Hi, I have a question about cutoff frequency and cross-over frequency in bode plot of buck converter.
I was studying buck converter's stability and wonder if cutoff freq and cross-over freq are same frequency.
In addition,
In the lecture, he said switching frequency should be 10 times of cutoff frequency.
Can i use the term cross over frequency instead of cutoff frequency?
Also, i wonder why switching frequency should be way bigger than cut off frequency in a mathematical way.
  • Hi Yunsik,
    1.cut-off frequency is same as cross-over frequency
    2. The cut-off frequency corresponds to a point where the gain is 0dB, we want a stable and DC output voltage. Therefore, our system needs to amplify the low-frequency signal and suppress the high-frequency noise, the biggest high frequency noise is the switching frequency, so switching frequency should be bigger than cut off frequency.
    Kevin
  • Hi Yunsik,
    Since I have not received your reply for several days, I will turn off this item. If you have further question, you can reply it again.
    Kevin
    If this answers your question, Please click "This resolved my issue" button.
    ____________________________________________
    TPS62810-Q1 – New Automotive 6Vin, 2.25MHz buck family with 1% accuracy and SYNC-pin. 1-2-3-4A options.
    Smallest 2x3QFN package with wettable-flanks for optical PCB inspection.
  • Hi Kevin,
    Sorry for the late reply.
    Your answer was really helpful and i could understand it fully.
    Thank you for your kind reply again.
    Yun
