CSD19538Q2: Layout recommendation
Part Number: CSD19538Q2
Other Parts Discussed in Thread: TIDA-010083
Hi Team,
For CSD19538Q2, what's the recommended PCB pattern?
In datasheet, Pad 7 and pad 8 are not connected to the S or D, but they are electrically connected to the source and drain, respectively.
Thank you!
Marc
  • Hi Marc,
    Thanks for the question. You are correct that pads 7 & 8 are connected to source and drain, respectively. The PCB pattern is included in section 7.1.1 on page 9 of the CSD19538Q2 datasheet. This device is used on multiple reference designs as can be found in the product folder on ti.com. I have opened the Altium board file for TIDA-010083 and attached a screen shot of the FET with routing included. Hope this helps.
    CSD19538Q2_layout_example.pdf
