Good day!How to choose a resistor value "Rdesat" for mode Overcurrent Based on Desaturation Circuit. The calculation of the resistor "Rdesat" is not given in the datasheet? Can i choose 0 ohm value for resistor "Rdesat"? Thank you.
Hello Igor,
The series resistor R_DESAT is used to limit current during forward voltage transients due to the IGBT switching. We recommend using a resistance between 100 Ohms to 1 kOhms.
Also, please take a look at our Fundamentals of Drivers Guide which discusses design of DESAT circuitry.
Audrey
rdesat affects "Vdet", therefore the formula should contain rdsat.I guess the formula should be like this
where
rdesat-resistance "Rdesat"
Vfdiode-forward voltage diode "Dhv"
Idesat-current through "Rdesat"
Vocht- is the detection threshold voltage of the gate driver
Is it correct? or ihave to use formula from datasheet
Hi Igor,
That is correct. To account for Rdesat, please use the equation as you have attached.
Audrey
