Part Number: TPS65218D0
Other Parts Discussed in Thread: TPS6521815, , BOOSTXL-TPS65218, TIDA-00478, IPG-UI
We will use only four DC-DC buck converter of this PMIC (DCDC1 to DCDC4) for XC7010 xilinx IC. Voltage levels and sequencing will be done by BOOSTXL-YPS65218 tool by using UI provide by TI for initial prototype.
After programming , we put this PMIC to our board, in this case i have following question :
1. Should we use Push button switch for PB or AC_DET pin. or by simply pull up is sufficient to enable PMIC for PB/AC_DET and Power_EN PIN. We don't want to put in Push button in our design ?
2.VIO=5V is right or not....?
