Other Parts Discussed in Thread: LM137,
Two bench power supplies can be connected together to produce +/- 3V by connecting the plus of one to the negative of the other to create a common GND?
Is it possible to connect two LM117s together to produce +/- 3V? The same positive d.c. line voltage would be input to both POLs?
I am trying to generate a low-current negative rail easily rather than construct one using a switching regulator.
thank you
