Does a voltage appear at a floating EN pin of the TPS54531? Are the internal current sources simply blocked with nowhere to go? If the EN pin is tied through a diode (anode on the pin) and a resistor to ground would the 1uA to 4uA current sources somehow create a voltage that would exceed the diode Vf so the current flows through the diode and resistor to ground? Or with the diode and resistor connecting EN to ground would EN still be floating with no voltage on the pin?
Thanks for any help.
