BQ34Z950: BQ34Z950 takes charging current 2.6A
Part Number: BQ34Z950
Other Parts Discussed in Thread: BQ2050
Hello
I am working on battery pack (4 cell series) 2600mAh  which consist BQ34Z950. I upload following parameters in BQ34Z950  but voltage Ok status, Full charge status not update after 100% charging. Battery cycle count also display some garbage value after some amount of time whenever you refresh then it update. At a time of charging it takes 2.6A current. What should i do? which parameter need to change? please help me.
[Voltage(1st Level Safety)]
COV Threshold = 4450
COV Recovery = 4200
CUV Threshold = 3010
CUV Recovery = 3060
[Current(1st Level Safety)]
OC (1st Tier) Chg = 6000
OC (1st Tier) Dsg = 6000
Current Recovery Time = 8
AFE OC Dsg = 12
AFE OC Dsg Time = 0F
AFE SC Chg Cfg = 77
AFE SC Dsg Cfg = 77
[Temperature(1st Level Safety)]
Over Temp Chg = 55.0
OT Chg Recovery = 50.0
Over Temp Dsg = 60.0
OT Dsg Recovery = 55.0
[Voltage(2nd Level Safety)]
SOV Threshold = 18000
SOV Time = 0
Cell Imbalance Current = 5
Cell Imbalance Fail Voltage = 1000
Cell Imbalance Time = 0
Battery Rest Time = 1800
[Current(2nd Level Safety)]
SOC Chg = 10000
SOC Chg Time = 0
SOC Dsg = 10000
SOC Dsg Time = 0
[Temperature(2nd Level Safety)]
SOT Chg = 65.0
SOT Chg Time = 0
SOT Dsg = 75.0
SOT Dsg Time = 0
[FET Verification(2nd Level Safety)]
FET Fail Time = 0
[AFE Verification(2nd Level Safety)]
AFE Fail Limit = 10
[Charge Inhibit Cfg(Charge Control)]
Chg Inhibit Temp Low = 0.0
Chg Inhibit Temp High = 50.0
[Pre-Charge Cfg(Charge Control)]
Pre-chg Current = 250
Pre-chg Temp = 12.0
Pre-chg Voltage = 3000
Recovery Voltage = 3100
[Fast Charge Cfg(Charge Control)]
Fast Charge Current = 850
Charging Voltage = 16800
Suspend Low Temp = -5.0
Suspend High Temp = 55.0
[Termination Cfg.(Charge Control)]
Taper Current = 250
Taper Voltage = 300
TCA Clear % = 95
FC Set % = 100
FC Clear % = 98
[Cell Balancing Cfg(Charge Control)]
Min Cell Deviation = 1750
[Charging Faults(Charge Control)]
Over Charge Capacity = 300
[Data(SBS Configuration)]
Rem Cap Alarm = 300
Rem Energy Alarm = 1440
Rem Time Alarm = 10
Init Battery Mode = 0081
Design Voltage = 14800
Spec Info = 0031
Manuf Date = 29-April-2019
Ser. Num. = 0001
Cycle Count = 2
CC Threshold = 2340
CF MaxError Limit = 100
Design Capacity = 2600
Design Energy = 38480
Manuf Name = EMS_V165
Device Name = bq34z950
Device Chemistry = LION
[Configuration(SBS Configuration)]
TDA Set % = 6
TDA Clear % = 8
FD Set % = 2
FD Clear % = 5
TDA Set Volt Threshold = 5000
TDA Set Volt Time = 0
TDA Clear Volt = 5500
[Integrity Data(System Data)]
Reset Counter Partial = 0
Reset Counter Full = 198
[Manufacturer Info(System Data)]
Manuf. Info = 0123456789ABCDEF0123
[Registers(Configuration)]
Operation Cfg A = 0329
Operation Cfg B = 2448
Operation Cfg C = 0001
Permanent Fail Cfg = 0000
Non-Removable Cfg = 0000
[AFE(Configuration)]
AFE PMS Threshold = 5500
[LED Cfg(LED Support)]
LED Flash Period = 512
LED Blink Period = 1024
LED Delay = 100
LED Hold Time = 4
CHG Flash Alarm = 10
CHG Thresh 1 = 0
CHG Thresh 2 = 20
CHG Thresh 3 = 40
CHG Thresh 4 = 60
CHG Thresh 5 = 80
DSG Flash Alarm = 10
DSG Thresh 1 = 0
DSG Thresh 2 = 20
DSG Thresh 3 = 40
DSG Thresh 4 = 60
DSG Thresh 5 = 80
Sink Current = 3
[Power(Power)]
Flash Update OK Voltage = 7500
Shutdown Voltage = 12050
Charger Present = 3000
Wake Current Reg = 00
[IT Cfg(Gas Gauging)]
Load Select = 3
Load Mode = 0
Term Voltage = 12000
User Rate-mA = 0
User Rate-mW = 0
Reserve Cap-mAh = 0
Reserve Cap-mWh = 0
[Current Thresholds(Gas Gauging)]
Dsg Current Threshold = 50
Chg Current Threshold = 800
Quit Current = 10
[State(Gas Gauging)]
Qmax Cell 0 = 2469
Qmax Cell 1 = 2480
Qmax Cell 2 = 2481
Qmax Cell 3 = 2485
Qmax Pack = 2469
Update Status = 06
Delta Voltage = 4
[R_a0(Ra Table)]
Cell0 R_a flag = 0000
Cell0 R_a 0 = 41
Cell0 R_a 1 = 50
Cell0 R_a 2 = 73
Cell0 R_a 3 = 98
Cell0 R_a 4 = 99
Cell0 R_a 5 = 96
Cell0 R_a 6 = 101
Cell0 R_a 7 = 149
Cell0 R_a 8 = 181
Cell0 R_a 9 = 235
Cell0 R_a 10 = 310
Cell0 R_a 11 = 417
Cell0 R_a 12 = 447
Cell0 R_a 13 = 684
Cell0 R_a 14 = 994
[R_a1(Ra Table)]
Cell1 R_a flag = 0000
Cell1 R_a 0 = 51
Cell1 R_a 1 = 51
Cell1 R_a 2 = 75
Cell1 R_a 3 = 102
Cell1 R_a 4 = 102
Cell1 R_a 5 = 99
Cell1 R_a 6 = 103
Cell1 R_a 7 = 149
Cell1 R_a 8 = 188
Cell1 R_a 9 = 244
Cell1 R_a 10 = 320
Cell1 R_a 11 = 430
Cell1 R_a 12 = 468
Cell1 R_a 13 = 707
Cell1 R_a 14 = 1037
[R_a2(Ra Table)]
Cell2 R_a flag = 0055
Cell2 R_a 0 = 55
Cell2 R_a 1 = 55
Cell2 R_a 2 = 78
Cell2 R_a 3 = 101
Cell2 R_a 4 = 101
Cell2 R_a 5 = 97
Cell2 R_a 6 = 101
Cell2 R_a 7 = 148
Cell2 R_a 8 = 211
Cell2 R_a 9 = 278
Cell2 R_a 10 = 360
Cell2 R_a 11 = 497
Cell2 R_a 12 = 532
Cell2 R_a 13 = 62
Cell2 R_a 14 = 93
[R_a3(Ra Table)]
Cell3 R_a flag = 0000
Cell3 R_a 0 = 52
Cell3 R_a 1 = 56
Cell3 R_a 2 = 79
Cell3 R_a 3 = 102
Cell3 R_a 4 = 104
Cell3 R_a 5 = 102
Cell3 R_a 6 = 105
Cell3 R_a 7 = 156
Cell3 R_a 8 = 188
Cell3 R_a 9 = 241
Cell3 R_a 10 = 316
Cell3 R_a 11 = 429
Cell3 R_a 12 = 461
Cell3 R_a 13 = 439
Cell3 R_a 14 = 641
[R_a0x(Ra Table)]
xCell0 R_a flag = 0055
xCell0 R_a 0 = 41
xCell0 R_a 1 = 50
xCell0 R_a 2 = 73
xCell0 R_a 3 = 98
xCell0 R_a 4 = 99
xCell0 R_a 5 = 96
xCell0 R_a 6 = 101
xCell0 R_a 7 = 149
xCell0 R_a 8 = 215
xCell0 R_a 9 = 279
xCell0 R_a 10 = 368
xCell0 R_a 11 = 495
xCell0 R_a 12 = 531
xCell0 R_a 13 = 812
xCell0 R_a 14 = 1181
[R_a1x(Ra Table)]
xCell1 R_a flag = 0055
xCell1 R_a 0 = 51
xCell1 R_a 1 = 51
xCell1 R_a 2 = 75
xCell1 R_a 3 = 102
xCell1 R_a 4 = 102
xCell1 R_a 5 = 99
xCell1 R_a 6 = 103
xCell1 R_a 7 = 149
xCell1 R_a 8 = 215
xCell1 R_a 9 = 279
xCell1 R_a 10 = 366
xCell1 R_a 11 = 492
xCell1 R_a 12 = 535
xCell1 R_a 13 = 809
xCell1 R_a 14 = 1186
[R_a2x(Ra Table)]
xCell2 R_a flag = 0000
xCell2 R_a 0 = 55
xCell2 R_a 1 = 55
xCell2 R_a 2 = 78
xCell2 R_a 3 = 101
xCell2 R_a 4 = 101
xCell2 R_a 5 = 97
xCell2 R_a 6 = 101
xCell2 R_a 7 = 148
xCell2 R_a 8 = 186
xCell2 R_a 9 = 245
xCell2 R_a 10 = 317
xCell2 R_a 11 = 438
xCell2 R_a 12 = 469
xCell2 R_a 13 = 55
xCell2 R_a 14 = 82
[R_a3x(Ra Table)]
xCell3 R_a flag = 0055
xCell3 R_a 0 = 52
xCell3 R_a 1 = 56
xCell3 R_a 2 = 79
xCell3 R_a 3 = 102
xCell3 R_a 4 = 104
xCell3 R_a 5 = 102
xCell3 R_a 6 = 105
xCell3 R_a 7 = 156
xCell3 R_a 8 = 228
xCell3 R_a 9 = 292
xCell3 R_a 10 = 383
xCell3 R_a 11 = 520
xCell3 R_a 12 = 559
xCell3 R_a 13 = 532
xCell3 R_a 14 = 777
[Device Status Data(PF Status)]
PF Flags 1 = 0000
PF Flags 2 = 0000
[Data(Calibration)]
CC Gain = 2.37
CC Delta = 2.37
Ref Voltage = 1225.45
AFE Pack Gain = 245.88
CC Offset = -0.233
Board Offset = -21.3
Int Temp Offset = 0.0
Ext1 Temp Offset = -.8
Ext2 Temp Offset = 0.0
[Config(Calibration)]
CC Current = 3000
Voltage Signal = 16800
Temp Signal = 298.0
CC Offset Time = 250
ADC Offset Time = 32
CC Gain Time = 250
Voltage Time = 1984
Temperature Time = 32
Cal Mode Timeout = 300
[Temp Model(Calibration)]
Ext Coef 1 = -28285
Ext Coef 2 = 20848
Ext Coef 3 = -7537
Ext Coef 4 = 401.2
Ext Min AD = 0
Ext Max Temp = 401.2
Int Coef 1 = 0
Int Coef 2 = 0
Int Coef 3 = -11136
Int Coef 4 = 575.4
Int Min AD = 0
Int Max Temp = 575.4
[Current(Calibration)]
Filter = 239
Deadband = 3
CC Deadband = 10.0
[bq2050 Config(DQ Communication)]
bq20z753 Configuration = 10
Pins Pulled Down = 20
Pins Pulled Up = 05
Resistor Divider Gain = 6
mV to mAhr Scale = 640
AutoCal per Sleep = 0
BR_Low = 2700
BR_RC = 1000
Wr0_Low = 1775
Wr0_RC = 1225
Wr1_Low = 550
Wr1_RC = 2451
Rd0_Low = 1150
Rd1_Low = 1100
Rd_TO = 0
RD_RS = 300
Wr_0_to_1_Delay = 100
SlaveRsp_Delay = 3020
To resolve this problem please tell me required changes and related factors which help me out.
Shalini Patil
(R & D Engineer)
