Dear Team,
please advice the method on how to calculate the maximum phase shift of ucc2895
thanks
Dear Team,
thanks
Hello John
Unfortunately, I don't have a formula for Dmax but I'll try to work one up over the coming days if I other priorities allow. It isn't a difficult calculation and most of the needed information is in the data sheet - the pull down transistors at CT shown in Fig 3 are 200 Ohms each.
I ran some experiments previously looking at Dmax for several different conditions - the results are below.
In general you will get the largest value of Dmax if you use a smaller timing capacitor and a larger timing resistor.
Colin
Hello John
Actually, reviewing the plots above I think that there is probably enough information regarding Dmax. The power stage is usually run at about 66% duty cycle which is well within the IC capability. If you have a specific application need in mind then please open a new post and I can estimate a Dmax for you.
In the meanwhile I'm going to close it now but please feel free to open a new one if there are any further questions..
Colin
