Other Parts Discussed in Thread: TPS61087,
I have an application in which a boost converter (TPS61087) runs directly from my LiIon battery, which is charged using BQ24650. The BQ24650 data sheet specifies specific, low-value output capacitors that are commensurate with its feedback compensation loop. In my case, 10uF. But the boost converter wants at least twice that on its input. So, what happens if I use a larger output cap? Or, is it sufficient to isolate the boost input caps from the charger using a low-value resistance?
