Part Number: LMG1020
Hello!
We've been asked by a customer if it's possible to operate LMG1020 at frequencies higher than 60MHz(around 100MHz) because it has very fast rise, fall, and propagation delay times.
From what I know, the maximum frequency that the input can handle is limited by the physical construction of the device and can operate only up to what the datasheet specifies.
I'm unable to ascertain if having fast tr/tf/tpd will mean having higher operating frequencies as, so far, I haven't found a TI document that discusses this.
Could you please advise if it can indeed be used at higher frequencies or share a document if there's any?
Thank you for your help!
