My circuit with BQ29700DSER is implemented as below, following your reference design. I found that the voltage on DOUT (pin 3) is very low. Therefore the MOSFET for discharge is not driven. I also measured V- (pin 6) and it is higher than Vocd.
I tried to pull down V- by connecting it to Vss. Then DOUT seems to become normal. I am very sure that there is no other load between J12 and GND.
What should I try next to solve this?
Thank you.
Gabriel
