,0x02CA,0x4040,0,1787,485,5604,0x08,0x0840,0x00,0x01,930,0,-273.2,97,23,2926,198,23,1004,0,0,0,0,0,0,717,SUCCESS
    242,2019-04-26 11:46:55,968.145,0x0000,42.3,11598,0x4081,0,485,7488,-6281,5,65535,0,0,-1095,38.6,5,7,94,13200,4000,0x02CA,0x4040,0,1799,485,5604,0x08,0x0840,0x00,0x01,926,0,-273.2,97,23,2930,198,23,1004,0,0,0,0,0,0,736,SUCCESS
    243,2019-04-26 11:46:59,972.145,0x0000,42.3,11598,0x4081,0,485,7488,-4771,6,65535,0,0,-832,38.6,5,7,94,13200,4000,0x02CA,0x4040,0,1804,485,5604,0x08,0x0840,0x00,0x01,922,0,-273.2,97,23,2934,198,23,1004,0,0,0,0,0,0,701,SUCCESS
    244,2019-04-26 11:47:03,976.145,0x0000,42.3,11598,0x4081,0,485,7488,-3625,8,65535,0,0,-632,38.6,5,7,94,13200,4000,0x02CA,0x4040,0,1806,485,5604,0x08,0x0840,0x00,0x01,918,0,-273.2,97,23,2938,198,23,1004,0,0,0,0,0,0,734,SUCCESS
    245,2019-04-26 11:47:07,980.146,0x0000,42.3,11598,0x4081,0,485,7488,-2754,11,65535,0,0,-480,38.6,5,7,94,13200,4000,0x02CA,0x4040,0,1806,485,5604,0x08,0x0840,0x00,0x01,914,0,-273.2,97,23,2942,198,23,1004,0,0,0,0,0,0,736,SUCCESS
    246,2019-04-26 11:47:11,984.146,0x0000,42.3,11598,0x4081,0,485,7488,-2092,14,65535,0,0,-365,38.6,5,7,94,13200,4000,0x02CA,0x4040,0,1806,485,5604,0x08,0x0840,0x00,0x01,910,0,-273.2,97,23,2946,198,23,1004,0,0,0,0,0,0,735,SUCCESS
    247,2019-04-26 11:47:15,988.147,0x0000,41.8,11664,0x4081,0,485,7488,-1589,18,65535,0,0,-277,38.2,5,7,94,13200,4000,0x02CA,0x4040,0,1806,485,5604,0x08,0x0840,0x00,0x01,906,0,-273.2,97,23,2950,198,23,1004,0,0,0,0,0,0,697,SUCCESS
    248,2019-04-26 11:47:19,992.148,0x0000,41.8,11664,0x4081,0,485,7488,-1207,24,65535,0,0,-210,38.2,5,7,94,13200,4000,0x02CA,0x4040,0,1806,485,5604,0x08,0x0840,0x00,0x01,902,0,-273.2,97,23,2954,198,23,1004,0,0,0,0,0,0,792,SUCCESS
    249,2019-04-26 11:47:23,996.149,0x0020,41.8,11664,0x4001,0,485,7488,-917,28,65535,0,0,-160,37.9,5,7,94,13200,4000,0x02CA,0x4040,0,1806,485,5604,0x08,0x0840,0x00,0x01,899,0,-273.2,97,23,2957,198,23,1004,0,0,0,0,0,0,880,SUCCESS
    250,2019-04-26 11:47:27,1000.149,0x0020,41.2,11682,0x4001,0,485,7488,-746,28,65535,0,0,-121,37.7,5,7,94,13200,4000,0x02CA,0x4040,0,1806,485,5604,0x08,0x0840,0x00,0x01,899,0,-273.2,97,23,2957,198,23,1004,0,0,0,0,0,0,730,SUCCESS
    251,2019-04-26 11:47:31,1004.150,0x0020,41.1,11682,0x4001,0,485,7488,-567,28,65535,0,0,-92,37.6,5,7,94,13200,4000,0x02CA,0x4040,0,1806,485,5604,0x08,0x0840,0x00,0x01,899,0,-273.2,97,23,2957,198,23,1004,0,0,0,0,0,0,751,SUCCESS
    252,2019-04-26 11:47:35,1008.648,0x0020,40.9,11688,0x4001,0,485,7488,-402,28,65535,0,0,-70,37.4,5,7,94,13200,4000,0x02CA,0x4040,0,1806,485,5604,0x08,0x0840,0x00,0x01,899,0,-273.2,97,23,2957,198,23,1004,0,0,0,0,0,0,731,SUCCESS
    253,2019-04-26 11:47:39,1012.151,0x0020,40.8,11694,0x4001,0,485,7488,-327,,65535,0,0,-46,37.4,5,7,94,13200,4000,0x028A,0x4040,0,1787,485,5604,0x08,0x0840,0x00,0x01,897,0,-273.2,97,23,2959,198,23,1004,0,0,0,0,0,0,3022,ERROR : Please check C:\Users\jpryde\Desktop\GPC\Logs\Discharge GPC3.log.err
    254,2019-04-26 11:47:43,1016.152,0x0000,40.7,11688,0x4081,0,485,7488,-249,117,65535,0,0,-43,37.4,5,7,94,13200,4000,0x028A,0x4040,0,1787,485,5604,0x08,0x0840,0x00,0x01,895,0,-273.2,97,23,2961,198,23,1004,0,0,0,0,0,0,757,SUCCESS
    255,2019-04-26 11:47:47,1020.152,0x0000,40.7,11688,0x4081,0,485,7488,-189,154,65535,0,0,-33,37.4,5,7,94,13200,4000,0x028A,0x4040,0,1787,485,5604,0x08,0x0840,0x00,0x01,891,0,-273.2,97,23,2965,198,23,1004,0,0,0,0,0,0,744,SUCCESS
    256,2019-04-26 11:47:51,1024.152,0x0000,40.7,11688,0x4080,0,485,7488,-143,203,65535,0,0,-25,37.4,5,7,94,13200,4000,0x0282,0x40,0,1787,485,5604,0x08,0x0840,0x00,0x01,887,0,-273.2,97,23,2969,198,23,1004,0,0,0,0,0,0,745,SUCCESS
    257,2019-04-26 11:47:55,1028.153,0x0000,40.7,11688,0x4080,0,485,7488,-109,267,65535,0,0,-19,37.4,5,7,94,13200,4000,0x0282,0x40,0,1787,485,5604,0x08,0x0840,0x00,0x01,883,0,-273.2,97,23,2973,198,23,1004,0,0,0,0,0,0,742,SUCCESS
    258,2019-04-26 11:47:59,1032.153,0x0000,40.7,11688,0x4080,0,485,7488,-83,351,65535,0,0,-14,37.4,5,7,94,13200,4000,0x0282,0x40,0,1787,485,5604,0x08,0x0840,0x00,0x01,879,0,-273.2,97,23,2977,198,23,1004,0,0,0,0,0,0,766,SUCCESS
    259,2019-04-26 11:48:03,1036.154,0x0000,39.9,11706,0x4080,0,485,7488,-63,462,65535,,0,-9,36.7,5,7,94,13200,4000,0x0282,0x40,0,1787,485,5604,0x08,0x0840,0x00,0x01,873,0,-273.2,97,23,2983,198,23,1004,0,0,0,0,0,0,3023,ERROR : Please check C:\Users\jpryde\Desktop\GPC\Logs\Discharge GPC3.log.err
    260,2019-04-26 11:48:07,1040.154,0x0000,39.9,11706,0x4080,0,485,7488,-48,606,65535,0,0,-8,36.7,5,7,94,13200,4000,0x0282,0x40,0,1787,485,5604,0x08,0x0840,0x00,0x01,871,0,-273.2,97,23,2985,198,23,1004,0,0,0,0,0,0,757,SUCCESS
    261,2019-04-26 11:48:11,1044.155,0x0000,39.9,11706,0x4080,0,485,7488,-36,808,65535,0,0,-6,36.7,5,7,94,13200,4000,0x0282,0x40,0,1787,485,5604,0x08,0x0840,0x00,0x01,867,0,-273.2,97,23,2989,198,23,1004,0,0,0,0,0,0,724,SUCCESS
    262,2019-04-26 11:48:15,1048.155,0x0000,39.9,11706,0x4080,0,485,7488,-28,1039,65535,0,0,-5,36.7,5,7,94,13200,4000,0x0282,0x40,0,1787,485,5604,0x08,0x0840,0x00,0x01,863,0,-273.2,97,23,2993,198,23,1004,0,0,0,0,0,0,723,SUCCESS
    263,2019-04-26 11:48:19,1052.156,0x0000,39.9,11706,0x4080,0,485,7488,-21,1386,65535,0,0,-4,36.7,5,7,94,13200,4000,0x0282,0x40,0,1787,485,5604,0x08,0x0840,0x00,0x01,859,0,-273.2,97,23,2997,198,23,1004,0,0,0,0,0,0,738,SUCCESS
    264,2019-04-26 11:48:23,1056.156,0x0000,39.2,11718,0x4080,0,485,7488,-16,1819,65535,0,0,-3,36.1,5,7,94,13200,4000,0x0282,0x40,0,1787,485,5604,0x08,0x0840,0x00,0x01,855,0,-273.2,97,23,3001,198,23,1004,0,0,0,0,0,0,740,SUCCESS
    265,2019-04-26 11:48:27,1060.156,0x0000,39.2,11718,0x4080,0,485,7488,-12,2425,65535,0,0,-2,36.1,5,7,94,13200,4000,0x0282,0x40,0,1787,485,5604,0x08,0x0840,0x00,0x01,851,0,-273.2,97,23,3005,198,23,1004,0,0,0,0,0,0,757,SUCCESS
    I tried messing around with the FitMaxSOC% and FitMinSOC% in the config. I haven't actually seen any posts or info about how to select these numbers. From what I noticed, the SOC Error% that are returned from TI vary about 1-2% when adjusting these values. It seems like with a lower percentage error, the RC/TTE values don't drop as heavily. For example when the SOCerror% for roomtemp_lowrate was 1.77%, the TTE dropped from 16mins to 3 mins once it hit EDV2. When the SOCerror% was 0.73%, the TTE dropped from 11 mins to 3 mins. I'm not sure if this is correlation or coincidence.
    The problem with this is that it's impossible to get all 6 condition (temp + rate) error % under 1%. If I change FitMax/Min so that one condition error goes down, another condition error will go up. It might be possible to change the CEDV parameters dynamically based on discharging environment conditions, but this would be a pain to code.
    I'm interested to hear any advice or suggestions you can give. Thanks for your time.
  • Hi Bryan,
    Thanks again for the reply. I couldn't find anything very helpful. I don't think either document really talked about choosing the Fit Max/Min SOC% config parameter much. I realize it has to do with curve fitting bounds but I still don't know how to choose them. If I missed something in the documents let me know.
    In the second document, we haven't been doing all the "things most commonly going wrong". Although I don't understand tip 6: "Voltage divider set to actual number of serial cell in the pack, but not for the voltage column that is selected". What does this mean? We used one 6-cell battery for the cycles, so I put 6 for the NumCellSeries = 6 config file. Does anything else have to be done? Also, I saw that "If EDVV bit is set to 1, EMF and EDVR0 have to be multiplied by the number of serial cells when written to data flash". Where is this EDVV bit? It is not in the GPCCEDV report they send back. Is it in the BQ's dataflash somewhere? I couldn't find any mention of it in the TRM.
    Colin
  • Hi Colin,
    The EDVV bit refers to if a fixed EDV is used (enable on some gauges). The values are absolute for other multicell gauges, however, this gauge is based on the single cell values.
    Sincerely,
    Bryan Kahler
  • Ok well fixed EDV is not being used so that shouldn't be a problem. If the CEDV values are single cell then we should have programmed the correct values to the gauge as well. Any other ideas why the gauge isn't behaving as expected?
    We've tried everything we can think of, we've read the TRM and searched the forums, but we still can't find what's wrong with the gauge. I know that for batteries needing a ChemID, it is possible to ship the batteries to TI for characterization. I don't suppose that the same is possible for GPC Cycles?
  • Hi ColinY,
    That's correct, the CEDV gauge doesn't require the creation of a chemID.
    Please send me your gpc report, gg.csv file and log of the event for review.
    Sincerely,
    Bryan Kahler
  • Hi Bryan,
    I realize that the CEDV gauge doesn't need a chemID, I was wondering whether TI could characterize the battery for CEDV parameters like they characterize batteries for chemIDs. I have uploaded the gpc report, gg.csv file and event log previously (nothing's changed since then), however I could link them again:
    GPC Report - NEWGPC3-report (1).zip
    Discharge Log -
    0358.Discharge GPC3.log
    Fri Apr 26 11:30:46 ADT 2019
    Device Name = bq34110
    Firmware Version = 0_02
    Design Capacity = 8000
    Sample,DateTime,ElapsedTime,Control,Temperature,Voltage,Batt Stat,Current,RemCap,FullChgCap,AvgCurr,RunTimeEmty,AvgTimeFull,AccumulatedCharge,AccumulatedCharge Time,AvgPwr,IntTemp,CycleCnt,RSOC,SOH,ChgVolt,ChgCurr,OpStat,GaugeStat,CEDVRemCap,EDV Threshold,SmRemCap,SmCurrent,ManufacStat,EOSLearnStatus,EOSSafetyStatus,EOSStatus,AutoLearnTime,AvgDsgCurrent,AvgDsgTemp,LearnedResistance,LearnedResTimeHours,LearnedResTimeSeconds,LastLearnedResistance,LastLearnedResHours,LastLearnedResSeconds,InitialRRateAgeHours,InitialRRateAgeSeconds,RRate,RRateLong,InitialRcellRRateLearnRes,InitialRcellRRateLearnCount,LogRowTime(ms),LogStatus
    1,2019-04-26 11:30:51,4.001,0x0000,30.9,12576,0x0080,0,4685,7488,0,65535,65535,0,0,0,28.5,5,63,94,13200,4000,0x0282,0x40,1940,1782,4685,3077,0x08,0x0840,0x00,0x01,1885,0,-273.2,97,23,1971,198,23,1004,0,0,0,0,0,0,674,SUCCESS
    2,2019-04-26 11:30:55,8.002,0x0000,30.9,12576,0x0080,0,4685,7488,0,65535,65535,0,0,0,28.5,5,63,94,13200,4000,0x0282,0x40,1940,1782,4685,3077,0x08,0x0840,0x00,0x01,1881,0,-273.2,97,23,1975,198,23,1004,0,0,0,0,0,0,672,SUCCESS
    3,2019-04-26 11:30:59,12.002,0x0000,30.9,12576,0x0080,0,4685,7488,0,65535,65535,0,0,0,28.5,5,63,94,13200,4000,0x0282,0x40,1940,1782,4685,3077,0x08,0x0840,0x00,0x01,1877,0,-273.2,97,23,1979,198,23,1004,0,0,0,0,0,0,676,SUCCESS
    4,2019-04-26 11:31:03,16.003,0x0000,30.9,12576,0x0080,0,4685,7488,0,65535,65535,0,0,0,28.5,5,63,94,13200,4000,0x0282,0x40,1940,1782,4685,3077,0x08,0x0840,0x00,0x01,1873,0,-273.2,97,23,1983,198,23,1004,0,0,0,0,0,0,669,SUCCESS
    5,2019-04-26 11:31:07,20.004,0x0000,30.9,12576,0x0080,0,4685,7488,0,65535,65535,0,0,0,28.5,5,63,94,13200,4000,0x0282,0x40,1940,1782,4685,3077,0x08,0x0840,0x00,0x01,1869,0,-273.2,97,23,1987,198,23,1004,0,0,0,0,0,0,676,SUCCESS
    6,2019-04-26 11:31:11,24.005,0x0000,30.9,12576,0x0080,0,4685,7488,0,65535,65535,0,0,0,28.5,5,63,94,13200,4000,0x0282,0x40,1940,1782,4685,3077,0x08,0x0840,0x00,0x01,1865,0,-273.2,97,23,1991,198,23,1004,0,0,0,0,0,0,671,SUCCESS
    7,2019-04-26 11:31:15,28.005,0x0000,30.9,12576,0x0080,0,4685,7488,0,65535,65535,0,0,0,28.5,5,63,94,13200,4000,0x0282,0x40,1940,1782,4685,3077,0x08,0x0840,0x00,0x01,1861,0,-273.2,97,23,1995,198,23,1004,0,0,0,0,0,0,670,SUCCESS
    8,2019-04-26 11:31:19,32.006,0x0000,30.9,12576,0x0080,0,4685,7488,0,65535,65535,0,0,0,28.5,5,63,94,13200,4000,0x0282,0x40,1940,1782,4685,3077,0x08,0x0840,0x00,0x01,1857,0,-273.2,97,23,1999,198,23,1004,0,0,0,0,0,0,703,SUCCESS
    9,2019-04-26 11:31:23,36.006,0x0000,30.9,12576,0x0080,0,4685,7488,0,65535,65535,0,0,0,28.5,5,63,94,13200,4000,0x0282,0x40,1940,1782,4685,3077,0x08,0x0840,0x00,0x01,1853,0,-273.2,97,23,2003,198,23,1004,0,0,0,0,0,0,679,SUCCESS
    10,2019-04-26 11:31:27,40.007,0x0000,30.9,12576,0x0080,0,4685,7488,0,65535,65535,0,0,0,28.7,5,63,94,13200,4000,0x0282,0x40,1940,1782,4685,3077,0x08,0x0840,0x00,0x01,1849,0,-273.2,97,23,2007,198,23,1004,0,0,0,0,0,0,708,SUCCESS
    11,2019-04-26 11:31:31,44.007,0x0000,31.3,11448,0x0001,-9019,4675,7488,-2165,130,65535,0,0,-413,28.8,5,63,94,13200,4000,0x0282,0x40,1930,1746,4675,3077,0x08,0x0840,0x00,0x01,1845,0,-273.2,97,23,2011,198,23,1004,0,0,0,0,0,0,672,SUCCESS
    12,2019-04-26 11:31:35,48.008,0x0000,31.4,11442,0x0001,-9035,4665,7488,-3815,73,65535,0,0,-728,29.0,5,63,94,13200,4000,0x0282,0x40,1920,1746,4665,3077,0x08,0x0840,0x00,0x01,1842,0,-273.2,97,23,2015,198,23,1004,0,0,0,0,0,0,671,SUCCESS
    13,2019-04-26 11:31:39,52.008,0x0000,31.6,11436,0x0001,-9049,4655,7488,-5072,55,65535,0,0,-967,29.1,5,63,94,13200,4000,0x0282,0x40,1910,1746,4655,3077,0x08,0x0840,0x00,0x01,1838,0,-273.2,97,23,2019,198,23,1004,0,0,0,0,0,0,682,SUCCESS
    14,2019-04-26 11:31:43,56.009,0x0000,31.8,11430,0x0001,-9063,4645,7488,-6030,46,65535,0,0,-1150,29.3,5,63,94,13200,4000,0x0282,0x40,1900,1746,4645,3077,0x08,0x0840,0x00,0x01,1834,0,-273.2,97,23,2023,198,23,1004,0,0,0,0,0,0,695,SUCCESS
    15,2019-04-26 11:31:47,60.009,0x0000,32.0,11424,0x0001,-9074,4635,7488,-6760,41,65535,0,0,-1288,29.4,5,62,94,13200,4000,0x0282,0x40,1890,1746,4635,3077,0x08,0x0840,0x00,0x01,1830,0,-273.2,97,23,2026,198,23,1004,0,0,0,0,0,0,670,SUCCESS
    16,2019-04-26 11:31:51,64.010,0x0000,32.1,11418,0x0001,-9086,4625,7488,-7318,38,65535,0,0,-1394,29.5,5,62,94,13200,4000,0x0282,0x40,1880,1746,4625,3077,0x08,0x0840,0x00,0x01,1826,0,-273.2,97,23,2030,198,23,1004,0,0,0,0,0,0,669,SUCCESS
    17,2019-04-26 11:31:55,68.010,0x0000,32.3,11412,0x0001,-9095,4615,7488,-7744,36,65535,0,0,-1475,29.7,5,62,94,13200,4000,0x0282,0x40,1870,1746,4615,3077,0x08,0x0840,0x00,0x01,1822,0,-273.2,97,23,2034,198,23,1004,0,0,0,0,0,0,669,SUCCESS
    18,2019-04-26 11:31:59,72.011,0x0000,32.5,11406,0x0001,-9105,4605,7488,-8070,34,65535,0,0,-1536,29.8,5,62,94,13200,4000,0x0282,0x40,1859,1746,4605,3077,0x08,0x0840,0x00,0x01,1818,0,-273.2,97,23,2038,198,23,1004,0,0,0,0,0,0,668,SUCCESS
    19,2019-04-26 11:32:03,76.011,0x0000,32.7,11406,0x0001,-9113,4595,7488,-8320,33,65535,0,0,-1583,30.0,5,62,94,13200,4000,0x0282,0x40,1849,1746,4595,3077,0x08,0x0840,0x00,0x01,1814,0,-273.2,97,23,2042,198,23,1004,0,0,0,0,0,0,687,SUCCESS
    20,2019-04-26 11:32:07,80.012,0x0000,32.9,11400,0x0001,-9121,4585,7488,-8512,32,65535,0,0,-1619,30.1,5,62,94,13200,4000,0x0282,0x40,1839,1746,4585,3077,0x08,0x0840,0x00,0x01,1810,0,-273.2,97,23,2046,198,23,1004,0,0,0,0,0,0,685,SUCCESS
    21,2019-04-26 11:32:11,84.013,0x0000,33.0,11394,0x0001,-9129,4574,7488,-8660,32,65535,0,0,-1647,30.3,5,62,94,13200,4000,0x0282,0x40,1829,1745,4574,3077,0x08,0x0840,0x00,0x01,1806,0,-273.2,97,23,2050,198,23,1004,0,0,0,0,0,0,695,SUCCESS
    22,2019-04-26 11:32:15,88.013,0x0000,33.2,11388,0x0001,-9135,4564,7488,-8773,31,65535,0,0,-1668,30.4,5,61,94,13200,4000,0x0282,0x40,1819,1745,4564,3077,0x08,0x0840,0x00,0x01,1802,0,-273.2,97,23,2054,198,23,1004,0,0,0,0,0,0,687,SUCCESS
    23,2019-04-26 11:32:19,92.014,0x0000,33.4,11388,0x0001,-9142,4554,7488,-8861,31,65535,0,0,-1684,30.5,5,61,94,13200,4000,0x0282,0x40,1809,1745,4554,3077,0x08,0x0840,0x00,0x01,1798,0,-273.2,97,23,2058,198,23,1004,0,0,0,0,0,0,734,SUCCESS
    24,2019-04-26 11:32:23,96.015,0x0000,33.6,11382,0x0001,-9149,4544,7488,-8930,31,65535,0,0,-1696,30.7,5,61,94,13200,4000,0x0282,0x40,1799,1745,4544,3077,0x08,0x0840,0x00,0x01,1794,0,-273.2,97,23,2062,198,23,1004,0,0,0,0,0,0,731,SUCCESS
    25,2019-04-26 11:32:27,100.015,0x0000,33.7,11376,0x0001,-9154,4534,7488,-8983,30,65535,0,0,-1706,30.8,5,61,94,13200,4000,0x0282,0x40,1788,1745,4534,3077,0x08,0x0840,0x00,0x01,1790,0,-273.2,97,23,2066,198,23,1004,0,0,0,0,0,0,686,SUCCESS
    26,2019-04-26 11:32:31,104.016,0x0000,33.9,11376,0x0001,-9160,4524,7488,-9025,30,65535,0,0,-1713,30.9,5,61,94,13200,4000,0x0282,0x40,1778,1745,4524,3077,0x08,0x0840,0x00,0x01,1786,0,-273.2,97,23,2070,198,23,1004,0,0,0,0,0,0,686,SUCCESS
    27,2019-04-26 11:32:35,108.016,0x0000,34.1,11370,0x0001,-9165,4513,7488,-9058,30,65535,0,0,-1719,31.1,5,61,94,13200,4000,0x0282,0x40,1768,1745,4513,3077,0x08,0x0840,0x00,0x01,1782,0,-273.2,97,23,2074,198,23,1004,0,0,0,0,0,0,686,SUCCESS
    28,2019-04-26 11:32:39,112.016,0x0000,34.2,11364,0x0001,-9170,4503,7488,-9085,30,65535,0,0,-1723,31.2,5,61,94,13200,4000,0x0282,0x40,1758,1745,4503,3077,0x08,0x0840,0x00,0x01,1778,0,-273.2,97,23,2078,198,23,1004,0,0,0,0,0,0,684,SUCCESS
    29,2019-04-26 11:32:43,116.017,0x0000,34.3,11364,0x0001,-9174,4493,7488,-9106,30,65535,0,0,-1727,31.3,5,61,94,13200,4000,0x0282,0x40,1748,1745,4493,3077,0x08,0x0840,0x00,0x01,1774,0,-273.2,97,23,2082,198,23,1004,0,0,0,0,0,0,703,SUCCESS
    30,2019-04-26 11:32:47,120.017,0x0000,34.5,11358,0x0001,-9178,4483,7488,-9123,29,65535,0,0,-1729,31.5,5,60,94,13200,4000,0x0282,0x40,1737,1745,4483,3077,0x08,0x0840,0x00,0x01,1770,0,-273.2,97,23,2086,198,23,1004,0,0,0,0,0,0,687,SUCCESS
    31,2019-04-26 11:32:51,124.018,0x0000,34.6,11352,0x0001,-9183,4473,7488,-9137,29,65535,0,0,-1731,31.6,5,60,94,13200,4000,0x0282,0x40,1727,1745,4473,3077,0x08,0x0840,0x00,0x01,1766,0,-273.2,97,23,2090,198,23,1004,0,0,0,0,0,0,686,SUCCESS
    32,2019-04-26 11:32:55,128.019,0x0000,34.8,11352,0x0001,-9187,4462,7488,-9149,29,65535,0,0,-1733,31.7,5,60,94,13200,4000,0x0282,0x40,1717,1745,4462,3077,0x08,0x0840,0x00,0x01,1762,0,-273.2,97,23,2094,198,23,1004,0,0,0,0,0,0,685,SUCCESS
    33,2019-04-26 11:32:59,132.019,0x0000,34.9,11346,0x0001,-9190,4452,7488,-9158,29,65535,0,0,-1734,31.8,5,60,94,13200,4000,0x0282,0x40,1707,1745,4452,3077,0x08,0x0840,0x00,0x01,1758,0,-273.2,97,23,2098,198,23,1004,0,0,0,0,0,0,684,SUCCESS
    34,2019-04-26 11:33:03,136.020,0x0000,35.1,11346,0x0001,-9194,4442,7488,-9167,29,65535,0,0,-1735,31.9,5,60,94,13200,4000,0x0282,0x40,1697,1745,4442,3077,0x08,0x0840,0x00,0x01,1754,0,-273.2,97,23,2102,198,23,1004,0,0,0,0,0,0,683,SUCCESS
    35,2019-04-26 11:33:07,140.020,0x0000,35.2,11340,0x0001,-9197,4432,7488,-9174,29,65535,0,0,-1736,32.0,5,60,94,13200,4000,0x0282,0x40,1686,1745,4432,3077,0x08,0x0840,0x00,0x01,1750,0,-273.2,97,23,2106,198,23,1004,0,0,0,0,0,0,687,SUCCESS
    36,2019-04-26 11:33:11,144.021,0x0000,35.3,11334,0x0001,-9201,4422,7488,-9180,29,65535,0,0,-1737,32.1,5,60,94,13200,4000,0x0282,0x40,1676,1745,4422,3077,0x08,0x0840,0x00,0x01,1746,0,-273.2,97,23,2110,198,23,1004,0,0,0,0,0,0,680,SUCCESS
    37,2019-04-26 11:33:15,148.021,0x0000,35.5,11334,0x0001,-9204,4411,7488,-9186,29,65535,0,0,-1737,32.2,5,59,94,13200,4000,0x0282,0x40,1666,1745,4411,3077,0x08,0x0840,0x00,0x01,1742,0,-273.2,97,23,2114,198,23,1004,0,0,0,0,0,0,682,SUCCESS
    38,2019-04-26 11:33:19,152.022,0x0000,35.6,11328,0x0001,-9207,4401,7488,-9190,29,65535,0,0,-1737,32.3,5,59,94,13200,4000,0x0282,0x40,1656,1745,4401,3077,0x08,0x0840,0x00,0x01,1738,0,-273.2,97,23,2118,198,23,1004,0,0,0,0,0,0,682,SUCCESS
    39,2019-04-26 11:33:23,156.022,0x0000,35.7,11322,0x0001,-9209,4391,7488,-9195,29,65535,0,0,-1738,32.4,5,59,94,13200,4000,0x0282,0x40,1645,1745,4391,3077,0x08,0x0840,0x00,0x01,1734,0,-273.2,97,23,2122,198,23,1004,0,0,0,0,0,0,775,SUCCESS
    40,2019-04-26 11:33:27,160.023,0x0000,35.8,11322,0x0001,-9212,4381,7488,-9199,29,65535,0,0,-1738,32.5,5,59,94,13200,4000,0x0282,0x40,1635,1745,4381,3077,0x08,0x0840,0x00,0x01,1730,0,-273.2,97,23,2126,198,23,1004,0,0,0,0,0,0,686,SUCCESS
    41,2019-04-26 11:33:31,164.024,0x0000,35.9,11322,0x0001,-9215,4370,7488,-9202,28,65535,0,0,-1738,32.6,5,59,94,13200,4000,0x0282,0x40,1625,1745,4370,3077,0x08,0x0840,0x00,0x01,1726,0,-273.2,97,23,2130,198,23,1004,0,0,0,0,0,0,684,SUCCESS
    42,2019-04-26 11:33:35,168.024,0x0000,36.0,11316,0x0001,-9217,4360,7488,-9206,28,65535,0,0,-1738,32.7,5,59,94,13200,4000,0x0282,0x40,1615,1745,4360,3077,0x08,0x0840,0x00,0x01,1722,0,-273.2,97,23,2134,198,23,1004,0,0,0,0,0,0,714,SUCCESS
    43,2019-04-26 11:33:39,172.024,0x0000,36.1,11310,0x0001,-9220,4350,7488,-9209,28,65535,0,0,-1738,32.8,5,59,94,13200,4000,0x0282,0x40,1605,1745,4350,3077,0x08,0x0840,0x00,0x01,1718,0,-273.2,97,23,2138,198,23,1004,0,0,0,0,0,0,770,SUCCESS
    44,2019-04-26 11:33:43,176.025,0x0000,36.3,11310,0x0001,-9222,4342,7488,-9212,28,65535,0,0,-1738,32.9,5,58,94,13200,4000,0x0282,0x40,1594,1745,4340,3077,0x08,0x0840,0x00,0x01,1714,0,-273.2,97,23,2142,198,23,1004,0,0,0,0,0,0,719,SUCCESS
    45,2019-04-26 11:33:47,180.026,0x0000,36.4,11304,0x0001,-9223,4332,7488,-9215,28,65535,0,0,-1738,33.0,5,58,94,13200,4000,0x0282,0x40,1584,1745,4329,3077,0x08,0x0840,0x00,0x01,1710,0,-273.2,97,23,2146,198,23,1004,0,0,0,0,0,0,699,SUCCESS
    46,2019-04-26 11:33:51,184.027,0x0000,36.5,11298,0x0001,-9225,4322,7488,-9217,28,65535,0,0,-1738,33.1,5,58,94,13200,4000,0x0282,0x40,1574,1745,4319,3077,0x08,0x0840,0x00,0x01,1706,0,-273.2,97,23,2150,198,23,1004,0,0,0,0,0,0,714,SUCCESS
    47,2019-04-26 11:33:55,188.028,0x0000,36.6,11298,0x0001,-9227,4311,7488,-9220,28,65535,0,0,-1738,33.2,5,58,94,13200,4000,0x0282,0x40,1564,1745,4309,3077,0x08,0x0840,0x00,0x01,1702,0,-273.2,97,23,2154,198,23,1004,0,0,0,0,0,0,679,SUCCESS
    48,2019-04-26 11:33:59,192.028,0x0000,36.7,11292,0x0001,-9230,4301,7488,-9222,28,65535,0,0,-1737,33.2,5,58,94,13200,4000,0x0282,0x40,1553,1745,4299,3077,0x08,0x0840,0x00,0x01,1698,0,-273.2,97,23,2158,198,23,1004,0,0,0,0,0,0,760,SUCCESS
    49,2019-04-26 11:34:03,196.029,0x0000,36.8,11292,0x0001,-9232,4291,7488,-9224,28,65535,0,0,-1737,33.3,5,58,94,13200,4000,0x0282,0x40,1543,1745,4288,3077,0x08,0x0840,0x00,0x01,1694,0,-273.2,97,23,2162,198,23,1004,0,0,0,0,0,0,673,SUCCESS
    50,2019-04-26 11:34:07,200.030,0x0000,36.9,11286,0x0001,-9233,4281,7488,-9226,28,65535,0,0,-1737,33.4,5,58,94,13200,4000,0x0282,0x40,1533,1745,4278,3077,0x08,0x0840,0x00,0x01,1690,0,-273.2,97,23,2166,198,23,1004,0,0,0,0,0,0,706,SUCCESS
    51,2019-04-26 11:34:11,204.030,0x0000,37.0,11280,0x0001,-9235,4270,7488,-9228,28,65535,0,0,-1737,33.5,5,57,94,13200,4000,0x0282,0x40,1522,1745,4268,3077,0x08,0x0840,0x00,0x01,1686,0,-273.2,97,23,2170,198,23,1004,0,0,0,0,0,0,691,SUCCESS
    52,2019-04-26 11:34:15,208.031,0x0000,37.1,11280,0x0001,-9236,4260,7488,-9230,28,65535,0,0,-1737,33.6,5,57,94,13200,4000,0x0282,0x40,1512,1745,4258,3077,0x08,0x0840,0x00,0x01,1682,0,-273.2,97,23,2174,198,23,1004,0,0,0,0,0,0,695,SUCCESS
    53,2019-04-26 11:34:19,212.032,0x0000,37.2,11274,0x0001,-9238,4250,7488,-9232,28,65535,0,0,-1737,33.7,5,57,94,13200,4000,0x0282,0x40,1502,1745,4247,3077,0x08,0x0840,0x00,0x01,1678,0,-273.2,97,23,2178,198,23,1004,0,0,0,0,0,0,711,SUCCESS
    54,2019-04-26 11:34:23,216.032,0x0000,37.3,11268,0x0001,-9239,4240,7488,-9233,28,65535,0,0,-1736,33.7,5,57,94,13200,4000,0x0282,0x40,1492,1745,4237,3077,0x08,0x0840,0x00,0x01,1674,0,-273.2,97,23,2182,198,23,1004,0,0,0,0,0,0,693,SUCCESS
    55,2019-04-26 11:34:27,220.033,0x0000,37.3,11268,0x0001,-9241,4229,7488,-9235,27,65535,0,0,-1736,33.8,5,57,94,13200,4000,0x0282,0x40,1481,1745,4227,3077,0x08,0x0840,0x00,0x01,1670,0,-273.2,97,23,2186,198,23,1004,0,0,0,0,0,0,695,SUCCESS
    56,2019-04-26 11:34:31,224.033,0x0000,37.4,11262,0x0001,-9243,4219,7488,-9237,27,65535,0,0,-1736,33.9,5,57,94,13200,4000,0x0282,0x40,1471,1745,4217,3077,0x08,0x0840,0x00,0x01,1666,0,-273.2,97,23,2190,198,23,1004,0,0,0,0,0,0,690,SUCCESS
    57,2019-04-26 11:34:35,228.034,0x0000,37.5,11256,0x0001,-9244,4209,7488,-9238,27,65535,0,0,-1736,34.0,5,57,94,13200,4000,0x0282,0x40,1461,1745,4206,3077,0x08,0x0840,0x00,0x01,1662,0,-273.2,97,23,2194,198,23,1004,0,0,0,0,0,0,717,SUCCESS
    58,2019-04-26 11:34:39,232.035,0x0000,37.6,11256,0x0001,-9246,4199,7488,-9240,27,65535,0,0,-1735,34.1,5,57,94,13200,4000,0x0282,0x40,1451,1745,4196,3077,0x08,0x0840,0x00,0x01,1658,0,-273.2,97,23,2198,198,23,1004,0,0,0,0,0,0,723,SUCCESS
    59,2019-04-26 11:34:43,236.035,0x0000,37.7,11256,0x0001,-9247,4188,7488,-9242,27,65535,0,0,-1735,34.1,5,56,94,13200,4000,0x0282,0x40,1440,1745,4186,3077,0x08,0x0840,0x00,0x01,1654,0,-273.2,97,23,2202,198,23,1004,0,0,0,0,0,0,690,SUCCESS
    60,2019-04-26 11:34:47,240.036,0x0000,37.8,11250,0x0001,-9248,4178,7488,-9243,27,65535,0,0,-1735,34.2,5,56,94,13200,4000,0x0282,0x40,1430,1745,4175,3077,0x08,0x0840,0x00,0x01,1650,0,-273.2,97,23,2206,198,23,1004,0,0,0,0,0,0,693,SUCCESS
    61,2019-04-26 11:34:51,244.036,0x0000,37.9,11250,0x0001,-9249,4168,7488,-9245,27,65535,0,0,-1735,34.3,5,56,94,13200,4000,0x0282,0x40,1420,1745,4165,3077,0x08,0x0840,0x00,0x01,1646,0,-273.2,97,23,2210,198,23,1004,0,0,0,0,0,0,739,SUCCESS
    62,2019-04-26 11:34:55,248.037,0x0000,38.0,11244,0x0001,-9251,4157,7488,-9246,27,65535,0,0,-1734,34.3,5,56,94,13200,4000,0x0282,0x40,1409,1745,4155,3077,0x08,0x0840,0x00,0x01,1642,0,-273.2,97,23,2214,198,23,1004,0,0,0,0,0,0,682,SUCCESS
    63,2019-04-26 11:34:59,252.037,0x0000,38.0,11238,0x0001,-9251,4147,7488,-9247,27,65535,0,0,-1734,34.4,5,56,94,13200,4000,0x0282,0x40,1399,1745,4145,3077,0x08,0x0840,0x00,0x01,1638,0,-273.2,97,23,2218,198,23,1004,0,0,0,0,0,0,682,SUCCESS
    64,2019-04-26 11:35:03,256.038,0x0000,38.1,11238,0x0001,-9253,4137,7488,-9248,27,65535,0,0,-1734,34.5,5,56,94,13200,4000,0x0282,0x40,1389,1745,4134,3077,0x08,0x0840,0x00,0x01,1634,0,-273.2,97,23,2222,198,23,1004,0,0,0,0,0,0,682,SUCCESS
    65,2019-04-26 11:35:07,260.038,0x0000,38.2,11232,0x0001,-9253,4127,7488,-9250,27,65535,0,0,-1734,34.5,5,56,94,13200,4000,0x0282,0x40,1379,1745,4124,3077,0x08,0x0840,0x00,0x01,1630,0,-273.2,97,23,2226,198,23,1004,0,0,0,0,0,0,684,SUCCESS
    66,2019-04-26 11:35:11,264.039,0x0000,38.2,11226,0x0001,-9254,4116,7488,-9251,27,65535,0,0,-1733,34.6,5,55,94,13200,4000,0x0282,0x40,1368,1745,4114,3077,0x08,0x0840,0x00,0x01,1626,0,-273.2,97,23,2230,198,23,1004,0,0,0,0,0,0,684,SUCCESS
    67,2019-04-26 11:35:15,268.039,0x0000,38.3,11226,0x0001,-9256,4106,7488,-9252,27,65535,0,0,-1733,34.7,5,55,94,13200,4000,0x0282,0x40,1358,1745,4103,3077,0x08,0x0840,0x00,0x01,1622,0,-273.2,97,23,2234,198,23,1004,0,0,0,0,0,0,683,SUCCESS
    68,2019-04-26 11:35:19,272.040,0x0000,38.3,11220,0x0001,-9257,4096,7488,-9253,27,65535,0,0,-1733,34.7,5,55,94,13200,4000,0x0282,0x40,1348,1745,4093,3077,0x08,0x0840,0x00,0x01,1618,0,-273.2,97,23,2238,198,23,1004,0,0,0,0,0,0,684,SUCCESS
    69,2019-04-26 11:35:23,276.040,0x0000,38.4,11214,0x0001,-9257,4085,7488,-9254,26,65535,0,0,-1732,34.8,5,55,94,13200,4000,0x0282,0x40,1338,1745,4083,3077,0x08,0x0840,0x00,0x01,1614,0,-273.2,97,23,2242,198,23,1004,0,0,0,0,0,0,688,SUCCESS
    70,2019-04-26 11:35:27,280.041,0x0000,38.5,11214,0x0001,-9258,4075,7488,-9255,26,65535,0,0,-1732,34.9,5,55,94,13200,4000,0x0282,0x40,1330,1745,4073,3077,0x08,0x0840,0x00,0x01,1610,0,-273.2,97,23,2246,198,23,1004,0,0,0,0,0,0,683,SUCCESS
    71,2019-04-26 11:35:31,284.041,0x0000,38.5,11208,0x0001,-9259,4065,7488,-9256,26,65535,0,0,-1731,34.9,5,55,94,13200,4000,0x0282,0x40,1320,1745,4062,3077,0x08,0x0840,0x00,0x01,1606,0,-273.2,97,23,2250,198,23,1004,0,0,0,0,0,0,686,SUCCESS
    72,2019-04-26 11:35:35,288.042,0x0000,38.6,11208,0x0001,-9260,4055,7488,-9257,26,65535,0,0,-1731,35.0,5,55,94,13200,4000,0x0282,0x40,1309,1745,4052,3077,0x08,0x0840,0x00,0x01,1602,0,-273.2,97,23,2254,198,23,1004,0,0,0,0,0,0,682,SUCCESS
    73,2019-04-26 11:35:39,292.042,0x0000,38.7,11202,0x0001,-9261,4044,7488,-9258,26,65535,0,0,-1731,35.0,5,55,94,13200,4000,0x0282,0x40,1299,1745,4044,3077,0x08,0x0840,0x00,0x01,1598,0,-273.2,97,23,2258,198,23,1004,0,0,0,0,0,0,684,SUCCESS
    74,2019-04-26 11:35:43,296.043,0x0000,38.8,11202,0x0001,-9262,4034,7488,-9259,26,65535,0,0,-1730,35.1,5,54,94,13200,4000,0x0282,0x40,1289,1745,4034,3077,0x08,0x0840,0x00,0x01,1594,0,-273.2,97,23,2262,198,23,1004,0,0,0,0,0,0,683,SUCCESS
    75,2019-04-26 11:35:47,300.044,0x0000,38.8,11196,0x0001,-9262,4024,7488,-9259,26,65535,0,0,-1730,35.1,5,54,94,13200,4000,0x0282,0x40,1278,1745,4024,3077,0x08,0x0840,0x00,0x01,1590,0,-273.2,97,23,2266,198,23,1004,0,0,0,0,0,0,682,SUCCESS
    76,2019-04-26 11:35:51,304.045,0x0000,38.9,11196,0x0001,-9264,4013,7488,-9260,26,65535,0,0,-1729,35.2,5,54,94,13200,4000,0x0282,0x40,1268,1745,4013,3077,0x08,0x0840,0x00,0x01,1586,0,-273.2,97,23,2270,198,23,1004,0,0,0,0,0,0,681,SUCCESS
    77,2019-04-26 11:35:55,308.045,0x0000,38.9,11190,0x0001,-9264,4003,7488,-9261,26,65535,0,0,-1729,35.2,5,54,94,13200,4000,0x0282,0x40,1255,1745,4001,3077,0x08,0x0840,0x00,0x01,1582,0,-273.2,97,23,2274,198,23,1004,0,0,0,0,0,0,1380,SUCCESS
    78,2019-04-26 11:35:59,312.046,0x0000,39.0,11184,0x0001,-9264,3993,7488,-9262,26,65535,0,0,-1729,35.3,5,54,94,13200,4000,0x0282,0x40,1245,1745,3990,3077,0x08,0x0840,0x00,0x01,1578,0,-273.2,97,23,2278,198,23,1004,0,0,0,0,0,0,1214,SUCCESS
    79,2019-04-26 11:36:03,316.046,0x0000,39.0,11184,0x0001,-9265,3983,7488,-9263,26,65535,0,0,-1728,35.3,5,54,94,13200,4000,0x0282,0x40,1235,1745,3980,3077,0x08,0x0840,0x00,0x01,1574,0,-273.2,97,23,2282,198,23,1004,0,0,0,0,0,0,864,SUCCESS
    80,2019-04-26 11:36:07,320.047,0x0000,39.1,11178,0x0001,-9266,3972,7488,-9263,26,65535,0,0,-1728,35.4,5,54,94,13200,4000,0x0282,0x40,1227,1745,3972,3077,0x08,0x0840,0x00,0x01,1570,0,-273.2,97,23,2286,198,23,1004,0,0,0,0,0,0,678,SUCCESS
    81,2019-04-26 11:36:11,324.048,0x0000,39.1,11172,0x0001,-9267,3962,7488,-9264,26,65535,0,0,-1727,35.5,5,53,94,13200,4000,0x0282,0x40,1217,1745,3962,3077,0x08,0x0840,0x00,0x01,1567,0,-273.2,97,23,2290,198,23,1004,0,0,0,0,0,0,676,SUCCESS
    82,2019-04-26 11:36:15,328.048,0x0000,39.2,11172,0x0001,-9268,3952,7488,-9265,26,65535,0,0,-1727,35.5,5,53,94,13200,4000,0x0282,0x40,1206,1745,3952,3077,0x08,0x0840,0x00,0x01,1563,0,-273.2,97,23,2294,198,23,1004,0,0,0,0,0,0,677,SUCCESS
    83,2019-04-26 11:36:19,332.049,0x0000,39.2,11166,0x0001,-9268,3941,7488,-9266,26,65535,0,0,-1727,35.6,5,53,94,13200,4000,0x0282,0x40,1196,1745,3941,3077,0x08,0x0840,0x00,0x01,1559,0,-273.2,97,23,2298,198,23,1004,0,0,0,0,0,0,693,SUCCESS
    84,2019-04-26 11:36:23,336.050,0x0000,39.3,11160,0x0001,-9269,3931,7488,-9266,25,65535,0,0,-1726,35.6,5,53,94,13200,4000,0x0282,0x40,1186,1745,3931,3077,0x08,0x0840,0x00,0x01,1555,0,-273.2,97,23,2301,198,23,1004,0,0,0,0,0,0,689,SUCCESS
    85,2019-04-26 11:36:27,340.050,0x0000,39.3,11160,0x0001,-9269,3921,7488,-9267,25,65535,0,0,-1726,35.6,5,53,94,13200,4000,0x0282,0x40,1175,1745,3921,3077,0x08,0x0840,0x00,0x01,1551,0,-273.2,97,23,2305,198,23,1004,0,0,0,0,0,0,689,SUCCESS
    86,2019-04-26 11:36:31,344.051,0x0000,39.4,11154,0x0001,-9270,3910,7488,-9268,25,65535,0,0,-1725,35.7,5,53,94,13200,4000,0x0282,0x40,1165,1745,3910,3077,0x08,0x0840,0x00,0x01,1547,0,-273.2,97,23,2309,198,23,1004,0,0,0,0,0,0,689,SUCCESS
    87,2019-04-26 11:36:35,348.051,0x0000,39.5,11154,0x0001,-9271,3900,7488,-9268,25,65535,0,0,-1725,35.7,5,53,94,13200,4000,0x0282,0x40,1155,1745,3900,3077,0x08,0x0840,0x00,0x01,1543,0,-273.2,97,23,2313,198,23,1004,0,0,0,0,0,0,690,SUCCESS
    88,2019-04-26 11:36:39,352.052,0x0000,39.5,11154,0x0001,-9271,3890,7488,-9269,25,65535,0,0,-1724,35.8,5,52,94,13200,4000,0x0282,0x40,1144,1745,3890,3077,0x08,0x0840,0x00,0x01,1539,0,-273.2,97,23,2317,198,23,1004,0,0,0,0,0,0,692,SUCCESS
    89,2019-04-26 11:36:43,356.052,0x0000,39.5,11148,0x0001,-9272,3880,7488,-9270,25,65535,0,0,-1724,35.8,5,52,94,13200,4000,0x0282,0x40,1134,1745,3880,3077,0x08,0x0840,0x00,0x01,1535,0,-273.2,97,23,2321,198,23,1004,0,0,0,0,0,0,707,SUCCESS
    90,2019-04-26 11:36:47,360.052,0x0000,39.6,11142,0x0001,-9272,3869,7488,-9270,25,65535,0,0,-1724,35.9,5,52,94,13200,4000,0x0282,0x40,1124,1745,3869,3077,0x08,0x0840,0x00,0x01,1531,0,-273.2,97,23,2325,198,23,1004,0,0,0,0,0,0,694,SUCCESS
    91,2019-04-26 11:36:51,364.053,0x0000,39.6,11142,0x0001,-9273,3859,7488,-9271,25,65535,0,0,-1723,35.9,5,52,94,13200,4000,0x0282,0x40,1114,1745,3859,3077,0x08,0x0840,0x00,0x01,1527,0,-273.2,97,23,2329,198,23,1004,0,0,0,0,0,0,707,SUCCESS
    92,2019-04-26 11:36:55,368.054,0x0000,39.7,11136,0x0001,-9273,3849,7488,-9271,25,65535,0,0,-1723,36.0,5,52,94,13200,4000,0x0282,0x40,1103,1745,3849,3077,0x08,0x0840,0x00,0x01,1523,0,-273.2,97,23,2333,198,23,1004,0,0,0,0,0,0,721,SUCCESS
    93,2019-04-26 11:36:59,372.054,0x0000,39.7,11130,0x0001,-9274,3838,7488,-9272,25,65535,0,0,-1722,36.0,5,52,94,13200,4000,0x0282,0x40,1093,1745,3838,3077,0x08,0x0840,0x00,0x01,1519,0,-273.2,97,23,2337,198,23,1004,0,0,0,0,0,0,725,SUCCESS
    94,2019-04-26 11:37:03,376.055,0x0000,39.8,11130,0x0001,-9274,3828,7488,-9272,25,65535,0,0,-1722,36.0,5,52,94,13200,4000,0x0282,0x40,1083,1745,3828,3077,0x08,0x0840,0x00,0x01,1515,0,-273.2,97,23,2341,198,23,1004,0,0,0,0,0,0,690,SUCCESS
    95,2019-04-26 11:37:07,380.056,0x0000,39.8,11118,0x0001,-9275,3818,7488,-9273,25,65535,0,0,-1721,36.1,5,51,94,13200,4000,0x0282,0x40,1070,1745,3815,3077,0x08,0x0840,0x00,0x01,1510,0,-273.2,97,23,2346,198,23,1004,0,0,0,0,0,0,2031,SUCCESS
    96,2019-04-26 11:37:11,384.057,0x0000,39.9,11118,0x0001,-9275,3807,7488,-9273,25,65535,0,0,-1721,36.1,5,51,94,13200,4000,0x0282,0x40,1062,1745,3807,3077,0x08,0x0840,0x00,0x01,1507,0,-273.2,97,23,2349,198,23,1004,0,0,0,0,0,0,881,SUCCESS
    97,2019-04-26 11:37:15,388.058,0x0000,39.9,11118,0x0001,-9275,3797,7488,-9274,25,65535,0,0,-1720,36.2,5,51,94,13200,4000,0x0282,0x40,1052,1745,3797,3077,0x08,0x0840,0x00,0x01,1503,0,-273.2,97,23,2353,198,23,1004,0,0,0,0,0,0,765,SUCCESS
    98,2019-04-26 11:37:19,392.059,0x0000,39.9,11112,0x0001,-9276,3787,7488,-9274,25,65535,0,0,-1720,36.2,5,51,94,13200,4000,0x0282,0x40,1041,1745,3787,3077,0x08,0x0840,0x00,0x01,1499,0,-273.2,97,23,2357,198,23,1004,0,0,0,0,0,0,715,SUCCESS
    99,2019-04-26 11:37:23,396.059,0x0000,40.0,11112,0x0001,-9276,3776,7488,-9275,24,65535,0,0,-1719,36.2,5,51,94,13200,4000,0x0282,0x40,1031,1745,3776,3077,0x08,0x0840,0x00,0x01,1495,0,-273.2,97,23,2361,198,23,1004,0,0,0,0,0,0,734,SUCCESS
    100,2019-04-26 11:37:27,400.060,0x0000,40.0,11106,0x0001,-9277,3766,7488,-9275,24,65535,0,0,-1719,36.3,5,51,94,13200,4000,0x0282,0x40,1021,1745,3766,3077,0x08,0x0840,0x00,0x01,1491,0,-273.2,97,23,2365,198,23,1004,0,0,0,0,0,0,687,SUCCESS
    101,2019-04-26 11:37:31,404.060,0x0000,40.1,11100,0x0001,-9277,3756,7488,-9276,24,65535,0,0,-1718,36.3,5,51,94,13200,4000,0x0282,0x40,1011,1745,3756,3077,0x08,0x0840,0x00,0x01,1487,0,-273.2,97,23,2369,198,23,1004,0,0,0,0,0,0,703,SUCCESS
    102,2019-04-26 11:37:35,408.060,0x0000,40.1,11100,0x0001,-9277,3746,7488,-9276,24,65535,0,0,-1718,36.4,5,51,94,13200,4000,0x0282,0x40,1000,1745,3746,3077,0x08,0x0840,0x00,0x01,1483,0,-273.2,97,23,2373,198,23,1004,0,0,0,0,0,0,700,SUCCESS
    103,2019-04-26 11:37:39,412.061,0x0000,40.1,11094,0x0001,-9278,3735,7488,-9276,24,65535,0,0,-1717,36.4,5,50,94,13200,4000,0x0282,0x40,990,1745,3735,3077,0x08,0x0840,0x00,0x01,1479,0,-273.2,97,23,2377,198,23,1004,0,0,0,0,0,0,708,SUCCESS
    104,2019-04-26 11:37:43,416.061,0x0000,40.1,11088,0x0001,-9278,3728,7488,-9277,24,65535,0,0,-1717,36.4,5,50,94,13200,4000,0x0282,0x40,980,1745,3725,3077,0x08,0x0840,0x00,0x01,1475,0,-273.2,97,23,2381,198,23,1004,0,0,0,0,0,0,710,SUCCESS
    105,2019-04-26 11:37:47,420.062,0x0000,40.2,11088,0x0001,-9278,3717,7488,-9277,24,65535,0,0,-1716,36.4,5,50,94,13200,4000,0x0282,0x40,969,1745,3715,3077,0x08,0x0840,0x00,0x01,1471,0,-273.2,97,23,2385,198,23,1004,0,0,0,0,0,0,705,SUCCESS
    106,2019-04-26 11:37:51,424.062,0x0000,40.2,11082,0x0001,-9279,3707,7488,-9277,24,65535,0,0,-1716,36.5,5,50,94,13200,4000,0x0282,0x40,959,1745,3704,3077,0x08,0x0840,0x00,0x01,1467,0,-273.2,97,23,2389,198,23,1004,0,0,0,0,0,0,686,SUCCESS
    107,2019-04-26 11:37:55,428.062,0x0000,40.3,11076,0x0001,-9279,3697,7488,-9278,24,65535,0,0,-1715,36.5,5,50,94,13200,4000,0x0282,0x40,949,1745,3694,3077,0x08,0x0840,0x00,0x01,1463,0,-273.2,97,23,2393,198,23,1004,0,0,0,0,0,0,685,SUCCESS
    108,2019-04-26 11:37:59,432.063,0x0000,40.3,11076,0x0001,-9279,3686,7488,-9278,24,65535,0,0,-1715,36.5,5,50,94,13200,4000,0x0282,0x40,938,1745,3684,3077,0x08,0x0840,0x00,0x01,1459,0,-273.2,97,23,2397,198,23,1004,0,0,0,0,0,0,683,SUCCESS
    109,2019-04-26 11:38:03,436.064,0x0000,40.3,11070,0x0001,-9280,3676,7488,-9278,24,65535,0,0,-1714,36.6,5,50,94,13200,4000,0x0282,0x40,928,1745,3673,3077,0x08,0x0840,0x00,0x01,1455,0,-273.2,97,23,2401,198,23,1004,0,0,0,0,0,0,686,SUCCESS
    110,2019-04-26 11:38:07,440.065,0x0000,40.3,11064,0x0001,-9280,3666,7488,-9279,24,65535,0,0,-1713,36.6,5,49,94,13200,4000,0x0282,0x40,918,1745,3663,3077,0x08,0x0840,0x00,0x01,1451,0,-273.2,97,23,2405,198,23,1004,0,0,0,0,0,0,687,SUCCESS
    111,2019-04-26 11:38:11,444.065,0x0000,40.4,11064,0x0001,-9280,3655,7488,-9279,24,65535,0,0,-1713,36.7,5,49,94,13200,4000,0x0282,0x40,907,1745,3653,3077,0x08,0x0840,0x00,0x01,1447,0,-273.2,97,23,2409,198,23,1004,0,0,0,0,0,0,687,SUCCESS
    112,2019-04-26 11:38:15,448.066,0x0000,40.4,11058,0x0001,-9280,3645,7488,-9279,24,65535,0,0,-1712,36.7,5,49,94,13200,4000,0x0282,0x40,897,1745,3642,3077,0x08,0x0840,0x00,0x01,1443,0,-273.2,97,23,2413,198,23,1004,0,0,0,0,0,0,745,SUCCESS
    113,2019-04-26 11:38:19,452.066,0x0000,40.4,11058,0x0001,-9281,3635,7488,-9280,24,65535,0,0,-1712,36.7,5,49,94,13200,4000,0x0282,0x40,887,1745,3632,3077,0x08,0x0840,0x00,0x01,1439,0,-273.2,97,23,2417,198,23,1004,0,0,0,0,0,0,775,SUCCESS
    114,2019-04-26 11:38:23,456.067,0x0000,40.5,11052,0x0001,-9281,3624,7488,-9280,23,65535,0,0,-1711,36.7,5,49,94,13200,4000,0x0282,0x40,876,1745,3622,3077,0x08,0x0840,0x00,0x01,1435,0,-273.2,97,23,2421,198,23,1004,0,0,0,0,0,0,751,SUCCESS
    115,2019-04-26 11:38:27,460.067,0x0000,40.5,11046,0x0001,-9282,3614,7488,-9280,23,65535,0,0,-1711,36.8,5,49,94,13200,4000,0x0282,0x40,866,1745,3612,3077,0x08,0x0840,0x00,0x01,1431,0,-273.2,97,23,2425,198,23,1004,0,0,0,0,0,0,701,SUCCESS
    116,2019-04-26 11:38:31,464.068,0x0000,40.6,11046,0x0001,-9282,3604,7488,-9281,23,65535,0,0,-1710,36.8,5,49,94,13200,4000,0x0282,0x40,856,1745,3601,3077,0x08,0x0840,0x00,0x01,1427,0,-273.2,97,23,2429,198,23,1004,0,0,0,0,0,0,721,SUCCESS
    117,2019-04-26 11:38:35,468.069,0x0000,40.6,11040,0x0001,-9282,3593,7488,-9281,23,65535,0,0,-1710,36.8,5,48,94,13200,4000,0x0282,0x40,846,1745,3591,3077,0x08,0x0840,0x00,0x01,1423,0,-273.2,97,23,2433,198,23,1004,0,0,0,0,0,0,822,SUCCESS
    118,2019-04-26 11:38:39,472.070,0x0000,40.7,11034,0x0001,-9282,3583,7488,-9281,23,65535,0,0,-1709,36.9,5,48,94,13200,4000,0x0282,0x40,835,1745,3581,3077,0x08,0x0840,0x00,0x01,1419,0,-273.2,97,23,2437,198,23,1004,0,0,0,0,0,0,797,SUCCESS
    119,2019-04-26 11:38:43,476.071,0x0000,40.7,11034,0x0001,-9283,3573,7488,-9282,23,65535,0,0,-1709,36.9,5,48,94,13200,4000,0x0282,0x40,827,1745,3573,3077,0x08,0x0840,0x00,0x01,1415,0,-273.2,97,23,2441,198,23,1004,0,0,0,0,0,0,692,SUCCESS
    120,2019-04-26 11:38:47,480.072,0x0000,40.7,11028,0x0001,-9283,3563,7488,-9282,23,65535,0,0,-1708,36.9,5,48,94,13200,4000,0x0282,0x40,817,1745,3560,3077,0x08,0x0840,0x00,0x01,1411,0,-273.2,97,23,2445,198,23,1004,0,0,0,0,0,0,769,SUCCESS
    121,2019-04-26 11:38:51,484.072,0x0000,40.7,11022,0x0001,-9283,3552,7488,-9282,23,65535,0,0,-1707,37.0,5,48,94,13200,4000,0x0282,0x40,807,1745,3552,3077,0x08,0x0840,0x00,0x01,1407,0,-273.2,97,23,2449,198,23,1004,0,0,0,0,0,0,711,SUCCESS
    122,2019-04-26 11:38:55,488.073,0x0000,40.7,11022,0x0001,-9283,3542,7488,-9282,23,65535,0,0,-1707,37.0,5,48,94,13200,4000,0x0282,0x40,797,1745,3542,3077,0x08,0x0840,0x00,0x01,1403,0,-273.2,97,23,2453,198,23,1004,0,0,0,0,0,0,693,SUCCESS
    123,2019-04-26 11:38:59,492.073,0x0000,40.8,11016,0x0001,-9283,3532,7488,-9283,23,65535,0,0,-1706,37.0,5,48,94,13200,4000,0x0282,0x40,786,1745,3532,3077,0x08,0x0840,0x00,0x01,1399,0,-273.2,97,23,2457,198,23,1004,0,0,0,0,0,0,711,SUCCESS
    124,2019-04-26 11:39:03,496.074,0x0000,40.8,11016,0x0001,-9284,3521,7488,-9283,23,65535,0,0,-1706,37.0,5,48,94,13200,4000,0x0282,0x40,776,1745,3521,3077,0x08,0x0840,0x00,0x01,1395,0,-273.2,97,23,2461,198,23,1004,0,0,0,0,0,0,695,SUCCESS
    125,2019-04-26 11:39:07,500.074,0x0000,40.8,11004,0x0001,-9284,3511,7488,-9283,23,65535,0,0,-1705,37.1,5,47,94,13200,4000,0x0282,0x40,766,1745,3511,3077,0x08,0x0840,0x00,0x01,1392,0,-273.2,97,23,2465,198,23,1004,0,0,0,0,0,0,695,SUCCESS
    126,2019-04-26 11:39:11,504.075,0x0000,40.8,11004,0x0001,-9285,3501,7488,-9283,23,65535,0,0,-1705,37.1,5,47,94,13200,4000,0x0282,0x40,755,1745,3501,3077,0x08,0x0840,0x00,0x01,1388,0,-273.2,97,23,2469,198,23,1004,0,0,0,0,0,0,707,SUCCESS
    127,2019-04-26 11:39:15,508.076,0x0000,40.8,10998,0x0001,-9285,3490,7488,-9284,23,65535,0,0,-1704,37.1,5,47,94,13200,4000,0x0282,0x40,745,1745,3490,3077,0x08,0x0840,0x00,0x01,1384,0,-273.2,97,23,2472,198,23,1004,0,0,0,0,0,0,693,SUCCESS
    128,2019-04-26 11:39:19,512.077,0x0000,40.9,10992,0x0001,-9285,3480,7488,-9284,22,65535,0,0,-1704,37.1,5,47,94,13200,4000,0x0282,0x40,735,1745,3480,3077,0x08,0x0840,0x00,0x01,1380,0,-273.2,97,23,2476,198,23,1004,0,0,0,0,0,0,705,SUCCESS
    129,2019-04-26 11:39:23,516.078,0x0000,40.9,10992,0x0001,-9285,3470,7488,-9284,22,65535,0,0,-1703,37.2,5,47,94,13200,4000,0x0282,0x40,724,1745,3470,3077,0x08,0x0840,0x00,0x01,1376,0,-273.2,97,23,2480,198,23,1004,0,0,0,0,0,0,719,SUCCESS
    130,2019-04-26 11:39:27,520.078,0x0000,40.9,10986,0x0001,-9285,3459,7488,-9284,22,65535,0,0,-1702,37.2,5,47,94,13200,4000,0x0282,0x40,714,1745,3459,3077,0x08,0x0840,0x00,0x01,1372,0,-273.2,97,23,2484,198,23,1004,0,0,0,0,0,0,691,SUCCESS
    131,2019-04-26 11:39:31,524.079,0x0000,41.0,10980,0x0001,-9286,3450,7488,-9285,22,65535,0,0,-1702,37.2,5,47,94,13200,4000,0x02C2,0x40,704,1745,3450,8000,0x08,0x0840,0x00,0x01,1368,0,-273.2,97,23,2488,198,23,1004,0,0,0,0,0,0,704,SUCCESS
    132,2019-04-26 11:39:35,528.079,0x0000,41.0,10980,0x0001,-9286,3441,7488,-9285,22,65535,0,0,-1701,37.2,5,46,94,13200,4000,0x02C2,0x40,693,1745,3441,8000,0x08,0x0840,0x00,0x01,1364,0,-273.2,97,23,2492,198,23,1004,0,0,0,0,0,0,679,SUCCESS
    133,2019-04-26 11:39:39,532.080,0x0000,41.0,10974,0x0001,-9286,3432,7488,-9285,22,65535,0,0,-1700,37.3,5,46,94,13200,4000,0x02C2,0x40,683,1745,3432,8000,0x08,0x0840,0x00,0x01,1360,0,-273.2,97,23,2496,198,23,1004,0,0,0,0,0,0,684,SUCCESS
    134,2019-04-26 11:39:43,536.080,0x0000,41.0,10968,0x0001,-9286,3423,7488,-9285,22,65535,0,0,-1700,37.3,5,46,94,13200,4000,0x02C2,0x40,673,1745,3423,8000,0x08,0x0840,0x00,0x01,1356,0,-273.2,97,23,2500,198,23,1004,0,0,0,0,0,0,679,SUCCESS
    135,2019-04-26 11:39:47,540.081,0x0000,41.1,10968,0x0001,-9286,3414,7488,-9286,22,65535,0,0,-1699,37.3,5,46,94,13200,4000,0x02C2,0x40,662,1745,3414,8000,0x08,0x0840,0x00,0x01,1352,0,-273.2,97,23,2504,198,23,1004,0,0,0,0,0,0,689,SUCCESS
    136,2019-04-26 11:39:51,544.081,0x0000,41.1,10962,0x0001,-9286,3405,7488,-9286,22,65535,0,0,-1699,37.3,5,46,94,13200,4000,0x02C2,0x40,652,1745,3405,8000,0x08,0x0840,0x00,0x01,1348,0,-273.2,97,23,2508,198,23,1004,0,0,0,0,0,0,735,SUCCESS
    137,2019-04-26 11:39:55,548.082,0x0000,41.1,10956,0x0001,-9287,3396,7488,-9286,22,65535,0,0,-1698,37.4,5,46,94,13200,4000,0x02C2,0x40,642,1745,3396,8000,0x08,0x0840,0x00,0x01,1344,0,-273.2,97,23,2512,198,23,1004,0,0,0,0,0,0,751,SUCCESS
    138,2019-04-26 11:39:59,552.082,0x0000,41.1,10950,0x0001,-9287,3388,7488,-9286,22,65535,0,0,-1698,37.4,5,46,94,13200,4000,0x02C2,0x40,631,1745,3388,8000,0x08,0x0840,0x00,0x01,1340,0,-273.2,97,23,2516,198,23,1004,0,0,0,0,0,0,737,SUCCESS
    139,2019-04-26 11:40:03,556.083,0x0000,41.1,10950,0x0001,-9287,3379,7488,-9287,22,65535,0,0,-1697,37.4,5,46,94,13200,4000,0x02C2,0x40,621,1745,3379,8000,0x08,0x0840,0x00,0x01,1336,0,-273.2,97,23,2520,198,23,1004,0,0,0,0,0,0,733,SUCCESS
    140,2019-04-26 11:40:07,560.084,0x0000,41.1,10944,0x0001,-9287,3370,7488,-9287,22,65535,0,0,-1696,37.4,5,46,94,13200,4000,0x02C2,0x40,611,1745,3370,8000,0x08,0x0840,0x00,0x01,1332,0,-273.2,97,23,2524,198,23,1004,0,0,0,0,0,0,715,SUCCESS
    141,2019-04-26 11:40:11,564.084,0x0000,41.2,10938,0x0001,-9287,3361,7488,-9287,22,65535,0,0,-1696,37.4,5,45,94,13200,4000,0x02C2,0x40,600,1745,3361,8000,0x08,0x0840,0x00,0x01,1328,0,-273.2,97,23,2528,198,23,1004,0,0,0,0,0,0,716,SUCCESS
    142,2019-04-26 11:40:15,568.085,0x0000,41.2,10938,0x0001,-9288,3352,7488,-9287,22,65535,0,0,-1695,37.4,5,45,94,13200,4000,0x02C2,0x40,590,1745,3352,8000,0x08,0x0840,0x00,0x01,1324,0,-273.2,97,23,2532,198,23,1004,0,0,0,0,0,0,716,SUCCESS
    143,2019-04-26 11:40:19,572.085,0x0000,41.2,10932,0x0001,-9288,3343,7488,-9287,22,65535,0,0,-1694,37.5,5,45,94,13200,4000,0x02C2,0x40,580,1745,3343,8000,0x08,0x0840,0x00,0x01,1320,0,-273.2,97,23,2536,198,23,1004,0,0,0,0,0,0,729,SUCCESS
    144,2019-04-26 11:40:23,576.086,0x0000,41.3,10926,0x0001,-9288,3334,7488,-9287,22,65535,0,0,-1694,37.5,5,45,94,13200,4000,0x02C2,0x40,570,1745,3334,8000,0x08,0x0840,0x00,0x01,1316,0,-273.2,97,23,2540,198,23,1004,0,0,0,0,0,0,693,SUCCESS
    145,2019-04-26 11:40:27,580.087,0x0000,41.3,10926,0x0001,-9288,3325,7488,-9288,21,65535,0,0,-1693,37.5,5,45,94,13200,4000,0x02C2,0x40,559,1745,3325,8000,0x08,0x0840,0x00,0x01,1312,0,-273.2,97,23,2544,198,23,1004,0,0,0,0,0,0,725,SUCCESS
    146,2019-04-26 11:40:31,584.087,0x0000,41.3,10920,0x0001,-9288,3316,7488,-9288,21,65535,0,0,-1693,37.5,5,45,94,13200,4000,0x02C2,0x40,549,1745,3316,8000,0x08,0x0840,0x00,0x01,1308,0,-273.2,97,23,2548,198,23,1004,0,0,0,0,0,0,721,SUCCESS
    147,2019-04-26 11:40:35,588.087,0x0000,41.3,10920,0x0001,-9288,3310,7488,-9288,21,65535,0,0,-1692,37.6,5,45,94,13200,4000,0x02C2,0x40,539,1745,3308,8000,0x08,0x0840,0x00,0x01,1304,0,-273.2,97,23,2552,198,23,1004,0,0,0,0,0,0,713,SUCCESS
    148,2019-04-26 11:40:39,592.088,0x0000,41.3,10914,0x0001,-9288,3301,7488,-9288,21,65535,0,0,-1691,37.6,5,45,94,13200,4000,0x02C2,0x40,528,1745,3299,8000,0x08,0x0840,0x00,0x01,1300,0,-273.2,97,23,2556,198,23,1004,0,0,0,0,0,0,694,SUCCESS
    149,2019-04-26 11:40:43,596.088,0x0000,41.3,10908,0x0001,-9289,3292,7488,-9288,21,65535,0,0,-1691,37.6,5,44,94,13200,4000,0x02C2,0x40,518,1745,3290,8000,0x08,0x0840,0x00,0x01,1296,0,-273.2,97,23,2560,198,23,1004,0,0,0,0,0,0,688,SUCCESS
    150,2019-04-26 11:40:47,600.088,0x0000,41.3,10902,0x0001,-9289,3283,7488,-9289,21,65535,0,0,-1690,37.6,5,44,94,13200,4000,0x02C2,0x40,508,1745,3281,8000,0x08,0x0840,0x00,0x01,1292,0,-273.2,97,23,2564,198,23,1004,0,0,0,0,0,0,736,SUCCESS
    151,2019-04-26 11:40:51,604.089,0x0000,41.3,10902,0x0001,-9289,3274,7488,-9289,21,65535,0,0,-1690,37.6,5,44,94,13200,4000,0x02C2,0x40,497,1745,3272,8000,0x08,0x0840,0x00,0x01,1288,0,-273.2,97,23,2568,198,23,1004,0,0,0,0,0,0,696,SUCCESS
    152,2019-04-26 11:40:55,608.090,0x0000,41.4,10896,0x0001,-9289,3265,7488,-9289,21,65535,0,0,-1689,37.6,5,44,94,13200,4000,0x02C2,0x40,487,1745,3263,8000,0x08,0x0840,0x00,0x01,1284,0,-273.2,97,23,2572,198,23,1004,0,0,0,0,0,0,720,SUCCESS
    153,2019-04-26 11:40:59,612.091,0x0000,41.4,10890,0x0001,-9289,3256,7488,-9289,21,65535,0,0,-1689,37.7,5,44,94,13200,4000,0x02C2,0x40,477,1745,3254,8000,0x08,0x0840,0x00,0x01,1280,0,-273.2,97,23,2576,198,23,1004,0,0,0,0,0,0,749,SUCCESS
    154,2019-04-26 11:41:03,616.091,0x0000,41.4,10884,0x0001,-9289,3248,7488,-9289,21,65535,0,0,-1688,37.7,5,44,94,13200,4000,0x02C2,0x40,466,1745,3245,8000,0x08,0x0840,0x00,0x01,1276,0,-273.2,97,23,2580,198,23,1004,0,0,0,0,0,0,1028,SUCCESS
    155,2019-04-26 11:41:07,620.091,0x0000,41.4,10884,0x0001,-9289,3239,7488,-9289,21,65535,0,0,-1687,37.7,5,44,94,13200,4000,0x02C2,0x40,456,1745,3236,8000,0x08,0x0840,0x00,0x01,1272,0,-273.2,97,23,2584,198,23,1004,0,0,0,0,0,0,991,SUCCESS
    156,2019-04-26 11:41:11,624.092,0x0000,41.4,10878,0x0001,-9290,3230,7488,-9289,21,65535,0,0,-1686,37.7,5,44,94,13200,4000,0x02C2,0x40,446,1745,3228,8000,0x08,0x0840,0x00,0x01,1268,0,-273.2,97,23,2588,198,23,1004,0,0,0,0,0,0,1138,SUCCESS
    157,2019-04-26 11:41:15,628.093,0x0000,41.4,10878,0x0001,-9290,3221,7488,-9289,21,65535,0,0,-1686,37.7,5,44,94,13200,4000,0x02C2,0x40,435,1745,3219,8000,0x08,0x0840,0x00,0x01,1264,0,-273.2,97,23,2592,198,23,1004,0,0,0,0,0,0,755,SUCCESS
    158,2019-04-26 11:41:19,632.093,0x0000,41.5,10872,0x0001,-9290,3212,7488,-9289,21,65535,0,0,-1685,37.7,5,43,94,13200,4000,0x02C2,0x40,425,1745,3210,8000,0x08,0x0840,0x00,0x01,1260,0,-273.2,97,23,2596,198,23,1004,0,0,0,0,0,0,751,SUCCESS
    159,2019-04-26 11:41:23,636.094,0x0000,41.5,10866,0x0001,-9290,3203,7488,-9290,21,65535,0,0,-1684,37.8,5,43,94,13200,4000,0x02C2,0x40,415,1745,3201,8000,0x08,0x0840,0x00,0x01,1256,0,-273.2,97,23,2600,198,23,1004,0,0,0,0,0,0,735,SUCCESS
    160,2019-04-26 11:41:27,640.095,0x0000,41.5,10860,0x0001,-9290,3194,7488,-9290,21,65535,0,0,-1684,37.8,5,43,94,13200,4000,0x02C2,0x40,404,1745,3192,8000,0x08,0x0840,0x00,0x01,1252,0,-273.2,97,23,2604,198,23,1004,0,0,0,0,0,0,840,SUCCESS
    161,2019-04-26 11:41:31,644.095,0x0000,41.5,10854,0x0001,-9290,3185,7488,-9290,21,65535,0,0,-1683,37.8,5,43,94,13200,4000,0x02C2,0x40,397,1745,3183,8000,0x08,0x0840,0x00,0x01,1248,0,-273.2,97,23,2608,198,23,1004,0,0,0,0,0,0,750,SUCCESS
    162,2019-04-26 11:41:35,648.095,0x0000,41.5,10854,0x0001,-9290,3176,7488,-9290,21,65535,0,0,-1683,37.8,5,43,94,13200,4000,0x02C2,0x40,386,1745,3176,8000,0x08,0x0840,0x00,0x01,1244,0,-273.2,97,23,2612,198,23,1004,0,0,0,0,0,0,716,SUCCESS
    163,2019-04-26 11:41:39,652.096,0x0000,41.5,10848,0x0001,-9290,3168,7488,-9290,20,65535,0,0,-1682,37.8,5,43,94,13200,4000,0x02C2,0x40,376,1745,3168,8000,0x08,0x0840,0x00,0x01,1240,0,-273.2,97,23,2616,198,23,1004,0,0,0,0,0,0,729,SUCCESS
    164,2019-04-26 11:41:43,656.097,0x0000,41.5,10842,0x0001,-9291,3159,7488,-9290,20,65535,0,0,-1681,37.9,5,43,94,13200,4000,0x02C2,0x40,366,1745,3159,8000,0x08,0x0840,0x00,0x01,1236,0,-273.2,97,23,2620,198,23,1004,0,0,0,0,0,0,713,SUCCESS
    165,2019-04-26 11:41:47,660.098,0x0000,41.5,10836,0x0001,-9291,3150,7488,-9290,20,65535,0,0,-1681,37.9,5,43,94,13200,4000,0x02C2,0x40,355,1745,3150,8000,0x08,0x0840,0x00,0x01,1232,0,-273.2,97,23,2624,198,23,1004,0,0,0,0,0,0,717,SUCCESS
    166,2019-04-26 11:41:51,664.098,0x0000,41.6,10830,0x0001,-9291,3141,7488,-9290,20,65535,0,0,-1680,37.9,5,42,94,13200,4000,0x02C2,0x40,345,1745,3141,8000,0x08,0x0840,0x00,0x01,1228,0,-273.2,97,23,2628,198,23,1004,0,0,0,0,0,0,715,SUCCESS
    167,2019-04-26 11:41:55,668.099,0x0000,41.6,10830,0x0001,-9291,3132,7488,-9291,20,65535,0,0,-1679,37.9,5,42,94,13200,4000,0x02C2,0x40,335,1745,3132,8000,0x08,0x0840,0x00,0x01,1224,0,-273.2,97,23,2632,198,23,1004,0,0,0,0,0,0,730,SUCCESS
    168,2019-04-26 11:41:59,672.100,0x0000,41.7,10824,0x0001,-9291,3123,7488,-9291,20,65535,0,0,-1678,37.9,5,42,94,13200,4000,0x02C2,0x40,324,1745,3123,8000,0x08,0x0840,0x00,0x01,1221,0,-273.2,97,23,2636,198,23,1004,0,0,0,0,0,0,706,SUCCESS
    169,2019-04-26 11:42:03,676.100,0x0000,41.7,10824,0x0001,-9292,3114,7488,-9291,20,65535,0,0,-1678,37.9,5,42,94,13200,4000,0x02C2,0x40,314,1745,3114,8000,0x08,0x0840,0x00,0x01,1217,0,-273.2,97,23,2639,198,23,1004,0,0,0,0,0,0,692,SUCCESS
    170,2019-04-26 11:42:07,680.101,0x0000,41.7,10812,0x0001,-9292,3105,7488,-9291,20,65535,0,0,-1677,37.9,5,42,94,13200,4000,0x02C2,0x40,304,1745,3105,8000,0x08,0x0840,0x00,0x01,1213,0,-273.2,97,23,2644,198,23,1004,0,0,0,0,0,0,722,SUCCESS
    171,2019-04-26 11:42:11,684.101,0x0000,41.7,10812,0x0001,-9292,3096,7488,-9291,20,65535,0,0,-1676,37.9,5,42,94,13200,4000,0x02C2,0x40,293,1745,3096,8000,0x08,0x0840,0x00,0x01,1209,0,-273.2,97,23,2647,198,23,1004,0,0,0,0,0,0,677,SUCCESS
    172,2019-04-26 11:42:15,688.102,0x0000,41.7,10806,0x0001,-9292,3088,7488,-9292,20,65535,0,0,-1676,38.0,5,42,94,13200,4000,0x02C2,0x40,283,1745,3088,8000,0x08,0x0840,0x00,0x01,1205,0,-273.2,97,23,2651,198,23,1004,0,0,0,0,0,0,691,SUCCESS
    173,2019-04-26 11:42:19,692.102,0x0000,41.7,10800,0x0001,-9292,3079,7488,-9292,20,65535,0,0,-1675,38.0,5,42,94,13200,4000,0x02C2,0x40,273,1745,3079,8000,0x08,0x0840,0x00,0x01,1201,0,-273.2,97,23,2655,198,23,1004,0,0,0,0,0,0,702,SUCCESS
    174,2019-04-26 11:42:23,696.103,0x0000,41.7,10800,0x0001,-9292,3070,7488,-9292,20,65535,0,0,-1675,38.0,5,41,94,13200,4000,0x02C2,0x40,262,1745,3070,8000,0x08,0x0840,0x00,0x01,1197,0,-273.2,97,23,2659,198,23,1004,0,0,0,0,0,0,706,SUCCESS
    175,2019-04-26 11:42:27,700.103,0x0000,41.7,10788,0x0001,-9292,3061,7488,-9292,20,65535,0,0,-1674,38.0,5,41,94,13200,4000,0x02C2,0x40,252,1745,3061,8000,0x08,0x0840,0x00,0x01,1193,0,-273.2,97,23,2664,198,23,1004,0,0,0,0,0,0,870,SUCCESS
    176,2019-04-26 11:42:31,704.103,0x0000,41.7,10788,0x0001,-9292,3052,7488,-9292,20,65535,0,0,-1673,38.0,5,41,94,13200,4000,0x02C2,0x40,242,1745,3052,8000,0x08,0x0840,0x00,0x01,1189,0,-273.2,97,23,2667,198,23,1004,0,0,0,0,0,0,694,SUCCESS
    177,2019-04-26 11:42:35,708.104,0x0000,41.7,10782,0x0001,-9292,3043,7488,-9292,20,65535,0,0,-1673,38.0,5,41,94,13200,4000,0x02C2,0x40,231,1745,3043,8000,0x08,0x0840,0x00,0x01,1185,0,-273.2,97,23,2671,198,23,1004,0,0,0,0,0,0,706,SUCCESS
    178,2019-04-26 11:42:39,712.105,0x0000,41.8,10782,0x0001,-9292,3034,7488,-9292,20,65535,0,0,-1672,38.0,5,41,94,13200,4000,0x02C2,0x40,221,1745,3034,8000,0x08,0x0840,0x00,0x01,1181,0,-273.2,97,23,2675,198,23,1004,0,0,0,0,0,0,705,SUCCESS
    179,2019-04-26 11:42:43,716.105,0x0000,41.8,10770,0x0001,-9292,3025,7488,-9292,20,65535,0,0,-1671,38.1,5,41,94,13200,4000,0x02C2,0x40,211,1745,3025,8000,0x08,0x0840,0x00,0x01,1177,0,-273.2,97,23,2679,198,23,1004,0,0,0,0,0,0,685,SUCCESS
    180,2019-04-26 11:42:47,720.106,0x0000,41.8,10770,0x0001,-9292,3016,7488,-9292,19,65535,0,0,-1670,38.1,5,41,94,13200,4000,0x02C2,0x40,200,1745,3016,8000,0x08,0x0840,0x00,0x01,1173,0,-273.2,97,23,2683,198,23,1004,0,0,0,0,0,0,704,SUCCESS
    181,2019-04-26 11:42:51,724.106,0x0000,41.9,10764,0x0001,-9292,3008,7488,-9292,19,65535,0,0,-1670,38.1,5,41,94,13200,4000,0x02C2,0x40,190,1746,3008,8000,0x08,0x0840,0x00,0x01,1169,0,-273.2,97,23,2687,198,23,1004,0,0,0,0,0,0,740,SUCCESS
    182,2019-04-26 11:42:55,728.107,0x0000,41.8,10758,0x0001,-9292,2999,7488,-9292,19,65535,0,0,-1669,38.1,5,41,94,13200,4000,0x02C2,0x40,180,1745,2999,8000,0x08,0x0840,0x00,0x01,1165,0,-273.2,97,23,2691,198,23,1004,0,0,0,0,0,0,736,SUCCESS
    183,2019-04-26 11:42:59,732.107,0x0000,41.8,10758,0x0001,-9292,2990,7488,-9292,19,65535,0,0,-1668,38.1,5,40,94,13200,4000,0x02C2,0x40,169,1745,2990,8000,0x08,0x0840,0x00,0x01,1161,0,-273.2,97,23,2695,198,23,1004,0,0,0,0,0,0,736,SUCCESS
    184,2019-04-26 11:43:03,736.107,0x0000,41.8,10746,0x0001,-9293,2981,7488,-9292,19,65535,0,0,-1667,38.1,5,40,94,13200,4000,0x02C2,0x40,159,1745,2981,8000,0x08,0x0840,0x00,0x01,1157,0,-273.2,97,23,2699,198,23,1004,0,0,0,0,0,0,748,SUCCESS
    185,2019-04-26 11:43:07,740.108,0x0000,41.8,10746,0x0001,-9293,2972,7488,-9292,19,65535,0,0,-1667,38.2,5,40,94,13200,4000,0x02C2,0x40,149,1745,2972,8000,0x08,0x0840,0x00,0x01,1153,0,-273.2,97,23,2703,198,23,1004,0,0,0,0,0,0,745,SUCCESS
    186,2019-04-26 11:43:11,744.108,0x0000,41.8,10740,0x0001,-9293,2963,7488,-9293,19,65535,0,0,-1666,38.2,5,40,94,13200,4000,0x02C2,0x40,139,1745,2963,8000,0x08,0x0840,0x00,0x01,1149,0,-273.2,97,23,2707,198,23,1004,0,0,0,0,0,0,762,SUCCESS
    187,2019-04-26 11:43:15,748.109,0x0000,41.9,10734,0x0001,-9293,2954,7488,-9293,19,65535,0,0,-1665,38.1,5,40,94,13200,4000,0x02C2,0x40,128,1746,2954,8000,0x08,0x0840,0x00,0x01,1145,0,-273.2,97,23,2711,198,23,1004,0,0,0,0,0,0,727,SUCCESS
    188,2019-04-26 11:43:19,752.110,0x0000,41.9,10728,0x0001,-9293,2945,7488,-9293,19,65535,0,0,-1665,38.1,5,40,94,13200,4000,0x02C2,0x40,118,1746,2945,8000,0x08,0x0840,0x00,0x01,1141,0,-273.2,97,23,2715,198,23,1004,0,0,0,0,0,0,729,SUCCESS
    189,2019-04-26 11:43:23,756.110,0x0000,41.9,10728,0x0001,-9293,2936,7488,-9293,19,65535,0,0,-1664,38.1,5,40,94,13200,4000,0x02C2,0x40,108,1746,2936,8000,0x08,0x0840,0x00,0x01,1137,0,-273.2,97,23,2719,198,23,1004,0,0,0,0,0,0,743,SUCCESS
    190,2019-04-26 11:43:27,760.111,0x0000,42.0,10722,0x0001,-9293,2928,7488,-9293,19,65535,0,0,-1663,38.1,5,40,94,13200,4000,0x02C2,0x40,97,1745,2928,8000,0x08,0x0840,0x00,0x01,1133,0,-273.2,97,23,2723,198,23,1004,0,0,0,0,0,0,818,SUCCESS
    191,2019-04-26 11:43:31,764.112,0x0000,42.0,10716,0x0001,-9293,2919,7488,-9293,19,65535,0,0,-1663,38.2,5,39,94,13200,4000,0x02C2,0x40,87,1745,2919,8000,0x08,0x0840,0x00,0x01,1129,0,-273.2,97,23,2727,198,23,1004,0,0,0,0,0,0,742,SUCCESS
    192,2019-04-26 11:43:35,768.112,0x0000,42.0,10716,0x0001,-9294,2912,7488,-9293,19,65535,0,0,-1662,38.2,5,39,94,13200,4000,0x02C2,0x40,77,1745,2910,8000,0x08,0x0840,0x00,0x01,1125,0,-273.2,97,23,2731,198,23,1004,0,0,0,0,0,0,727,SUCCESS
    193,2019-04-26 11:43:39,772.113,0x0000,42.0,10704,0x0001,-9294,2903,7488,-9293,19,65535,0,0,-1661,38.2,5,39,94,13200,4000,0x02C2,0x40,66,1745,2901,8000,0x08,0x0840,0x00,0x01,1121,0,-273.2,97,23,2735,198,23,1004,0,0,0,0,0,0,706,SUCCESS
    194,2019-04-26 11:43:43,776.114,0x0000,41.9,10704,0x0001,-9294,2894,7488,-9294,19,65535,0,0,-1660,38.2,5,39,94,13200,4000,0x02C2,0x40,56,1745,2892,8000,0x08,0x0840,0x00,0x01,1117,0,-273.2,97,23,2739,198,23,1004,0,0,0,0,0,0,723,SUCCESS
    195,2019-04-26 11:43:47,780.115,0x0000,41.9,10698,0x0001,-9293,2885,7488,-9294,19,65535,0,0,-1660,38.2,5,39,94,13200,4000,0x02C2,0x40,46,1745,2883,8000,0x08,0x0840,0x00,0x01,1113,0,-273.2,97,23,2743,198,23,1004,0,0,0,0,0,0,690,SUCCESS
    196,2019-04-26 11:43:51,784.116,0x0000,41.9,10692,0x0001,-9294,2876,7488,-9294,19,65535,0,0,-1659,38.3,5,39,94,13200,4000,0x02C2,0x40,35,1746,2874,8000,0x08,0x0840,0x00,0x01,1109,0,-273.2,97,23,2747,198,23,1004,0,0,0,0,0,0,705,SUCCESS
    197,2019-04-26 11:43:55,788.117,0x0000,41.9,10686,0x0001,-9293,2868,7488,-9294,19,65535,0,0,-1658,38.3,5,39,94,13200,4000,0x02C2,0x40,25,1745,2865,8000,0x08,0x0840,0x00,0x01,1105,0,-273.2,97,23,2751,198,23,1004,0,0,0,0,0,0,687,SUCCESS
    198,2019-04-26 11:43:59,792.118,0x0000,42.0,10686,0x0001,-9294,2859,7488,-9294,18,65535,0,0,-1657,38.3,5,39,94,13200,4000,0x02C2,0x40,15,1745,2856,8000,0x08,0x0840,0x00,0x01,1101,0,-273.2,97,23,2755,198,23,1004,0,0,0,0,0,0,701,SUCCESS
    199,2019-04-26 11:44:03,796.119,0x0000,42.0,10680,0x0001,-9294,2850,7488,-9294,18,65535,0,0,-1657,38.3,5,39,94,13200,4000,0x02C2,0x40,4,1745,2848,8000,0x08,0x0840,0x00,0x01,1097,0,-273.2,97,23,2759,198,23,1004,0,0,0,0,0,0,688,SUCCESS
    200,2019-04-26 11:44:07,800.119,0x0000,42.0,10674,0x0001,-9294,2841,7488,-9294,18,65535,0,0,-1656,38.3,5,38,94,13200,4000,0x02C2,0x40,0,1745,2839,8000,0x08,0x0840,0x00,0x01,1093,0,-273.2,97,23,2763,198,23,1004,0,0,0,0,0,0,687,SUCCESS
    201,2019-04-26 11:44:11,804.120,0x0000,42.0,10668,0x0001,-9294,2832,7488,-9294,18,65535,0,0,-1655,38.3,5,38,94,13200,4000,0x02C2,0x40,0,1745,2830,8000,0x08,0x0840,0x00,0x01,1089,0,-273.2,97,23,2767,198,23,1004,0,0,0,0,0,0,684,SUCCESS
    202,2019-04-26 11:44:15,808.121,0x0000,42.0,10662,0x0001,-9294,2823,7488,-9294,18,65535,0,0,-1654,38.3,5,38,94,13200,4000,0x02C2,0x40,0,1745,2821,8000,0x08,0x0840,0x00,0x01,1085,0,-273.2,97,23,2771,198,23,1004,0,0,0,0,0,0,700,SUCCESS
    203,2019-04-26 11:44:19,812.122,0x0000,42.0,10656,0x0001,-9294,2814,7488,-9294,18,65535,0,0,-1654,38.3,5,38,94,13200,4000,0x02C2,0x40,0,1745,2812,8000,0x08,0x0840,0x00,0x01,1081,0,-273.2,97,23,2775,198,23,1004,0,0,0,0,0,0,685,SUCCESS
    204,2019-04-26 11:44:23,816.122,0x0000,42.0,10650,0x0001,-9294,2805,7488,-9294,18,65535,0,0,-1653,38.3,5,38,94,13200,4000,0x02C2,0x40,0,1745,2803,8000,0x08,0x0840,0x00,0x01,1077,0,-273.2,97,23,2779,198,23,1004,0,0,0,0,0,0,699,SUCCESS
    205,2019-04-26 11:44:27,820.123,0x0000,42.0,10644,0x0001,-9294,2796,7488,-9294,18,65535,0,0,-1652,38.3,5,38,94,13200,4000,0x02C2,0x40,0,1745,2794,8000,0x08,0x0840,0x00,0x01,1073,0,-273.2,97,23,2783,198,23,1004,0,0,0,0,0,0,695,SUCCESS
    206,2019-04-26 11:44:31,824.124,0x0000,42.0,10638,0x0001,-9294,2788,7488,-9294,18,65535,0,0,-1651,38.3,5,38,94,13200,4000,0x02C2,0x40,0,1745,2785,8000,0x08,0x0840,0x00,0x01,1069,0,-273.2,97,23,2787,198,23,1004,0,0,0,0,0,0,700,SUCCESS
    207,2019-04-26 11:44:35,828.124,0x0000,42.0,10638,0x0001,-9294,2779,7488,-9294,18,65535,0,0,-1650,38.3,5,38,94,13200,4000,0x02C2,0x40,0,1745,2776,8000,0x08,0x0840,0x00,0x01,1065,0,-273.2,97,23,2791,198,23,1004,0,0,0,0,0,0,681,SUCCESS
    208,2019-04-26 11:44:39,832.125,0x0000,42.0,10632,0x0001,-9294,2770,7488,-9294,18,65535,0,0,-1650,38.4,5,37,94,13200,4000,0x02C2,0x40,0,1745,2768,8000,0x08,0x0840,0x00,0x01,1061,0,-273.2,97,23,2795,198,23,1004,0,0,0,0,0,0,714,SUCCESS
    209,2019-04-26 11:44:43,836.126,0x0000,42.0,10626,0x0001,-9294,2761,7488,-9294,18,65535,0,0,-1649,38.3,5,37,94,13200,4000,0x02C2,0x40,0,1745,2761,8000,0x08,0x0840,0x00,0x01,1057,0,-273.2,97,23,2799,198,23,1004,0,0,0,0,0,0,697,SUCCESS
    210,2019-04-26 11:44:47,840.126,0x0000,42.0,10620,0x0001,-9294,2752,7488,-9294,18,65535,0,0,-1648,38.4,5,37,94,13200,4000,0x02C2,0x40,0,1745,2752,8000,0x08,0x0840,0x00,0x01,1053,0,-273.2,97,23,2803,198,23,1004,0,0,0,0,0,0,696,SUCCESS
    211,2019-04-26 11:44:51,844.127,0x0000,42.1,10614,0x0001,-9294,2743,7488,-9294,18,65535,0,0,-1647,38.3,5,37,94,13200,4000,0x02C2,0x40,0,1745,2743,8000,0x08,0x0840,0x00,0x01,1049,0,-273.2,97,23,2807,198,23,1004,0,0,0,0,0,0,763,SUCCESS
    212,2019-04-26 11:44:55,848.127,0x0000,42.1,10608,0x0001,-9294,2734,7488,-9294,18,65535,0,0,-1646,38.4,5,37,94,13200,4000,0x02C2,0x40,0,1745,2734,8000,0x08,0x0840,0x00,0x01,1045,0,-273.2,97,23,2811,198,23,1004,0,0,0,0,0,0,695,SUCCESS
    213,2019-04-26 11:44:59,852.128,0x0000,42.1,10602,0x0001,-9294,2725,7488,-9294,18,65535,0,0,-1645,38.4,5,37,94,13200,4000,0x02C2,0x40,0,1745,2725,8000,0x08,0x0840,0x00,0x01,1041,0,-273.2,97,23,2815,198,23,1004,0,0,0,0,0,0,696,SUCCESS
    214,2019-04-26 11:45:03,856.129,0x0000,42.1,10596,0x0001,-9294,2716,7488,-9294,18,65535,0,0,-1644,38.4,5,37,94,13200,4000,0x02C2,0x40,0,1745,2716,8000,0x08,0x0840,0x00,0x01,1037,0,-273.2,97,23,2819,198,23,1004,0,0,0,0,0,0,690,SUCCESS
    215,2019-04-26 11:45:07,860.129,0x0000,42.1,10596,0x0001,-9294,2708,7488,-9294,17,65535,0,0,-1644,38.4,5,37,94,13200,4000,0x02C2,0x40,0,1745,2708,8000,0x08,0x0840,0x00,0x01,1033,0,-273.2,97,23,2823,198,23,1004,0,0,0,0,0,0,696,SUCCESS
    216,2019-04-26 11:45:11,864.129,0x0000,42.1,10590,0x0001,-9294,2699,7488,-9294,17,65535,0,0,-1643,38.4,5,37,94,13200,4000,0x02C2,0x40,0,1745,2699,8000,0x08,0x0840,0x00,0x01,1029,0,-273.2,97,23,2827,198,23,1004,0,0,0,0,0,0,713,SUCCESS
    217,2019-04-26 11:45:15,868.130,0x0000,42.1,10584,0x0001,-9294,2690,7488,-9294,17,65535,0,0,-1642,38.4,5,36,94,13200,4000,0x02C2,0x40,0,1745,2690,8000,0x08,0x0840,0x00,0x01,1026,0,-273.2,97,23,2831,198,23,1004,0,0,0,0,0,0,731,SUCCESS
    218,2019-04-26 11:45:19,872.130,0x0000,42.1,10578,0x0001,-9294,2681,7488,-9294,17,65535,0,0,-1641,38.4,5,36,94,13200,4000,0x02C2,0x40,0,1745,2681,8000,0x08,0x0840,0x00,0x01,1022,0,-273.2,97,23,2835,198,23,1004,0,0,0,0,0,0,741,SUCCESS
    219,2019-04-26 11:45:23,876.131,0x0000,42.1,10572,0x0001,-9294,2672,7488,-9294,17,65535,0,0,-1640,38.4,5,36,94,13200,4000,0x02C2,0x40,0,1745,2672,8000,0x08,0x0840,0x00,0x01,1018,0,-273.2,97,23,2839,198,23,1004,0,0,0,0,0,0,754,SUCCESS
    220,2019-04-26 11:45:27,880.131,0x0000,42.1,10566,0x0001,-9295,2663,7488,-9294,17,65535,0,0,-1640,38.5,5,36,94,13200,4000,0x02C2,0x40,0,1745,2663,8000,0x08,0x0840,0x00,0x01,1014,0,-273.2,97,23,2842,198,23,1004,0,0,0,0,0,0,721,SUCCESS
    221,2019-04-26 11:45:31,884.132,0x0000,42.1,10560,0x0001,-9295,2654,7488,-9295,17,65535,0,0,-1639,38.5,5,36,94,13200,4000,0x02C2,0x40,0,1745,2654,8000,0x08,0x0840,0x00,0x01,1010,0,-273.2,97,23,2846,198,23,1004,0,0,0,0,0,0,724,SUCCESS
    222,2019-04-26 11:45:35,888.133,0x0000,42.1,10554,0x0001,-9295,2645,7488,-9295,17,65535,0,0,-1638,38.5,5,36,94,13200,4000,0x02C2,0x40,0,1745,2645,8000,0x08,0x0840,0x00,0x01,1006,0,-273.2,97,23,2850,198,23,1004,0,0,0,0,0,0,722,SUCCESS
    223,2019-04-26 11:45:39,892.134,0x0000,42.2,10548,0x0001,-9295,2636,7488,-9295,17,65535,0,0,-1637,38.5,5,36,94,13200,4000,0x02C2,0x40,0,1745,2636,8000,0x08,0x0840,0x00,0x01,1002,0,-273.2,97,23,2854,198,23,1004,0,0,0,0,0,0,692,SUCCESS
    224,2019-04-26 11:45:43,896.134,0x0000,42.2,10542,0x0001,-9295,2628,7488,-9295,17,65535,0,0,-1636,38.4,5,36,94,13200,4000,0x02C2,0x40,0,1745,2628,8000,0x08,0x0840,0x00,0x01,998,0,-273.2,97,23,2858,198,23,1004,0,0,0,0,0,0,694,SUCCESS
    225,2019-04-26 11:45:47,900.135,0x0000,42.2,10536,0x0001,-9295,2619,7488,-9295,17,65535,0,0,-1635,38.5,5,35,94,13200,4000,0x02C2,0x40,0,1745,2619,8000,0x08,0x0840,0x00,0x01,994,0,-273.2,97,23,2862,198,23,1004,0,0,0,0,0,0,710,SUCCESS
    226,2019-04-26 11:45:51,904.136,0x0000,42.2,10530,0x0001,-9295,2610,7488,-9295,17,65535,0,0,-1634,38.5,5,35,94,13200,4000,0x02C2,0x40,0,1745,2610,8000,0x08,0x0840,0x00,0x01,990,0,-273.2,97,23,2866,198,23,1004,0,0,0,0,0,0,704,SUCCESS
    227,2019-04-26 11:45:55,908.136,0x0000,42.2,10524,0x0001,-9295,2601,7488,-9295,17,65535,0,0,-1633,38.5,5,35,94,13200,4000,0x02C2,0x40,0,1745,2601,8000,0x08,0x0840,0x00,0x01,986,0,-273.2,97,23,2870,198,23,1004,0,0,0,0,0,0,689,SUCCESS
    228,2019-04-26 11:45:59,912.136,0x0000,42.2,10518,0x0001,-9295,2592,7488,-9295,17,65535,0,0,-1632,38.5,5,35,94,13200,4000,0x02C2,0x40,0,1745,2592,8000,0x08,0x0840,0x00,0x01,982,0,-273.2,97,23,2874,198,23,1004,0,0,0,0,0,0,724,SUCCESS
    229,2019-04-26 11:46:03,916.137,0x0000,42.2,10512,0x0001,-9295,2583,7488,-9295,17,65535,0,0,-1631,38.5,5,35,94,13200,4000,0x02C2,0x40,0,1745,2583,8000,0x08,0x0840,0x00,0x01,978,0,-273.2,97,23,2878,198,23,1004,0,0,0,0,0,0,722,SUCCESS
    230,2019-04-26 11:46:07,920.138,0x0000,42.2,10506,0x0001,-9295,2574,7488,-9295,17,65535,0,0,-1631,38.5,5,35,94,13200,4000,0x02C2,0x40,0,1745,2574,8000,0x08,0x0840,0x00,0x01,974,0,-273.2,97,23,2882,198,23,1004,0,0,0,0,0,0,705,SUCCESS
    231,2019-04-26 11:46:11,924.138,0x0000,42.2,10500,0x0101,-9295,2565,7488,-9295,17,65535,0,0,-1630,38.5,5,35,94,13200,4000,0x02C2,0x40,0,1745,2565,8000,0x08,0x0840,0x00,0x01,970,0,-273.2,97,23,2886,198,23,1004,0,0,0,0,0,0,703,SUCCESS
    232,2019-04-26 11:46:15,928.139,0x0000,42.2,10494,0x0101,-9295,2556,7488,-9295,16,65535,0,0,-1629,38.5,5,35,94,13200,4000,0x02C2,0x40,0,1745,2556,8000,0x08,0x0840,0x00,0x01,966,0,-273.2,97,23,2890,198,23,1004,0,0,0,0,0,0,690,SUCCESS
    233,2019-04-26 11:46:19,932.139,0x0000,42.2,10482,0x0101,-9296,2548,7488,-9295,16,65535,0,0,-1628,38.5,5,35,94,13200,4000,0x02C2,0x40,0,1745,2548,8000,0x08,0x0840,0x00,0x01,962,0,-273.2,97,23,2894,198,23,1004,0,0,0,0,0,0,703,SUCCESS
    234,2019-04-26 11:46:23,936.140,0x0000,42.2,10482,0x0101,-9295,2539,7488,-9295,16,65535,0,0,-1627,38.5,5,34,94,13200,4000,0x02C2,0x40,0,1745,2539,8000,0x08,0x0840,0x00,0x01,958,0,-273.2,97,23,2898,198,23,1004,0,0,0,0,0,0,705,SUCCESS
    235,2019-04-26 11:46:27,940.140,0x0000,42.2,10470,0x0101,-9295,524,7488,-9295,3,65535,0,0,-1626,38.5,5,7,94,13200,4000,0x028A,0x4040,0,1745,524,8000,0x08,0x0840,0x00,0x01,954,0,-273.2,97,23,2902,198,23,1004,0,0,0,0,0,0,702,SUCCESS
    236,2019-04-26 11:46:31,944.141,0x0000,42.2,10470,0x4101,-9296,513,7488,-9295,3,65535,0,0,-1625,38.5,5,7,94,13200,4000,0x028A,0x4040,0,1720,513,8000,0x08,0x0840,0x00,0x01,950,0,-273.2,97,23,2906,198,23,1004,0,0,0,0,0,0,685,SUCCESS
    237,2019-04-26 11:46:35,948.141,0x0000,42.3,10458,0x4101,-9296,507,7488,-9295,3,65535,0,0,-1624,38.6,5,7,94,13200,4000,0x02CA,0x4040,0,1720,507,5604,0x08,0x0840,0x00,0x01,946,0,-273.2,97,23,2910,198,23,1004,0,0,0,0,0,0,702,SUCCESS
    238,2019-04-26 11:46:39,952.142,0x0000,42.2,10452,0x4101,-9295,501,7488,-9295,3,65535,0,0,-1623,38.6,5,7,94,13200,4000,0x02CA,0x4040,0,1720,501,5604,0x08,0x0840,0x00,0x01,942,0,-273.2,97,23,2914,198,23,1004,0,0,0,0,0,0,685,SUCCESS
    239,2019-04-26 11:46:43,956.142,0x0000,42.3,10446,0x4101,-9296,495,7488,-9295,3,65535,0,0,-1622,38.6,5,7,94,13200,4000,0x02CA,0x4040,0,1720,495,5604,0x08,0x0840,0x00,0x01,938,0,-273.2,97,23,2918,198,23,1004,0,0,0,0,0,0,704,SUCCESS
    240,2019-04-26 11:46:47,960.143,0x0000,42.3,10440,0x4101,-9295,489,7488,-9295,3,65535,0,0,-1621,38.6,5,7,94,13200,4000,0x02CA,0x4040,0,1720,489,5604,0x08,0x0840,0x00,0x01,934,0,-273.2,97,23,2922,198,23,1004,0,0,0,0,0,0,686,SUCCESS
    241,2019-04-26 11:46:51,964.144,0x0000,42.2,10434,0x4001,0,485,7488,-8268,4,65535,0,0,-1441,38.6,5,7,94,13200,4000,0x02CA,0x4040,0,1787,485,5604,0x08,0x0840,0x00,0x01,930,0,-273.2,97,23,2926,198,23,1004,0,0,0,0,0,0,717,SUCCESS
    242,2019-04-26 11:46:55,968.145,0x0000,42.3,11598,0x4081,0,485,7488,-6281,5,65535,0,0,-1095,38.6,5,7,94,13200,4000,0x02CA,0x4040,0,1799,485,5604,0x08,0x0840,0x00,0x01,926,0,-273.2,97,23,2930,198,23,1004,0,0,0,0,0,0,736,SUCCESS
    243,2019-04-26 11:46:59,972.145,0x0000,42.3,11598,0x4081,0,485,7488,-4771,6,65535,0,0,-832,38.6,5,7,94,13200,4000,0x02CA,0x4040,0,1804,485,5604,0x08,0x0840,0x00,0x01,922,0,-273.2,97,23,2934,198,23,1004,0,0,0,0,0,0,701,SUCCESS
    244,2019-04-26 11:47:03,976.145,0x0000,42.3,11598,0x4081,0,485,7488,-3625,8,65535,0,0,-632,38.6,5,7,94,13200,4000,0x02CA,0x4040,0,1806,485,5604,0x08,0x0840,0x00,0x01,918,0,-273.2,97,23,2938,198,23,1004,0,0,0,0,0,0,734,SUCCESS
    245,2019-04-26 11:47:07,980.146,0x0000,42.3,11598,0x4081,0,485,7488,-2754,11,65535,0,0,-480,38.6,5,7,94,13200,4000,0x02CA,0x4040,0,1806,485,5604,0x08,0x0840,0x00,0x01,914,0,-273.2,97,23,2942,198,23,1004,0,0,0,0,0,0,736,SUCCESS
    246,2019-04-26 11:47:11,984.146,0x0000,42.3,11598,0x4081,0,485,7488,-2092,14,65535,0,0,-365,38.6,5,7,94,13200,4000,0x02CA,0x4040,0,1806,485,5604,0x08,0x0840,0x00,0x01,910,0,-273.2,97,23,2946,198,23,1004,0,0,0,0,0,0,735,SUCCESS
    247,2019-04-26 11:47:15,988.147,0x0000,41.8,11664,0x4081,0,485,7488,-1589,18,65535,0,0,-277,38.2,5,7,94,13200,4000,0x02CA,0x4040,0,1806,485,5604,0x08,0x0840,0x00,0x01,906,0,-273.2,97,23,2950,198,23,1004,0,0,0,0,0,0,697,SUCCESS
    248,2019-04-26 11:47:19,992.148,0x0000,41.8,11664,0x4081,0,485,7488,-1207,24,65535,0,0,-210,38.2,5,7,94,13200,4000,0x02CA,0x4040,0,1806,485,5604,0x08,0x0840,0x00,0x01,902,0,-273.2,97,23,2954,198,23,1004,0,0,0,0,0,0,792,SUCCESS
    249,2019-04-26 11:47:23,996.149,0x0020,41.8,11664,0x4001,0,485,7488,-917,28,65535,0,0,-160,37.9,5,7,94,13200,4000,0x02CA,0x4040,0,1806,485,5604,0x08,0x0840,0x00,0x01,899,0,-273.2,97,23,2957,198,23,1004,0,0,0,0,0,0,880,SUCCESS
    250,2019-04-26 11:47:27,1000.149,0x0020,41.2,11682,0x4001,0,485,7488,-746,28,65535,0,0,-121,37.7,5,7,94,13200,4000,0x02CA,0x4040,0,1806,485,5604,0x08,0x0840,0x00,0x01,899,0,-273.2,97,23,2957,198,23,1004,0,0,0,0,0,0,730,SUCCESS
    251,2019-04-26 11:47:31,1004.150,0x0020,41.1,11682,0x4001,0,485,7488,-567,28,65535,0,0,-92,37.6,5,7,94,13200,4000,0x02CA,0x4040,0,1806,485,5604,0x08,0x0840,0x00,0x01,899,0,-273.2,97,23,2957,198,23,1004,0,0,0,0,0,0,751,SUCCESS
    252,2019-04-26 11:47:35,1008.648,0x0020,40.9,11688,0x4001,0,485,7488,-402,28,65535,0,0,-70,37.4,5,7,94,13200,4000,0x02CA,0x4040,0,1806,485,5604,0x08,0x0840,0x00,0x01,899,0,-273.2,97,23,2957,198,23,1004,0,0,0,0,0,0,731,SUCCESS
    253,2019-04-26 11:47:39,1012.151,0x0020,40.8,11694,0x4001,0,485,7488,-327,,65535,0,0,-46,37.4,5,7,94,13200,4000,0x028A,0x4040,0,1787,485,5604,0x08,0x0840,0x00,0x01,897,0,-273.2,97,23,2959,198,23,1004,0,0,0,0,0,0,3022,ERROR : Please check C:\Users\jpryde\Desktop\GPC\Logs\Discharge GPC3.log.err
    254,2019-04-26 11:47:43,1016.152,0x0000,40.7,11688,0x4081,0,485,7488,-249,117,65535,0,0,-43,37.4,5,7,94,13200,4000,0x028A,0x4040,0,1787,485,5604,0x08,0x0840,0x00,0x01,895,0,-273.2,97,23,2961,198,23,1004,0,0,0,0,0,0,757,SUCCESS
    255,2019-04-26 11:47:47,1020.152,0x0000,40.7,11688,0x4081,0,485,7488,-189,154,65535,0,0,-33,37.4,5,7,94,13200,4000,0x028A,0x4040,0,1787,485,5604,0x08,0x0840,0x00,0x01,891,0,-273.2,97,23,2965,198,23,1004,0,0,0,0,0,0,744,SUCCESS
    256,2019-04-26 11:47:51,1024.152,0x0000,40.7,11688,0x4080,0,485,7488,-143,203,65535,0,0,-25,37.4,5,7,94,13200,4000,0x0282,0x40,0,1787,485,5604,0x08,0x0840,0x00,0x01,887,0,-273.2,97,23,2969,198,23,1004,0,0,0,0,0,0,745,SUCCESS
    257,2019-04-26 11:47:55,1028.153,0x0000,40.7,11688,0x4080,0,485,7488,-109,267,65535,0,0,-19,37.4,5,7,94,13200,4000,0x0282,0x40,0,1787,485,5604,0x08,0x0840,0x00,0x01,883,0,-273.2,97,23,2973,198,23,1004,0,0,0,0,0,0,742,SUCCESS
    258,2019-04-26 11:47:59,1032.153,0x0000,40.7,11688,0x4080,0,485,7488,-83,351,65535,0,0,-14,37.4,5,7,94,13200,4000,0x0282,0x40,0,1787,485,5604,0x08,0x0840,0x00,0x01,879,0,-273.2,97,23,2977,198,23,1004,0,0,0,0,0,0,766,SUCCESS
    259,2019-04-26 11:48:03,1036.154,0x0000,39.9,11706,0x4080,0,485,7488,-63,462,65535,,0,-9,36.7,5,7,94,13200,4000,0x0282,0x40,0,1787,485,5604,0x08,0x0840,0x00,0x01,873,0,-273.2,97,23,2983,198,23,1004,0,0,0,0,0,0,3023,ERROR : Please check C:\Users\jpryde\Desktop\GPC\Logs\Discharge GPC3.log.err
    260,2019-04-26 11:48:07,1040.154,0x0000,39.9,11706,0x4080,0,485,7488,-48,606,65535,0,0,-8,36.7,5,7,94,13200,4000,0x0282,0x40,0,1787,485,5604,0x08,0x0840,0x00,0x01,871,0,-273.2,97,23,2985,198,23,1004,0,0,0,0,0,0,757,SUCCESS
    261,2019-04-26 11:48:11,1044.155,0x0000,39.9,11706,0x4080,0,485,7488,-36,808,65535,0,0,-6,36.7,5,7,94,13200,4000,0x0282,0x40,0,1787,485,5604,0x08,0x0840,0x00,0x01,867,0,-273.2,97,23,2989,198,23,1004,0,0,0,0,0,0,724,SUCCESS
    262,2019-04-26 11:48:15,1048.155,0x0000,39.9,11706,0x4080,0,485,7488,-28,1039,65535,0,0,-5,36.7,5,7,94,13200,4000,0x0282,0x40,0,1787,485,5604,0x08,0x0840,0x00,0x01,863,0,-273.2,97,23,2993,198,23,1004,0,0,0,0,0,0,723,SUCCESS
    263,2019-04-26 11:48:19,1052.156,0x0000,39.9,11706,0x4080,0,485,7488,-21,1386,65535,0,0,-4,36.7,5,7,94,13200,4000,0x0282,0x40,0,1787,485,5604,0x08,0x0840,0x00,0x01,859,0,-273.2,97,23,2997,198,23,1004,0,0,0,0,0,0,738,SUCCESS
    264,2019-04-26 11:48:23,1056.156,0x0000,39.2,11718,0x4080,0,485,7488,-16,1819,65535,0,0,-3,36.1,5,7,94,13200,4000,0x0282,0x40,0,1787,485,5604,0x08,0x0840,0x00,0x01,855,0,-273.2,97,23,3001,198,23,1004,0,0,0,0,0,0,740,SUCCESS
    265,2019-04-26 11:48:27,1060.156,0x0000,39.2,11718,0x4080,0,485,7488,-12,2425,65535,0,0,-2,36.1,5,7,94,13200,4000,0x0282,0x40,0,1787,485,5604,0x08,0x0840,0x00,0x01,851,0,-273.2,97,23,3005,198,23,1004,0,0,0,0,0,0,757,SUCCESS
    gg.csv excel file: 8475.BQ34110GGCSV.xlsx
  • Hi ColinY,
    Unfortunately, that is not offered, however, If you would like to tweak the parameters of the gpccedv tool further, here is the mathcad tool: www.ti.com/.../MATHCAD_CEDV_SOFTWARE
    It will require mathcad to use and comes with advanced instructions for tweaking parameters.
    Sincerely,
    Bryan Kahler
  • Hi ColinY,
    Haven't heard from you in some time. The CEDV software is the other option than the webtool GPCCEDV.
    Sincerely,
    Bryan Kahler
  • Hello Bryan,
    Unfortunately I am not very familiar with MathCAD. If problems persist and I have no other options then I can try looking into the CEDV software, but if there are other simpler possible solutions I would rather try those instead.
    Have you had the chance to look into the CEDV Report, log and gg.csv files? I know it would be quite hard to troubleshoot just off of those, but it's very possible that we have missed something that could be the source of our troubles.
    Thanks again for your time,
    Colin
  • Hi Colin,
    After taking the 6 log files, submitting to the tool and then programming the values into the gauge, what issues are you now experiencing?
    Sincerely,
    Bryan Kahler
  • Hi Colin,
    Haven't heard back from you in a while. Hopefully no news is good news and the issue is now resolved.
    If not, please let us know.
    Sincerely,
    Bryan Kahler
  • Hi again Bryan,
    Sorry, I must have missed your previous question. Unfortunately we still have not been able to find the bugs. Our problem is still that the SoC (and related values like TTE) drop significantly (about 27% minimum, 8 minutes TTE)  when the voltage hits the EDV2 value, even though our GPCCEDV report tells us there should be an error of no more than 3%. This happens even after we completely discharge the battery and recharge it to 100% SoC while the chip is connected.
    I have noticed that if we don't charge the SoC all the way to 100%, the SoC/TTE value doesn't drop as much when it hits EDV2. The lower SoC we start our discharge, the less the SoC/TTE value drops. This makes me think think that it might be an issue with the Coulomb counter? Is there any way to check this/fix this? We have already calibrated the current reading, and it is fairly accurate with a maximum error of about 0.15 mA.
    I apologize again for my delayed response.
    Colin
  • Hi ColinY,
    To test the coulomb counter, please see section 2.6 of the TRM. Accumulated charge measurement.
    It can be configured to accumulate charge or discharge and may be compared against your external measurements.
    Sincerely,
    Bryan Kahler
  • Hi Bryan,
    Ok that makes sense, I didn't really pay any attention to the accumulated charge measurement. Practically speaking, how would you suggest measuring the accumulated charge externally? Would we charge/discharge it to a constant current and multiply current in/out by time?
    Colin
  • Hi Colin,
    This article may help:
    e2e.ti.com/.../how-accurate-is-your-battery-fuel-gauge-part-2-2
    Sincerely,
    Bryan Kahler
  • The article is very helpful. I will let you know once I am able to test the gauge.
