LP87565-Q1: LP875650RNFRQ1 vs LP87565CRNFRQ1
Part Number: LP87565-Q1
What is the difference of LP875650RNFRQ1 and LP87565CRNFRQ1?
Kuramochi
  • Hello Kuramochi-san,
    The LP875650RNFRQ1 is optimized for using an MCU to configure the PMIC after boot (volatile register settings). The defaults can be found in the Technical Reference Manual and information on how I2C configuration is used can be found in the Configuration Guide.
    The LP87565CRNFRQ1 is pre-programmed in the non-volatile memory to specific voltage & sequence settings for powering the DRA7xx processor family. The defaults can be found in the Technical Reference Manual and information on using it with the DRA7xx family are available in the User's Guide
    All of this information is available in the LP87565-Q1 product folder under the technical documentation section.
    Let us know if you have further question that is not described in the existing documentation.
