Other Parts Discussed in Thread: BQSTUDIO, EV2400, BQ78350
I am using MCU STM32F1 to communicate with BQ78350-R1 through SMBus pins but it only send out the address 0x16 and then nothing happen. I have wired VCC to +2.5V, VSS to ground, SMBD and SMBC to I2C ports of the MCU (SDA and SCL) and using I2C of the MCU with 90kHz frequency to communicate with it, I have also tight up SMBD and SMBC pin with 10k Ohms pull-up resistors with +2.5V sources each. Am I doing anything wrong?
Thank you.
