Other Parts Discussed in Thread: TPS54060
I would like to know about pulse - skip of TPS54335A.
Could you please check attached file which have questions and currently informationTPS54335ADDAR_190919.xlsx?
Nagata.
Nagata.
1. The switching frequency in pulse skip mode is related to the load current. The switching frequency decreases with the decreasing of load current.
2. The min load current is related to VIN, VOUT, IOUT, L and switching frequency of CCM, you can check it based on your application.
3. The pulse skip mode can't be disabled, why do you want to disable it?
Shawn
Hi Nagata,
It is not accurate to for 500mA. The Eco-mode is related to many parameters, 500mA is the rough current for some typical application. I can't give you the accurate value.you'd better check it on the bench for your application.
You can refer to below application note to understand Eco-mode.
http://www.ti.com/lit/an/slva388/slva388.pdf
Shawn
