Hi Team,
one of my customer facing the issue in bq24650 Synchronous Switch-Mode Battery Charge Controller, in which the charge controller waits for 30 min for the Vfb pin to go above 1.55 V .If the voltage does not reach 1.55 V at Vfb pin charge will be terminated and they have to reset the input manually .As they are using this IC in Solar street light reinitiating charge manually is not suggested .So in this scenario the charger IC will fail to charge the battery and the device will not work.
Kindly advice on this.
