Other Parts Discussed in Thread: LM5170
Hello:
Now in my project, I will use the Lm5170 output(use buck mode,the output voltage is about 12V) to control a product. In my test, I use the DCDC output to connect the product, work is normal. Then I close the contactor(this contactor is in the product), then the phenomenon is: the contact is closed,but later it is open. I think it will be output current limitation. How can I enhance the output current? Now I see when it is closed, the voltage changed is normal. Or I want to use this way, how can I use it? I want to check my use way is right or not.Could you please help me check it? Thank you very much! I will wait for your reply!
