Other Parts Discussed in Thread: TPS2376,
Dear Sir,
Out Customer is using TI TPS2376 for their design and currently , they fail power up the TPS2376 PD controller. we have confirmed the the PSE side is ok(connect with other PD device and work fine) and the power muddle they use after TPS2376 (we could power up by sending individual power and enable). and the schematic look ok to us as well, Therefore, could you kinldy help us double check if there is anything that we miss or any suggestion for the issue. And here are their schematic and spec of some components that they use:
The schematic (removed)
Above, please help check and kinldy give us some suggestions. thanks in advance
Alec
