We have several dc-dc modules designed with UCC28780 controller.
We obtain all design values from the spreadsheet SLUC664b.
Consider a design with 380V DC input with very little input ripple, output 5v/4 amp, we use NV6117 primary GaN and EPC output sync rectifier using UCC7138 controller.
A lot of values in the spreadsheet come out "####", or " divide/0" or negative in DC-DC converter case.
If we use all the ac input values by default, we get no such error results.
Will highly appreciate if you can point out why the DC-DC case does this & how to input several of the ac case inputs that are consistent with the formulas used behind the scene and yet not conflicting with our DC inputsluc664b_5v3a_oct29_330aM.xlsx.
Pl see attached example .
robin
