Is it okay to leave pin9 floating? Thank you!
Patty Chuang
Hello Patty,
Yes, pin9 (PWMCNTL) of the UCC28063 can be left floating (unconnected) if this feature is not used.
It does not require any pull-up or pull-down resistor on this pin for the IC to function.
If someone wishes to observe signal toggling of this pin, for whatever reason even if the PWMCNTL function is unused, I recommend to apply a high-resistance pull-up to VDD, on order of 1Megohm or so, to avoid any significant loading of the VDD rail.
Ulrich
