We meet an issue about BQ24297 BATFET can't normally turn on, please see below SYS pin waveform, BATFET turn on/turn off each ~170ms, seems meet some error after turn on BATFET, but I check the register only see the REG09[7] WATCHDOG_FAULT is 1. And other strange is REG01[5] OTG Enable is 1.
This symptom can be release after remove battery, we have 2 device, we have tried one to remove battery, and keep one still have this fail symptom.
Do you have ever meet this issue or any possible fault caused BATFET can't turn on normally?
CH1: SYS pin
CH1: SYS pin
CH2: BAT pin
schematic
thanks!
Jeff
