Dear,
We first time use BQ25125, could double confirm schematic as below chart:
If any suggestion, Please advise me.
Lawrence.
Dear,
Lawrence.
You're missing a minimum of 1uF cap on BAT
Please take a look at the following post.
No concern with connecting VINLS to PMID. What are your RCOLD and RHOT values?
SW is the switch node of the Buck converter. VSYS is the regulated output which should be at 1.8V after startup.
Yes RCOLD and RHOT are the thermal resistor operation range you intend to use for you device.
