Other Parts Discussed in Thread: BQ24266
Dear Sir/Madam
We are trying to establish the quiescent current the bq25606 consumes for low system current output. We power our system from just the battery and use bq25606 SW out as the main system voltage to power the electronics. VBUS is normally disconnected (connected only for charging).
I couldn’t see the internal switching regulator efficiency data in the datasheet….for example we wanted to know how much current will be consumed from the battery (at the BAT terminal) if we draw between 100uA and 700uA at SW pin.
I have drawn a diagram for clarification (attached) and with reference to this
In the older device we were using, the BQ24266, we found that for the above condition (700uA ) the current taken from the battery by the BQ24266 was in the region of 2mA
Thanks a lot
Kindest regards
Para
