What are the default settings for BOOST_INITIAL_VOLTAGES[5:0] in EEPROM register 19? i.e upon first power up what is the output voltage of the LP8860-Q1
Hi Chris,
We have different versions of LP8860 device. Each has a different default setting for boost initial voltage. You can also reprogram the EEPROM to other value that you need. Below is the application report introducing the different versions of LP8860.
