Part Number: BQ20Z655-R1
Other Parts Discussed in Thread: EV2400, BQ2060, BQ40Z50-R2
Hi
I have a problem. Difference between capacity display on LCD BQ20Z655-R1 80% and on PC (EV2400) 0%. Can you help me?
Lada
Hi
Lada
[Header] bq EVSW Version = 0.9.80 DeviceName = bq20z655-R1 v0.03 Time = 13.11.2014 7:13:39 [Voltage(1st Level Safety)] LT COV Threshold = 4300 LT COV Recovery = 4100 ST COV Threshold = 4300 ST COV Recovery = 4100 HT COV Threshold = 4250 HT COV Recovery = 4100 COV Time = 1 CUV Threshold = 2400 CUV Time = 2 CUV Recovery = 3000 [Current(1st Level Safety)] OC (1st Tier) Chg = 3000 OC (1st Tier) Chg Time = 3 OC Chg Recovery = 200 OC (1st Tier) Dsg = 5000 OC (1st Tier) Dsg Time = 3 OC Dsg Recovery = 200 OC (2nd Tier) Chg = 3500 OC (2nd Tier) Chg Time = 1 OC (2nd Tier) Dsg = 6000 OC (2nd Tier) Dsg Time = 1 Current Recovery Time = 10 AFE OC Dsg =00 AFE OC Dsg Time = 01 AFE OC Dsg Recovery = 5 AFE SC Chg Cfg = 72 AFE SC Dsg Cfg = 86 AFE SC Recovery = 0 [Temperature(1st Level Safety)] OT1 Chg Threshold = 53.0 OT1 Chg Time = 2 OT1 Chg Recovery = 51.0 OT2 Chg Threshold = 53.0 OT2 Chg Time = 0 OT2 Chg Recovery = 51.0 OT1 Dsg Threshold = 75.0 OT1 Dsg Time = 0 OT1 Dsg Recovery = 73.0 OT2 Dsg Threshold = 75.0 OT2 Dsg Time = 2 OT2 Dsg Recovery = 73.0 Hi Dsg Start Temp = 75.0 [Host Comm(1st Level Safety)] Host Watchdog Timeout = 0 [Voltage(2nd Level Safety)] LT SOV Threshold = 4400 ST SOV Threshold = 4400 HT SOV Threshold = 4350 SOV Time = 0 PF SOV Fuse Blow Delay = 0 SUV Threshold = 2000 SUV Time = 0 Rest CIM Current = 5 Rest CIM Fail Voltage = 1000 Rest CIM Time = 0 CIM Battery Rest Time = 0 Rest CIM Check Voltage = 3000 Active CIM Fail Voltage = 1000 Active CIM Time = 0 Active CIM Check Voltage = 3000 PFIN Detect Time = 0 PF Min Fuse Blow Voltage = 8000 [Current(2nd Level Safety)] SOC Chg = 7000 SOC Chg Time = 0 SOC Dsg = 10000 SOC Dsg Time = 0 [Temperature(2nd Level Safety)] SOT1 Chg Threshold = 65.0 SOT1 Chg Time = 0 SOT2 Chg Threshold = 65.0 SOT2 Chg Time = 0 SOT1 Dsg Threshold = 80.0 SOT1 Dsg Time = 0 SOT2 Dsg Threshold = 80.0 SOT2 Dsg Time = 0 Open Thermistor = -33.3 Open Time = 0 [FET Verification(2nd Level Safety)] FET Fail Limit = 20 FET Fail Time = 0 [AFE Verification(2nd Level Safety)] AFE Check Time = 0 AFE Fail Limit = 0 AFE Fail Recovery Time = 20 AFE Init Retry Limit = 6 AFE Init Limit = 20 [Fuse Verification(2nd Level Safety)] Fuse Fail Limit = 20 Fuse Fail Time = 0 [Charge Temp Cfg(Charge Control)] JT1 = 0.0 JT2 = 10.0 JT2a = 40.0 JT3 = 45.0 JT4 = 50.0 Temp Hys = 1.0 [Pre-Charge Cfg(Charge Control)] Pre-chg Voltage Threshold = 2800 Pre-chg Recovery Voltage = 2850 Pre-chg Current = 400 [Charge Cfg(Charge Control)] LT Chg Voltage = 16800 LT Chg Current1 = 1400 LT Chg Current2 = 1400 LT Chg Current3 = 1000 ST1 Chg Voltage = 16800 ST1 Chg Current1 = 2700 ST1 Chg Current2 = 2700 ST1 Chg Current3 = 2000 ST2 Chg Voltage = 16600 ST2 Chg Current1 = 2000 ST2 Chg Current2 = 2000 ST2 Chg Current3 = 1400 HT Chg Voltage = 16400 HT Chg Current1 = 1200 HT Chg Current2 = 800 HT Chg Current3 = 800 Cell Voltage Threshold1 = 4000 Cell Voltage Threshold2 = 4100 Cell Voltage Thresh Hys = 10 [Termination Cfg.(Charge Control)] Maintenance Current = 0 Taper Current = 300 Taper Voltage = 400 Current Taper Window = 10 TCA Set % = -1 TCA Clear % = 95 FC Set % = -1 FC Clear % = 98 [Cell Balancing Cfg(Charge Control)] Min Cell Deviation = 1350 [Charging Faults(Charge Control)] Over Charging Voltage = 300 Over Charging Volt Time = 2 Over Charging Current = 500 Over Charging Curr Time = 2 Over Charging Curr Recov = 100 Depleted Voltage = 9600 Depleted Voltage Time = 2 Depleted Recovery = 10000 Over Charge Capacity = 500 Over Charge Recovery = 2 CMTO = 0 PCMTO = 0 Charge Fault Cfg = 00 [External Charge Control(Charge Control)] Chg Inhibit Threshold = 0 Chg Inhibit Hold Time = 0 [Data(SBS Configuration)] Rem Cap Alarm = 560 Rem Energy Alarm = 810 Rem Time Alarm = 10 Init Battery Mode = 0081 Design Voltage = 14400 Spec Info = 0031 Manuf Date = xxxxxxx Ser. Num. = 0001 Cycle Count = 0 CC Threshold = 3000 CC % = 55 CF MaxError Limit = 100 Design Capacity = 5600 Design Energy = 8100 Manuf Name = xxxxx Device Name = xxxxx Device Chemistry = LION [Configuration(SBS Configuration)] TDA Set % = 5 TDA Clear % = 7 FD Set % = 3 FD Clear % = 5 TDA Set Volt Threshold = 12000 TDA Set Volt Time = 5 TDA Clear Volt = 12500 FD Set Volt Threshold = 12000 FD Volt Time = 5 FD Clear Volt = 12500 [Manufacturer Data(System Data)] Pack Lot Code = 0000 PCB Lot Code = 0000 Firmware Version = 0000 Hardware Revision = 0000 Cell Revision = 0000 [Manufacturer Info(System Data)] Manuf. Info 0 = 0123456789ABCDEF0123456789ABCDE Manuf. Block 1 = 0123456789ABCDEF0123 Manuf. Block 2 = 0123456789ABCDEF0123 Manuf. Block 3 = 0123456789ABCDEF0123 [Lifetime Data(System Data)] Lifetime Max Temp = 30.0 Lifetime Min Temp = 20.0 Lifetime Max Cell Voltage = 3500 Lifetime Min Cell Voltage = 3200 Lifetime Max Pack Voltage = 14000 Lifetime Min Pack Voltage = 12800 Lifetime Max Chg Current = 1500 Lifetime Max Dsg Current = -3000 Lifetime Max Chg Power = 15000 Lifetime Max Dsg Power = -15000 Life Max AvgDsg Cur = -1000 Life Max AvgDsg Pow = -1500 Life Avg Temp = 25.0 [Lifetime Temp Samples(System Data)] LT Temp Samples = 0 [Registers(Configuration)] Operation Cfg A = 0329 Operation Cfg B = 2448 Operation Cfg C = 0534 Permanent Fail Cfg = 0000 Permanent Fail Cfg 2 = 0000 Non-Removable Cfg = 0000 [AFE(Configuration)] AFE.State_CTL = 00 SMB Sync Command = FF SMB Sync Delay = 50 [LED Cfg(LED Support)] LED Flash Period = 512 LED Blink Period = 1024 LED Delay = 100 LED Hold Time = 4 CHG Flash Alarm = 0 CHG Thresh 1 = 0 CHG Thresh 2 = 10 CHG Thresh 3 = 25 CHG Thresh 4 = 50 CHG Thresh 5 = 75 DSG Flash Alarm = 0 DSG Thresh 1 = 0 DSG Thresh 2 = 10 DSG Thresh 3 = 25 DSG Thresh 4 = 50 DSG Thresh 5 = 75 Sink Current = 3 LCD Freq = 35 [Power(Power)] Flash Update OK Voltage = 11500 Shutdown Voltage = 10000 Shutdown Time = 10 Cell Shutdown Voltage = 2500 Cell Shutdown Time = 10 Charger Present = 10000 Sleep Current = 10 Bus Low Time = 5 Cal Inhibit Temp Low = 5.0 Cal Inhibit Temp High = 45.0 Sleep Voltage Time = 20 Sleep Current Time = 80 Wake Current Reg = 00 Sealed Ship Delay = 5 [IT Cfg(Gas Gauging)] Load Select = 3 Load Mode = 0 Term Voltage = 12000 User Rate-mA = 0 User Rate-mW = 0 Reserve Cap-mAh = 0 Reserve Cap-mWh = 0 Ra Max Delta = 44 Max IR Correct = 400 Transient Factor Charge = 128 Transient Factor Discharge = 128 [Current Thresholds(Gas Gauging)] Dsg Current Threshold = 100 Chg Current Threshold = 50 Quit Current = 10 Dsg Relax Time = 1 Chg Relax Time = 60 [State(Gas Gauging)] Qmax Cell 0 = 5700 Qmax Cell 1 = 5700 Qmax Cell 2 = 5700 Qmax Cell 3 = 5700 Qmax Pack = 5700 Update Status = 02 Cell 0 Chg dod at EoC = 0 Cell 1 Chg dod at EoC = 0 Cell 2 Chg dod at EoC = 0 Cell 3 Chg dod at EoC = 0 Avg I Last Run = -2000 Avg P Last Run = -3022 Delta Voltage = 0 Max Avg I Last Run = -2000 Max Avg P Last Run = -3022 [R_a0(Ra Table)] Cell0 R_a flag = 0055 Cell0 R_a 0 = 52 Cell0 R_a 1 = 39 Cell0 R_a 2 = 43 Cell0 R_a 3 = 46 Cell0 R_a 4 = 44 Cell0 R_a 5 = 30 Cell0 R_a 6 = 36 Cell0 R_a 7 = 34 Cell0 R_a 8 = 29 Cell0 R_a 9 = 31 Cell0 R_a 10 = 35 Cell0 R_a 11 = 59 Cell0 R_a 12 = 103 Cell0 R_a 13 = 162 Cell0 R_a 14 = 437 [R_a1(Ra Table)] Cell1 R_a flag = 0055 Cell1 R_a 0 = 59 Cell1 R_a 1 = 44 Cell1 R_a 2 = 48 Cell1 R_a 3 = 50 Cell1 R_a 4 = 49 Cell1 R_a 5 = 35 Cell1 R_a 6 = 40 Cell1 R_a 7 = 37 Cell1 R_a 8 = 32 Cell1 R_a 9 = 34 Cell1 R_a 10 = 38 Cell1 R_a 11 = 62 Cell1 R_a 12 = 105 Cell1 R_a 13 = 164 Cell1 R_a 14 = 436 [R_a2(Ra Table)] Cell2 R_a flag = 0055 Cell2 R_a 0 = 67 Cell2 R_a 1 = 50 Cell2 R_a 2 = 50 Cell2 R_a 3 = 53 Cell2 R_a 4 = 53 Cell2 R_a 5 = 36 Cell2 R_a 6 = 42 Cell2 R_a 7 = 39 Cell2 R_a 8 = 34 Cell2 R_a 9 = 37 Cell2 R_a 10 = 41 Cell2 R_a 11 = 70 Cell2 R_a 12 = 121 Cell2 R_a 13 = 188 Cell2 R_a 14 = 506 [R_a3(Ra Table)] Cell3 R_a flag = 0055 Cell3 R_a 0 = 56 Cell3 R_a 1 = 42 Cell3 R_a 2 = 42 Cell3 R_a 3 = 46 Cell3 R_a 4 = 43 Cell3 R_a 5 = 28 Cell3 R_a 6 = 35 Cell3 R_a 7 = 31 Cell3 R_a 8 = 28 Cell3 R_a 9 = 29 Cell3 R_a 10 = 33 Cell3 R_a 11 = 57 Cell3 R_a 12 = 101 Cell3 R_a 13 = 160 Cell3 R_a 14 = 428 [R_a0x(Ra Table)] xCell0 R_a flag = 0000 xCell0 R_a 0 = 52 xCell0 R_a 1 = 39 xCell0 R_a 2 = 43 xCell0 R_a 3 = 46 xCell0 R_a 4 = 44 xCell0 R_a 5 = 30 xCell0 R_a 6 = 36 xCell0 R_a 7 = 34 xCell0 R_a 8 = 29 xCell0 R_a 9 = 31 xCell0 R_a 10 = 35 xCell0 R_a 11 = 59 xCell0 R_a 12 = 104 xCell0 R_a 13 = 164 xCell0 R_a 14 = 441 [R_a1x(Ra Table)] xCell1 R_a flag = 0000 xCell1 R_a 0 = 59 xCell1 R_a 1 = 44 xCell1 R_a 2 = 48 xCell1 R_a 3 = 50 xCell1 R_a 4 = 49 xCell1 R_a 5 = 35 xCell1 R_a 6 = 40 xCell1 R_a 7 = 37 xCell1 R_a 8 = 32 xCell1 R_a 9 = 34 xCell1 R_a 10 = 38 xCell1 R_a 11 = 62 xCell1 R_a 12 = 104 xCell1 R_a 13 = 162 xCell1 R_a 14 = 432 [R_a2x(Ra Table)] xCell2 R_a flag = 0000 xCell2 R_a 0 = 67 xCell2 R_a 1 = 50 xCell2 R_a 2 = 50 xCell2 R_a 3 = 53 xCell2 R_a 4 = 53 xCell2 R_a 5 = 36 xCell2 R_a 6 = 42 xCell2 R_a 7 = 39 xCell2 R_a 8 = 34 xCell2 R_a 9 = 37 xCell2 R_a 10 = 41 xCell2 R_a 11 = 70 xCell2 R_a 12 = 120 xCell2 R_a 13 = 186 xCell2 R_a 14 = 502 [R_a3x(Ra Table)] xCell3 R_a flag = 0000 xCell3 R_a 0 = 56 xCell3 R_a 1 = 42 xCell3 R_a 2 = 42 xCell3 R_a 3 = 46 xCell3 R_a 4 = 43 xCell3 R_a 5 = 28 xCell3 R_a 6 = 35 xCell3 R_a 7 = 31 xCell3 R_a 8 = 28 xCell3 R_a 9 = 29 xCell3 R_a 10 = 33 xCell3 R_a 11 = 57 xCell3 R_a 12 = 101 xCell3 R_a 13 = 160 xCell3 R_a 14 = 428 [Device Status Data(PF Status)] Saved PF Flags 1 = 0000 Saved PF Flags 2 = 0000 Fuse Flag = 00 PF Voltage = 0 PF C4 Voltage = 0 PF C3 Voltage = 0 PF C2 Voltage = 0 PF C1 Voltage = 0 PF Current = 0 PF Temperature = 0.0 PF Batt Stat = 00 PF RC-mAh = 0 PF RC-10mWh = 0 PF Chg Status = 0000 PF Safety Status 1 = 0000 PF Safety Status2 = 0000 Saved 1st PF Flags 1 = 0000 Saved 1st PF Flags 2 = 0000 [AFE Regs(PF Status)] AFE Status = 00 AFE Output = 00 AFE State = 00 AFE Function = 00 AFE Cell Select = 00 AFE OLV = 00 AFE OLT = 00 AFE SCC = 00 AFE SCD = 00 [Data(Calibration)] CC Gain = 5 CC Delta = 5 Ref Voltage = 1225.00 AFE Pack Gain = 672.91 CC Offset = -0.245 Board Offset = 0 Int Temp Offset = 0.0 Ext1 Temp Offset = 0.0 Ext2 Temp Offset = 0.0 [Config(Calibration)] CC Current = 3000 Voltage Signal = 16800 Temp Signal = 298.0 CC Offset Time = 250 ADC Offset Time = 32 CC Gain Time = 250 Voltage Time = 1984 Temperature Time = 32 Cal Mode Timeout = 300 [Temp Model(Calibration)] Ext Coef 1 = -28285 Ext Coef 2 = 20848 Ext Coef 3 = -7537 Ext Coef 4 = 401.2 Ext Min AD = 0 Ext Max Temp = 401.2 Int Coef 1 = 0 Int Coef 2 = 0 Int Coef 3 = -11136 Int Coef 4 = 575.4 Int Min AD = 0 Int Max Temp = 575.4 [Current(Calibration)] Filter = 239 Deadband = 3 CC Deadband = 10.0
The battery pack capacity LCD indication is OK. It is possible to write the „Remaining Capacity“ value manually (0x0f command). We wrote null „Remaining Capacity“ value.
The LCD capacity indication is goes to zerro. It is OK. After that we read „Remaining Capacity“ null value the (command 0x0f). It is OK.
We wrote 1000 mAh „Remaining Capacity value now“. LCD displays correct value, but PCs (EV2400 sw) read null „Remaining Capacity“ value constantly.
The error is possible chanched when we set BQ20z655-R1 soft reset command. After that the „Remaining Capacity“ value starts to indicate correctly (EV2400 sw).
We found that the BQ2060 and BQ40Z50-R2 have "Remaining Capacity" read-only command (0x0f). The BQ20Z655-R1 has write/read command (0x0f).
Is it possible to block this write command? (set read command only)
Thank you for your support and informations.
Lada
