Part Number: BQ34Z100-G1
Other Parts Discussed in Thread: BQ34Z100
BQ34Z100 has a pin called VEN, the definition is as below:
Active High Voltage Translation Enable. This signal is optionally used to switch the input voltage divider on/off to reduce the power consumption (typ 45 μA) of the divider network.
But i could not find the method how to control the output logic in all the documents, would you please help to share me the details?
In addition, there are 2 functions referred in the datasheet: voltage measurement consistency check”/“fast convergence”, how do they works?
thanks!
