Part Number: BQ24171
Hi
There are the value of current regulation at precharge in Electrical Characteristics.
If I use higher Rsense, does that's value change?
Hi
Hi Yokota-san,
The current regulation for precharge and fast charge is a function of the voltage drop across the sense resistor, RSENSE. The electrical characteristics table shows current regulation accuracy as a function of V(SRN-SRP) = I(PRECHARGE)*RSENSE. Larger RSENSE results in larger V(SRN-SRP) which results in better accuracy.
Jeff
Hi Jeff-san
Yokota-san,
There is no equation to determine regulation accuracy. The accuracy in the datasheet was determined empirically. The tightest accuracy is 4% assuming V(SRP-SRN) = ICRG*RSNS=40mV. Increasing RSNS will likely not improve accuracy much as 4% is the in range of the internal reference and errors from amplifier offsets.
Jeff
Hi Jeff-san
Yi Yokota-san,
The regulation specifications are at -40 to 125 C, although practically if using TS function you cannot charge outside of 0-60C.
At Tj=25C, the regulation will likely be tighter on most but I cannot warranty outside of the datasheet spec.
Jeff
