Hi team,
Could you give me advise if VDD (e.g. 12V) with pull up occurs on IN- pin or not? For example, can low voltage logic buffer (e.g. 3.3V) be connected to the IN-pin with VDD=12V?
Takeshi Sasaki
Hi team,
Takeshi Sasaki
Hello Takeshi,
Thanks for reaching out, my name is Mamadou DIallo, I will help address your concerns.
It sounds like you're trying to use UCC27517 in an inverting configuration. If so, there few key considerations to take into account.
-Input thresholds: this driver has inputs thresholds of VIN_H = 2.2V (typ.) and VIN_L= 1.2V (typ.) meaning in an inverting configuration you need a logic buffer signal > 2.4V for the output stage to go low while you will need a logic buffer signal <1V for the output stage to go high.
-IN+ must be tied to VDD or an external supply (5V) for the inverting configuration.
The table is (from the datasheet) is the truth table of the IC.
Please let us know if this addresses your inquiry by pressing the green button or further post here if you have additional questions.
-Mamadou
Hi Mamadou,
Thank you for your comments. It seems you've got different message that I want to ask. Simply speaking, can 3.3V logic buffer be connected to IN- pin when VDD=12V as follows? For UCC27517 functional block, IN- pin is pulled up to VDD pin, it seems VDD voltage will occur at IN- pin.
Hello Takeshi,
Thanks for the clarification. TO answer your question, yes the 3.3V logic PWM signal can be connected to IN- when VDD=12V as shown on the typical application diagram section of the datasheet.
When IN- pin is left floating or unconnected, VDD internally pulls IN- high to ensure that the OUT remains low to prevent FET from turning-on. When a buffer is connected to any of the input pins, the logic PWM signal drives the input pins as the inputs are independent of the VDD voltage range.
Please press the green button if this addressed your concerns.
-Mamadou
Hi Mamadou,
Could you give me comments on following additional customer question in attached figure? In the customer system, VDD=12V is powered up first and 3.3V power supply is later than that due to power sequencing. I'm not sure how to prevent such situation, so if yes, could you give me advise on how to prevent such situation?
Takeshi Sasaki
Hi Mamadou,
Takeshi Sasaki7183.図2.tif
Hello Takeshi,
I will respond to your inquiry before end of business day today.
Thanks.
-Mamadou
Hello Takeshi,
The INx pins are input pins and therefore do not source/sink enough current to damage the buffer's output stage. IN- is internally pulled HIGH only to allow internal logic to pull OUT pin low and shutdown the driver.
Please let us know if you have further questions.
-Mamadou
