Dear all
What happens to TPS7A1650 device if one of the pins had been open from PCB ?
As below is our sugessing , please help me to check " Potential Failure Phenomenon ", and redress them, Thanks a lot.
Dear all
HI Went,
Some minor suggestions:
1. If the PG pin is open and used in the application, the device will always appear to indicate that the Power is Good (PG).
2. Similarly if the Delay is open, the impact is that there will be no delay from VOUT rising to PG asserting.
For completeness, I think you should also consider the thermal pad. If Open, the device may go into thermal shutdown under certain operating conditions.
I hope this helps.
Please see my reply below:
- Stephen
Hello Went,
The impedance of the enable pin to ground, while the LDO is unpowered, is approximately 3.8 megaohms.
If the enable pin is left floating while power is applied to the LDO, the voltage on the enable pin was measured as 20mV.
- Stephen
