Part Number: TPS61089
Other Parts Discussed in Thread: BQ25895, TPS61088, INA253
Hello TI,
We are using TPS61089 Boost converter to Avoid Switch over time of charging IC of BQ25895
BQ25895 takes Switch over time more than 30mSec as per thread
we looking to avoid load reset(Raspberry PI) for this we plan to use TPS61089 Boost converter we have few question related TPS61089
1.there is any Buck to boost and vise versa conversion time require to TPS61089
2.If there is any voltage variation on Input side of TPS61089 require time of (FB to Vout) to set regulated output voltage
3.we require constant Output voltage is it possible and If yes then How ..?
4.TPS61089 can handle 5A Load ..? what we need to to design precaution ..?
Thanks for your valuable support and availability to resolve the query
Thanks & Regards,
Rahul Surawase
